Question about Gateway 510 X PC Desktop
Driver/Firmware Problen on a Lite on CDRW
My system gives an error when trying to use the CD, the error tells me that it finds the driver but cannot find the device. Error code is a 41.
Do you know how I can fix this problem. Tried Geek Squad and they did not know.
WDM
  • Wayne Morgan Mar 06, 2009
    3/6/2009
    Had an IT tech friend fix the problem today. This error code is caused by 2 registry entries that become corrupted. The tech logged intohttp://support.microsoft.com/gp/admin and copied the instructions for removing the corrupted entries. Any CD copy software has to be uninstalled prior to correcting the registry.
    After the registry entries were corrected (deleted), the system was rebooted and the CD RE was properly installed and is working fine.
    The Microsoft article number is Q314060.
    WDM
  • 741 Answers
Here ya go straight off the Microsoft Knowledge Base. Geek Squad too lazy to research:
Code 41
Windows successfully loaded the device driver for this hardware but cannot find the hardware device. (Code 41) Recommended resolution
This problem occurs if you install a driver for a non-Plug and Play device, but Windows cannot find the device. Here are some things that you can try to resolve this problem.
If the Troubleshooting Wizard does not resolve the problem, do one of the following:
  • If the device was removed, uninstall the driver, connect the device, and then click Scan for hardware changes to reinstall the driver.
  • If the hardware was not removed, the driver files might be obsolete. In this case, update the driver from Device Manager. In the device Properties dialog box, click the Driver tab, and then click Update Driver to start the Hardware Update Wizard. Follow the instructions to update the driver.
  • If the device is a non-Plug and Play device, you may have to install a newer version of the driver. To install non-Plug and Play devices, use the Add Hardware wizard. Click Start, and then click Run. In the Open box, type hdwwiz.cpl.
4 diamonds pls
Posted on Mar 01, 2009
  • Randall  Trahan
    Randall Trahan Mar 06, 2009
    Great glad to hear you got things going again..
WINDOWS VISTA 64 bit not reading CD Rom/ DVD player after services pack download. Driver is best. Error message "problen in registry (code 19)
If it truly needs a driver then install patin-couffin It will bypass all that windows uses now and accurately talk between drives and the dvd-rom. But it sounds to me that your dvd-rom just failed. You never know when they are going to go
Apr 17, 2013 | Microsoft Windows 7 Home Premium Operating...
Drivers for sony cdrw dvd crs8435e missing
try to find the driver in the cartoon of your cd-rw/dvd-rom, or you may visit any sony service center in your area they have a driver in there. thanks
Jun 28, 2011 | Sony CRX835E CD-RW/DVD-ROM (Combo) Burner
My computer HP Pavilion dv6000 doesn't detect the Cd-Rom. I also can't write Cd-s. the system is windows 7
Hi
if you click on this link it should take you to the hp site type in y our product informatio or
i would go for the 2nd option automatically detect products
when you click on it it may well give you a dropdown bar across the top of your screen look out for it because you will have to give permission to download the file
so click download file
the scanner will then scan your laptop and offer up any updated driver than you may need
if this does not offer you the cd-rom drive then take option one give your information and find the driver
Unfortunatly if the drive is just a cd rom which we dont much of these now a days they will not write cd-s but it should be at least a cdrw in the slot and probably a cdrw/dvdrom
good luck
please let us know if this has helped you
Jan 31, 2011 | HP Computers & Internet
Lite on combo ltc dvd drive not working in my computer
is it reading a disc??
if it is neither reading nor burning any disc...upgrade the firmware of the drive
Jun 25, 2010 | Lite On LTC-48161H CD-RW/DVD-ROM Burner
Lite on DVD Combo disk read failure
You could take the drive out of the encloser and hook it up. There could be a flaw in the enclouser ive had that happen before to me. I just took it out and put it in standard if this dosent work then there is a flaw in the dvd burner
May 20, 2009 | AMD Duron 1.3 GHz (cpu-amd-1.3g-o)...
The CDRW driver cant be found
If you go to start, control panel, device manager, cd drive, right click it and click un-install.
Now reboot the system and test.
Hope this helps
Richard.
Apr 22, 2009 | Acer Aspire 3680 Laptop
Need drivers
If Windows detects and installs your hardware, let it do so and relax.
If you install Nero, and it then detects and installs your hardware, again let it do so and relax.
If neither of the above work, next time you use windowsupdate.microsoft.com you will normally get a good driver for anything that is currently not working.
If you wanna download, try this:
http://www.opendrivers.com/driver/224420/liteon-sohc-5235k-combo-firmware-lk04-free-download.html
However, this claims to be firmware, while then giving instruction on installing a driver so I can't be sure which it is. I haven't tried this last link.
Mar 26, 2009 | Lite On (SOHC-5235K-BGEOEM) CD-RW/DVD-ROM...
I have a lite-on ltr-2410b cd-rw...it says it has a usb 1.0 even though I have a 2.0 card in my computer. Is there an upgrade for the 2410b?
go into the system list, select the cd/rw drive and uninstall the driver. restart the the pc. the correct usb driver should then automatically be installed.
start, settings, control panel, system, hardware, cdrw, driver details, uninstall.
Nov 27, 2008 | Lite On Computers & Internet
Trying to find the driver to install for the cd-rw
Please download the driver file from this location its an exe file so when you will finish downloading click on open folder where you can find the correct driver file, and rest i think you know how to install it.
http://drivers.softpedia.com/get/FIRMWARE/Lite-On/LiteOn-LTR-52327S.shtml
Regards
Moses
Jan 13, 2008 | Lite On LTR 52327S CD-RW Burner
Driver
You should reinstall drivers to your DVD and after restart your operating system, install firmware (http://www.liteon.ab.pl/d/fw/1679S1B.zip) than second time reboot your PC.
Nov 13, 2007 | Lite On 167T DVD Drive
Gateway 510 X PC Desktop Logo
108 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
