Question about Dell Dimension 2400 PC Desktop
Picture on monitor will get big then go back to normal
Every so often my picture on my monitor will magnifly then go back to normal
My picture on my monitor is to big for my monitor,it just happened one day
Posted on Mar 12, 2009
  • 523 Answers
Check your windows monitar setting, if it has no problem! update your vedio card driver, if non work u have problem in your vedio card. change it.
Posted on Mar 01, 2009
It is 7x3cm big, and its like dark green with bright green lines. I can see underneath it my screen, but only if i look deep.
if you can hooked up with other monitor just to ensure if the problem is only with in the monitor. after you replaced with other monitor then the display is clear or good picture, that was mean the only problem is the monitor. if the upper portion is black screen or the picture not so clear the cause is busted screen back light. to see the back light you will need to remove the back cover of the monitor. then the back light is a thin cold cathode flourescent tube, it was covered with a metal shield cover protection attached at the upper portion of the screen panel display.
Nov 08, 2012 | Samsung SyncMaster 913V 19" Flat Panel LCD...
Display got big after search
click start control panel display desktop you can select a different desktop from the drop down list
or a browse button where you can select different pictures this may vary depending on your operating system
also you can change the settings for more or less pixels or from the drop down list pick the appropriate level of color range or troubleshoot also select advanced then general dpi normal size,larger size or custom settings
always click APPLY after making any changes
depending on your monitor it might have some adjustment tabs usually located on the front underside of the monitor where you can centre your screen if needed
hope this helps
Jul 09, 2012 | Computers & Internet
I have a Dell SyncMaster 400Pn I did the flashlight thing and I can see a picture. So I assume I have a back light issue. How do I trouble shoot the back light???
This is a BIG monitor! First place to look will be the 24vdc power supply section of the power supply module, then check the surface mounted fuse on the backlight inverter board. You can use my LCD troubleshooting guide to help you out, it is jsut a big TV without a tuner sedction. I could not find many info about this monitor replacement parts.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 16, 2010 | Dell UltraSharp 2001FP 20.1" LCD Monitor
How can I reset original monitor settings? I touched controls under screen and now everything is big.. I have a samsung 19'' monitor.
hi
you have to reset screen resolution from the properties
just go to
desktop
right click mouse
properties
settings
there u will find screen resolution just select (1280 by 800 pixels)
it will be back on normal screen
Jun 27, 2010 | Samsung SyncMaster 932GW LCD Monitor
The screen turns blackout then after a seconds it turns back to normal..
The problem is the picture board on your monitor, the picture board on the monitor is malfunction, that is why the screen goes off after few seconds and turn back on.
If the problem is a regular one, i will advice you replace the picture board on your monitor to fix the problem.
Take care.
Jun 22, 2010 | AOC 5 En 15" CRT Monitor
My monitor suddenly turned pink and light green. I can hardly read text or see picturs. How can I fix the monitor/screen color problem? Thank you.
if this is a CRT or big monitor to the back you have cold solder on the CRT board this is the board to the back to make sure tap the monitor to the back and see if the color change back you will have to open and re solder that crt board
Jan 11, 2010 | Gateway FPD1975W 19" LCD Monitor
The image is stretched, how do i set for a normal image. its a 21 in moniter
some images will look streached if pixels of the picture are not as big as the monitor. what happens if you just use one of the windows images that come preloaded. if that is the case u can ether center it or find picture that has more pixels.
Nov 27, 2009 | E-Machines eMachines Monitor E15T4
Slow start
(I'm copying a guest's comment above. What Gateway told him does seem to work - although in my case, the monitor was slow to start when plugged directly into the wall, and it was immediately fixed when I plugged it back into a heavy duty power bar.)
hey, I had the same problem. Gateway told me "Plug the monitor power plug directly into a wall electrical outlet
or a different wall outlet by removing any surge suppressors." I did that and it works. It might be a certain kind of power bar they do not like. It worked for me so try that and see if that helps.
Dec 10, 2007 | Gateway FPD2485W Television
Picture too big
Assuming that it is not a hardware problem, in Windows XP (or in most Windows version), you need to increase your display screen resolution. To do this, pls click on any clear area of your desktop. Click on Properties, click on the Settings tab, move the Screen resolution slider towards the right. Tha maximum resolution of your Acer LCD is 1280 x 1024. Set it to your preference/allowable. Click on Apply button, click on Yes button, OK.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Dec 07, 2007 | Acer AL1912 19" LCD Monitor
Dell Dimension 2400 PC Desktop Logo
42 people viewed this question
Alun Cox
