Question about Plumbing
Hi i have a 3 ton sears floor jack i can not
Hi i have a 3 ton sears floor jack i can not find model # or serial # i called sears they told me the #s where on the top of jack the sticker wore off leaving me with no #s on the rest of the jack ????? help the jack is about 6 years old .
I think I have the same jack. Th serial number was on a little sticker that is long gone,but the model number you need might needs is: 875.501390.
Hope this helps.
Gary
Posted on May 02, 2009
Send a picture of the jack to bernie at A&A hydraulic Repair info@hydraulicparts.com He will have a kit for it.
Posted on Mar 05, 2009
What model is 171-UK-A61218
Hi there, it's Jack at Dyson.
From the serial number you've provided, I can see you have a DC14 All Floors.
I'm not sure if you need any help with your machine, but if you do you're welcome to give the Dyson UK Helpline a call on 0800 298 0298. We're available from 8am-8pm from Monday to Friday, and 8am-6pm on weekends. Calls are free from UK landlines.
Mar 01, 2015 | Dyson DC14 All floors Bagless Upright...
How to overhaul/ repair a hydraulic floor jack?
Sounds like a bad seal on that plunger that pumps up and down. That plunger should unscrew and then it's pilled out , there should be an O ring. That is where it probably is leaking. You probably need to top off oil. You can jack oil in an auto store or Lowes, etc.
Jun 08, 2014 | Automotive HEAVYDUTY Hydraulic Bottle Jack...
Sears 11/2 ton floor jack
Is there anywhere that you can tighten the seal retainer if not needs a new seal . My experience is that a seal kit is as expensive as buying a new jack plus the work that goes into it. Look up how much to buy a new one and a set of seals then decide
Oct 21, 2013 | Washing Machines
I have a old 1.1/2 ton sears floor jack model is 328.12001
dont think seals will be available ,where it lock down to stay up is a ball bearing in a seat and this is worn .
May 07, 2012 | Cars & Trucks
I just inherited an older 3 ton floor jack. Guardian make, Model 4-102, 3000 lb. capacity. What type of fluyid does it take. who would I contact for repair parts? thanks
It was made by Hein-Werner, Similar to the WS model also 3,000lbs (not 3 tons). Been out of production at least 20 years or more. Guardian was Hein-Werner's cheaper off brand. Kind of a "dumbed-down" version. Also made an H-101 which was similar to H-W OS (O-Boy) model of 2500lbs.
Try a hydraulics dealer who sells Hein Werner parts. although obsolete, about 1/2 the parts are still available.
Lastly: Hydraulic jack oil. Never use brake fluid. Engine oil in a pinch, by I would never do it.
Jun 22, 2011 | Garden
Jacks stalls 1/2 way up
try opening the hydrolic oil "fill" plug to let air in...Your jack came with a vented plug,for you to put on after shipping...so oil doesn't leak while being transported...I hope this helps,...1nglen
May 04, 2009 | Plumbing
Floor jack will not raise even without load
sounds like either pump piston seals or check valve on pump.
Apr 02, 2009 | Plumbing
What Jack and stand to get for my '04 Ram 1500 Short Bed V6?
THE SAFEST CHOICE IS THE 3 TON.. YOU COULD GO WITH THE 2 OR 2.5 TON, BUT WITH THE SIZE OF YOUR TRUCK YOU NEED THE 3 TON..REMEBER TO ALWAYS USE THE JACK STANDS..GOOD LUCK KEITH...
Mar 14, 2009 | 2004 Dodge Ram 1500
Sears 4 Ton Hydraulic Automotive Floor Jack-Will Not Lift ?
I have a Sears 1 1/2 ton floor jack. I was able to buy a repair kit from Astro Pneumatic Tool Company 372 OLD U.S. Hwy 52 South Mount Airy N,C 27030-8093
1-800-221-9705
John
Sep 27, 2008 | Plumbing
Plumbing Logo
1,308 people viewed this question
Top Plumbing Experts
Tom Chichester
Paul Carew
Are you a Plumbing Expert? Answer questions, earn points and help others
