Question about Acer Aspire 5600 Series 5630-6951 Laptop
Speakers don't work
My volume bar at the bottom of the screen show the volume to be adjusting, but there is no sound.
  • 46 Answers
Make sure your Windows volume control isn't muted.
Posted on Mar 04, 2009
How can I adjust the volume on my monitor
dose your monitor have speakers ?
otherwise use your mouse & at the bottom right corner of your screen there will be a icon that looks like a speaker click on that & you will see the volume bar
Mar 13, 2016 | E-Machines E17T 17" Flat Panel LCD Monitor
How can I set time and volume?
These 2 things can be done using the "Menu". (You can also adjust the Volume from the Driving Screen - tap bottom left area and slide the volume bar to adjust the volume).
From your Driving screen (showing map of current location), tap on the (middle of the) screen, to show the Main Menu (on the next screen),
Look for, and tap on "Change preferences".
1. To set Time:
On the next screen, look for and tap "Set Unit". On the next screen, select (tap on TIME), and you can set (reset) the (display) format and time.
2. To set Volume:
On the next screen, look for and tap "Volume preferences". You can then tap on the bar (position) and test/hear the level of the sound. And/or you can select "Link Volume to car Speed" ... and tap Done.
Feb 11, 2016 | Tomtom One GPS
I am having problems adjusting volume
What type of laptop HP , ASUS , COMPAQ , ACER ?..........
Up the Volume on My HP Laptop
Open the "Start" menu and click on the "Control Panel" icon.
Locate and open the icon that deals with sound.
Depending on your version of Windows, it will say either "Sounds and Audio Devices" or "Adjust System Volume."
Adjust the volume under the "Speakers" icon.
To do this, click on the slider bar and move it up on the slider.
If you need to decrease the volume, simply move the slider bar down.
Click on "OK" when finished and close the "Control Panel" window.
Click on the speaker icon in the bottom-right corner of the screen for a faster volume adjustment. Simply move the slider bar up to increase the volume and move it back down to decrease the volume.
Volume on an Acer Laptop
Acer laptops are typically sold with pre-installed Windows operating systems that offer sound-adjustment features for increasing the volume on the laptop's built-in stereo speakers.
These same functions can also be used in tandem with external speakers or headphones to increase the volume, as well as mute all sound on the laptop.
If the computer should output an unusually low volume, fixing the problem may be no more involved than sliding a control switch with the computer mouse. Click once on the speaker icon in the taskbar on the lower-right corner to open a rectangular window with a slide control.
Click and hold the left mouse button on the slide control to drag it upward, increasing the volume to the laptop's maximum setting.
Click the "Mixer" button below the slider control to open another window with volume controls for "Speakers" and "Applications," adjusting each slide control upward to increase the volume.
Be sure the speaker icon below each control is not accidentally muted.
Click once on each speaker icon to remove the red circle with a slash through it, which will restore audio.
Click the Microsoft flag or "Start" button in the lower-left corner if the shortcut speaker icon is missing from the taskbar.
Click "Control Panel" to select "Adjust Sounds" from the Hardware and Sounds category.
Aug 10, 2013 | Computers & Internet
Dell latitude D610 will not unmute
    • 1 Click on the speaker icon in the system tray of your windows 7 screen, located in the task tray by the system clock. This will cause a volume adjustment screen to pop up. Drag the volume slider to adjust the volume higher or lower.
    • 2
      Right-click on the speaker icon and select "Open Volume Mixer" to manually adjust the volume of each device separately, using the same method as in step 1.
    • 3
      Right-click the speaker icon and select "Sounds" to change which sounds play for specific events, such as Windows Startup, Windows Logon and System Notification. This should bring you directly to the "Sounds" tab of the sound menu, where you can click the program event from the list and change the sound using the drop-down menu at the bottom. You can choose "(None)" to disable the sound.
      car headlights.
Jun 01, 2012 | Dell Latitude D610 Notebook
Can I mute or lower the volume on my nuvi 265T without going to the main menu?
If you go to the screen that shows WHERE TO and VIEW MAP there's a speaker icon in the bottom right corner. You touch the speaker and it brings you to the screen where you can adjust the volume or mute it. I don't know if that's what you mean by the main menu but I'm afraid it's the shortest way to adjusting the volume.
Aug 02, 2011 | Garmin Nuvi 265W GPS Receiver
Good morning -- I am having an issue with my volume - I have it on the highest possible, but my speakers aren't able to pick up much still
Does any sound at all come out of your speakers?
1. Go to Start > Control Panel > Sounds and Audio Devices
2. Under the volume tab, turn your "Device Volume" bar up
3. Also, click on "Speaker Volume" at the bottom and adjust both left and right speaker bars up
Jul 20, 2011 | HP Compaq Presario SR1920NX PC Desktop
I do not know how to increase the sound volume on this computer
What operating system are you using..If you are using windows look at the task bar at the right facing your pc you will see a speaker icon then click it then adjust your desired sound volume...
Jul 01, 2011 | Computers & Internet
The volume is to low
hi
you will see a speaker icon on ur toolbar i.e the vertical bar at the bottom of your desktop page.. click on it to adjust the volume.. if that doesn't solve the problen, go to "control panel" and click on the "sounds" icon check if all the accessories shows "working".. if not, the problem is from the sound card and you will have to get it replaced
GOODLUCK!!
Feb 13, 2010 | Computers & Internet
I lost sound in my computer and i also don,t what,s real problem ,please help resolve this problem
Look in your task bar (bottom right) for the picture of a speaker...it will show "volume" when you hover over it. Double left click on the speaker icon and it will show the "Master Volume window"...make sure none of the "Mute" is checked, if they are the un-check them.
Also bring up all the "sliders" to the top. This will give you max volume.
Good luck,
Hope this helps
Oct 30, 2009 | Audio Players & Recorders
Volume level display
it sounds like your laptop drivers aren't working properly.. possibly the program dealing with your sound volume is corrupted or missing.
I'd try reinstalling your keyboard/touchpad drivers. what is the make and model # of your laptop?
Dec 28, 2007 | Lenovo ThinkPad R60 with Wireless Wide...
Acer Aspire 5600 Series 5630-6951 Laptop Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
