Question about Toshiba Sattelite A105-S2051 Notebook
Jumping when write
When I try to write, frecuently pass to another line
example: good day I hope you have a nice day
failure: good day ope you ha I hve a nice day
this failure appear every time when use ''word''
could you pls give me a suggestion about that
Thanks & best regards
  • 46 Answers
You may be dragging your hand across the touchpad pointing device, which would move the cursor, then select the new location. Best fix: Turn off "tapping" under Mouse Properties.
Posted on Mar 04, 2009
SUSPENSION OF MY LICENCE, because did not pass the written test satisfactarmy. AJITDEOL AJITDEOL48@GMAIL.COM
ha ha ha ha ha ha ha ha obviously you arent bright enough to pass any test.
Aug 30, 2017 | Cell Phones
Tried to jump start my dead battery on my 950-T it wont say running and the engine, fuel, and oil light are flashing when it runs then it just dies is the battery ruined?
Hi, Anonymous and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
16. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/49-v-star/5524-vstar-950-starter-motor-failure.html
VStar charging problem
YAMAHA XVS950A Owner Manual
OEM parts for Yamaha
2010 Yamaha STAR 950 TOURER Motorcycle Service Manual Download Manuals...
Apr 22, 2014 | 2010 Yamaha V Star 950
My Lincoln navigator won't start tried to jump start but get nothing when key is turned on air ride kicks on but no radio is it starter
You need to perform some detective work. Diagnostics is very important due to the new complex electrical systems. There can be a dozen or more reasons why it won't start. From your symptoms it sounds like a loose cable or connection going to or at the power distribution box. You should have power to everything when the key is in the "Run" position. I would start there and check for blown fuses too. The problem could also be a failure inside the ignition switch but I need to read more first to help you better. Please elaborate on your description about jump starting the SUV. Are you saying that the battery was dead or were by-passing the ignition switch? If the battery is dead you need to take care of that first. If you were by-passing the ignition switch. I need to know why the engine didn't crank over. This failure alone could be the battery, either battery cable, or the starter itself. Please write back and be as descriptive and detailed as possible. You are the eyes and ears of this vehicle. I'll do my best to help you narrow down this problem and hopefully solve it, good luck.
Mar 18, 2014 | Cars & Trucks
Cooling System Failure 2000 Chevy Cavalier 2.2LOHV
Did you have the head checked, they have been known to break inside the runners . I always used a vacuum fill system when working on these, jack up the pass front corner when doing a coolant refill, that should eliminate an air lock
Nov 05, 2017 | 2000 Chevrolet Cavalier
Me temp gage is passing the center line but my car does n't overheats
First I suggest to check coolant level; could be a wrong about engine coolant temperature sending unit go to bad.
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Feb 10, 2012 | 1997 Ford Expedition
Camara Nikon D60 - error: pulse de nuevo el disparador
Hola,ha recibido alguna caida o golpe en el lado inferior izquierdo junto al display?
Si asi fue tiene el conector FPC cortado.
Otro la mas frecuente debe de reemplazar la unidad de secuencia SQ base plate unit.
Saludos
Feb 19, 2011 | Nikon D60 Digital Camera
Unit freezing up when running
The most common causes of evaporator freezing are:
dirty or obstruccted evaporator coil,
evaporator fan not working or working too slow.
and the most frecuent is LOW on R-22 Refrigerant. Check lines, look for wet looking spots and greasy/oily stuff on the lines.
Good luck!! Rate this post!!
Aug 10, 2010 | Breezaire WKCE 2200 Wine Cooler
Defrost want work
good day, you may have a water pump failure, have it replaced hope this helps, have a nice day
Feb 09, 2010 | 2003 Kia Rio
The T key on my wireless keyboard s oped prin ing.
please installthe window the problem is solves
Jun 05, 2009 | ASUS Eee 4G Notebook
Hello
I mean The phone cables, the ones that connect to the phone sockets.
Try first unplugging all power cords and waiting ten minutes, then check connection to phone, ensure that the phon cable is not for example on top of a power adapter.
Aug 29, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Toshiba Sattelite A105-S2051 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
