Question about Technics SA-EX900 Receiver
I am unable to receive either AM or FM stations on my receiver. On certain band ranges I hear a thumping sound. Help would be appreciated. Al
  • Anonymous Mar 30, 2014
  • 156 Answers
Hello. well i can think of a few things that would do this. One being that you antenna is not hooked up into the back of your radio, two you have no antenna or three you have a window seal antenna and part of it is brokwn and needs to be replaced. To check these take out the deck and see if the port where the antenna goes into is plugged in and if it is find out what kind of antenna you have
Posted on Mar 01, 2009
I experience a problem with the unit in radio mode. When switched on the radio do not latch on the station (only background hiss) Only after repeatedly toggling the BAND button (random times)it will l
Try turning off the AutoTune (lock, center....) function (on most FM tuners) and retune manually to the errant station. Then reactivare auto-tune, or not. Toggling bands (as you put it) means that sometimes signal will center, sometimes not...a more or less random thing as you say. That suggests resetting station auto lock. Bear in mind though that certains stations can simply be uncooperative depending on numersou factors such as transmit location, reception terrain, and so on.
Oct 03, 2014 | Crosley CR7002A Turntable
No Sound on AM or SW
If the set receives FM signals without any problem, and only fails to receive AM signals, the IC [integrated circuit] used in it is faulty. The number of the IC used with your radio is CXA 1376AS. It is a replacable type IC, and can be bought from most of the electronic spare part shops at your town. If you want further details about its service manual, get me by Fixya. OK.
Nov 11, 2011 | Sony ICFSW7600GR FM Stereo World Band...
Unable to tune in to programmes on LW, MW and SW bands. FM working fine
If you are experiencing bad or NONE AM (MW) reception ,if your receiver has an external antenna connection point here is the solution... It should also have a ground connection as it is rare such a point does not accompany an external antenna connection.
The problem with MW reception is the vast frequency range of the MW band as" 540-1760kHz "
means nighttime fade out, and even heavy static and distortion..( less than SW )
in order to receive a station on LW and MW bands you need to have a "Loop Antenna " that normally supplied by manufacturer..if you cant locate it ,you can buy it in any electronic is a very cheap accessory..additionally both LW and MW works good in daytime with powerful radio stations in your vicinity ..espacially LW..not much stations on these days..except in Europa..MW works better and more stations come after sunset ..
SW band is a little bit different.if you really want to listen SW in depth ,and if your receiver has multiple SW bands as well ,you then need special SW antenna to be attached to your receiver..otherwise it is not worth to listen it due to heavy static and distortion on the band..,unless you want it..just for testing and to see what is available in your area pls attack a plain wire (about 1 meter ) to ext antenna plug and try to search it..if you desire to learn shortwave -Listen To The World please visit the URL below.
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote for us
to continue f
or Helping out the Community :)
Jul 07, 2011 | Audio Players & Recorders
I have an older onkyo integra (TX-870) which pop when I change stations, then no sound. Need to turn off and begin again. Can this be fixed or should I purchase a new 2 channel sys?
Hi, It sounds like you are listening F.M. radio and the F.M. muting button is engaged ( as well it should be-otherwise you will have static between the stations ) sometimes there is almost a "THUMP" sound when you switch stations-this is caused by the receivers P.L.L. circuitry losing then locking in on stations, if you do not lower the system volume you will amost assuredly cause an overload of your final drivers, that's why it will come back on when turned off-it has reset. Turning off fm muting will get rid of the "POPPING" noise-it will however leave you with unbearable static which in turn should cause you to lower volume momentarily eliminating the need to constantly turn off the receiver. Thank for asking FixYa, I hope this helps, let me know how I did or if I can be of more assistance, good luck Prodzilla
Apr 13, 2011 | Onkyo Audio Players & Recorders
How do I preset the tuner for radio stations. I've never had a problem doing this with any other stereo. But what I think should work isn't!
Not very specific. Do you have the manual?
The following is from a VSX-03TXH manual. It ain't pretty but it may help.
I'm posting it in multiple parts due to space contraints.
Chapter 6:
Using the tuner
Listening to the radio
The following steps show you how to tune in to FM and
AM radio broadcasts using the automatic (search) and
manual (step) tuning functions. If you already know the
frequency of the station you want, see Tuning directly to a
station below. Once you are tuned to a station you can
memorize the frequency for recall later-see Saving
station presets below for more on how to do this.
1 Press the FM/AM button to select the tuner.
2 Use the FM/AM button to change the band (FM or
AM), if necessary.
Each press switches the band between FM and AM.
3 Tune to a station.
There are three ways to do this:
Automatic tuning
To search for stations in the currently selected band,
press and hold TUNE ?©/?? for about a second. The
receiver will start searching for the next station,
stopping when it has found one. Repeat to search for
other stations.
Manual tuning
To change the frequency one step at a time, press
TUNE ?©/??.
High speed tuning
Press and hold TUNE ?©/?? for high speed tuning.
Release the button at the frequency you want.
Improving FM stereo sound
If the TUNED or STEREO indicators don't light when
tuning to an FM station because the signal is weak, press
the MPX button to switch the receiver into mono
reception mode. This should improve the sound quality
and allow you to enjoy the broadcast.
Using Neural THX
This feature uses Neural Surround™, THX® technology to
achieve optimal surround sound from FM radio.
• While listening to FM radio, press AUTO/DIRECT for
Neural THX listening.
Dec 23, 2010 | Pioneer VSX-07TX Receiver
I have a 1999 Cadillac DeVille Concours with an AM/FM/Cassette/CD/RDS Radio. The AM works fine, the FM does not, screen shows digital info(stations like 99.3, etc) but no sound. RDS does not function at...
Well there's lots of possible reasons. The FM receiver portion of the radio is separate from the AM Band receiver, pre-amp, and amplifier sections of the radio. The FM receiver may have simply failed, as well as the CD player portion of the radio. Your car FM needs repair, you need a multimeter to check it or take it to a repair person. Please post further comments for further help or information......
Good Luck!!
Jul 06, 2010 | Car Audio & Video
I can barely hear sound even when turned all the way up
Turn-off all "surround sound" modes. Try listening to just a plain AM or FM talk station. Then you can check your speaker wiring. Some stereo programming can turn into nothing with certain surround modes, so make sure that your speaker wiring is correct by using the radio or CD player with it first.
Nov 10, 2009 | Harman Kardon AVR 120 Receiver
How do I preset radio stations on my hi-fi system?
Owner's Manual is PN 3834RH0020U
On pg13
1. Press TUNER/BAND to select AM or FM
(Leftmost rectangular button on left of volume knob)
2. Select station by using TUNING +/-
3. Press PROGRAM/MEMO on the remote
A preset number will appear.
4. Press PRESET +/- (or PRESET ^/v on remote) to
select the preset number you want.
5. Press PROGRAM/MEMO again. The statio is stored.
6. Repeat above for more stations.
Believe you can store up to 30 stations.
Apr 28, 2009 | Denon DRA-375RD Receiver
Tuner Omits No Sound - Onkyo TX-SR605 7.1 Channels Receiver
Make sure your receiver is hooked up to proper AM and FM antennae. Try switching to AM, scan stations. If you hear AM static and/or weak signals the problem could be antennas are not hooked up. FM has AFT which blocks out weak or noisey stations and you wont hear anything without ant.
May 06, 2008 | Onkyo TX-SR605 Receiver
Apr 26, 2007 | Kenwood DPX-440
100 people viewed this question
Top Technics Audio Players & Recorders Experts
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
