Question about Maytag Refrigerators
How do you get the ice/water dispencer unlocked ?
How do you get the ice/water dispenser unlocked ?
  • slang1 Mar 01, 2009
    I talked with a rep.
    The proceedure is to press the lock button 3 times within 10 seconds.
    It worked !
    President:
  • Maytag Master
  • 2,651 Answers
It may bve as simple as holding down the "lock" button for 3-5 secs?? its also quite possible depending on the age( within the last 2 years, they have built in a safety featurein which the dispensor "thinks " there has been a flood and for your protection turned off the dispensor, if indeed this happened you would need to reset the main control, a cust service rep could possible walk you thruogh thosesteps if needed.
Posted on Mar 01, 2009
No water from the Icemaker and Water Dispenser Dual Inlet Valve
if no water is going to both icemaker and water dispencer, check water supply to refrig. into valve.
If ok and valve is being energized by dispencer arm and icemaker, then it's probably a bad water valve
Dec 03, 2011 | Whirlpool Refrigerators
How do i access the ice dispencer door in the door? The door is stuck open and freezes up the dispencer.
1. Disconnect the unit from the electrical
supply and wait for 3 to 4 hrs to get ice melted.
2. Pull out and unclip the drip tray on the ice
and water dispenser compartment.
3. Remove the screws from the ice and water
dispenser compartment front panel and
turn it over. The selector switch pack and
dispenser switches are now accessible for
testing.
Jan 29, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
GC3SHEx300 ice dispencer does not dispense cube or crush ice. Water comes out, lights work. it is not deactivated.
Sep 06, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
How to unlock ice and water dispencer.
Press and hold the lock button (one that has key emblem) until the lock light goes out. If that does not solve it or that light is not on , you may have a dispenser board problem..
Jun 11, 2010 | Maytag MZD2766GES Side by Side...
Water dispenser suddenly stoped working. Ice dispenser working
check the water line fron filter that continues on to water dispfrom icemaker, also a bad water disp solenoid or no pwr to water valve disp solenoid could be a problem,when you try to disp water can you hear a click from the solenoid operating to let water out?
Aug 16, 2009 | Frigidaire FRS23KF7AB Side by Side...
No water supply to water dispencer
I had this problem with an old amana and my water filter neded replacing. Filter was enough for ice but not for water dispenser.
Mar 27, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Water dispencer not working
check inside the bottom of the refrigerator for water, the water line goes thru the back of the refrigerator and it may have cracked and leaking inside instead of going to the dispenser.
if not then water is most likely frozen in the line going thru the back of the refrigerator. look behind the pans in the refrigerator and there should be a coil of clear plastic water line, this is the reservoir that chills the water for the dispenser. sometimes it will freeze up if the refrigerator is very cold.
May 07, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Door dispenser stopped dispensing, starting making a constant clicking and now the entire fride isn't working
We had the same problem. Our frigerator is 1.5 year old. Everytime we try to dispence water or ice the dispencer clicks and the whole thing turns of. We had a GE repairman come by: the electronic board needs to be replaced: total cost $350. (cost of the board only: $150. We are considering disconnecting the dispencer by unplugging the board (according to the repain man the ice maker wil still work)or buy a new refrigurator (for sure NO GE!!!!!!)
Aug 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
264 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
