Question about LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher
Get an error code of E1 a few minutes after you start the wash mode. Manuels said that it is a water leakage problem,but it doesnt say where to look or what to do about it.
    Sergeant:
    Champion:
  • 338 Answers
I would look under the dishwasher.. i believe the modle you have sits in a pan and if it fills with so much water then it will put out that error code. more than likely a mouse chewed a small hole in the drain line.. i would uninstall the dishwasher and start from there.. when i say uninstall i mean pull it out from under the counter.
Posted on Mar 01, 2009
Installed new dishwasher, not working properly
If it is an LG:
ERROR DISPLAY [E I ] Leakage error. Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
Apr 01, 2015 | Dishwashers
Hi, I have an E1 error code what could that be.
E1 error code is when you have water leakage problems.
Check for blocked or chafed hoses and loose clamps for leakage areas. Check the tub seals as well.
Also check that the water pump seal is not leaking. If so, you will have to replace the pump as it is a sealed unit.
Jul 19, 2014 | LG Dishwashers
Powerpoint dishwasher flashing E1 any solutions please
E1 is commonly know as a leakage error which occurs due to the excessive RPM of Washing Motor happened during Wash cycle due to water leakage. To start with check if there is a water leakage in hose connections, motor water seal leakage of sump assembly or water is leaked due to damages. Replace the connections of Hose if bad. Also check the point of damages and repair or replace the related parts.
Mar 07, 2012 | Hoover 24 in. HD98E Built-in Dishwasher
Error code E1
E1...LEAKAGE ERROR-displayed-
The excessive RPM of
Washing Motor
cycle due to water
leakage.
The Motor Water Seal leakage of
Sump assembly.
The height of Drain Hose connection
(sink-Drain Hose) is not over 20 .
Impeller of the Washing Pump is
worn away.
Read the Installation Instructions
(page 9) and fix it to the
recommended Height.
Replace the Impeller of the
Washing pump
this is from your manual any more questions please message me back thanks again
rickead1
Sep 02, 2010 | LG WM2487H Front Load Washer
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
LG 3 in 1 Dishwasher model LD2131SH showing E1, leaks water
e1 is a leakage error. you will have to find where it is leaking from...crack hose .crack motor assy.. water must be leaking
The excessive RPM of Washing Motor happened during Wash cycle due to water leakage.
Water leakage in Hose connections. Water is leaked by damages. The Motor Water Seal leakage of Sump assembly. The height of Drain Hose connection (sink-Drain Hose) is not over 20 . Impeller of the Washing Pump is worn away.
Sep 11, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Getting error message E1 what does this mean
E1 leakage error
Replace the connections of Hose. Check the point of damages and repair or replace the related parts.
Replace the Impeller of the Washing Pump.
Sep 03, 2009 | LG LDF6810ST Stainless Steel Built-in...
Dishwasher sounds like it is straining LG LD-2040WH
E1 leakage error
Aug 30, 2009 | LG Dishwashers
What is an E1 error code for an LG Dishwasher? Model LD12AW2
Please check at both ends of the drain hose and confirm that you do nit have a leak. Also, please confirm that water is not leaking directly under the dishwasher.
If you are certain that you do not have a real leak, check the impeller (under the mesh filter in the sump area beneath the lower dish rack) is not damaged and is firmly in place.
The E1 error code is a Leakage Error, detected by the motor spinning faster than it should if the unit is filled with water.
Please report back with what you find. Good Luck!
Feb 15, 2009 | LG LDF6810ST Stainless Steel Built-in...
Open Questions:
See all LG 24 in. LDS 5811ST Stainless Steel Built-in Questions
LG 24 in. LDS 5811ST Stainless Steel Built-in Dishwasher Logo
135 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
