Question about Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x 48"
Any problems with Watts FS-cwm-s-hh??
Has anyone had problems with Watts Floodsafe flexible connecting hoses??
  • 659 Answers
If the water pressure is too high, it will trip the "floodsafe" connection prematurly. You have to find a way to reduce the pressure to it.
Posted on Mar 17, 2009
  • Tim Leahy Dec 11, 2010
    Watts FloodSafe hose - 1/4" Ice Maker x 10' - I'm having a problem with a bad taste coming out of the refrigerator water after connecting this tube. No problem with plastic tubing, but I've had a couple of leaks from the plastic ones.
I just installed a tuscany brookesville pulldown kitcken faucet. I cannot get any hot water. I checked the line and I have water to the connection. What do I do?
Hi Wilber- are you using the Watts brand "Floodsafe" auto-shutoff connectors for your hot & cold water supply lines?
Refer to the following link, please: http://www.watts.com/pages/whatsnew/floodsafe_connectors.asp
Feb 23, 2015 | Plumbing
Reset floodsafe lines
To reactivate flow of water to the fixture:
  1. Close the shutoff valve to shut the water supply to the FloodSafe™ connector
  2. Disconnect the FloodSafe™ at the shutoff valve. This will automatically reset the FloodSafe™ device.
  3. Reconnect the FloodSafe™ according to installation instructions and turn on water supply to full open position. Check for leaks.
Apr 27, 2009 | Kenmore HE2 Plus Front Load Washer
Screechy shower curtain
what I would try is putting a strip of glue from a glue gun. It is barely noticeable. But us enough to stick.
Apr 12, 2009 | Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x...
Adjusting power output on FURUNO FS 1502
hi Wally.
this is all i could find,go to this link and see if it helps you out,if not try youtube.
how to Adjust power output on FURUNO FS 1502 Google Search
Nov 19, 2017 | Furuno FS1503 (199 Channels) 2-Way Radio
F-h is the problem magtag neptune front load
fh is a NO WATER fault, check your incoming water supply, watch out some new stainless steel inlet hoses marked" floodsafe" are imfamous for shutting water supply, if you have these hoses i strongly reccomned replacing with "NORMAL stainless steel inlets" FLOOD SAFE brand no good
Jan 21, 2009 | Maytag EPIC MFW9700S Front Load Washer
E70 error on Model LTF2940FE1 Front loading washer
good to see you cked that , 1 question though are you by chance using stainless hoses made by company FLOODSAFE. if so theres your problem theres a shut off inside the hose itself that is malfunfuctioning, replace with regular s/s hose and all will be good. if your not usinf a floodsafe hose hten lets go to the next hting- when oyu first start machine, cold water flows in before cycle even starts, can you hear it coming in??? at least trying perhaps a light humm with no water? water vavle is located under main top you can remove the top and check for voltage when trying to fill
Mar 10, 2008 | Washing Machines
Watts 0392262 FS-CWM-S-HH 3/4" x 3/4" x 48" Logo
195 people viewed this question
Top Watts Home Experts
john h
Tom Chichester
Are you a Watts Home Expert? Answer questions, earn points and help others
