Question about Philips GoGear HDD1830 MP3 Player
When ever I turn power on my mp3 (8gb)it gets too hot...why?
  • 8,596 Answers
It is defective - find out if you are still in warranty by calling Philips. Overheating is bad news.
Posted on Mar 07, 2009
2000 tacoma flashers don't work but turn sig do work!
The hazard switch gets power from the horn fuse which is hot all the time, and from the turn signal fuse which is hot when the key switch is on. The turn signal switch gets power from the hazard switch and both use the same flasher.
So if the turn signals work but the hazard switch does not power the lights, and both fuses have power, I would say the problem is inside the hazard switch.
Feb 19, 2013 | Cars & Trucks
On a Kirby sentria the metal spool sticking out that goes into hose or power head becomes extremely hot and left burns marks on brush tube. It only gets hot when using power head. I checked all adjust
Check the brush roll to be sure it's spinning free too much drag can cause that to get hotter but usually it would break the belt. That spindle will get hot from the friction created by turning the belt and from the motor's heat. They'll just get hot, any brand that spindle will be hot after running it. It's just how it is.
Feb 05, 2013 | Kirby Vacuums
What wud be the reason behind fuser error in a printer?
A fuser is basically a really hot light bulb or heater element, turned on and off by the AC power module.
If the bulb/element blew, or the AC power module is stuck on or off, the temperature won't get hot enough, or will get too hot.
Either too hot or not hot enough will cause a fuser error.
Sep 08, 2010 | HP Office Equipment & Supplies
Our hot and cold water seem to be mixing. we had scalding hot water for a few days,then hot water tank died. put in a new one and now the water is warm for a minute then turns very cold.
When you filled the water heater did you get all the air out of lines and water flowing before you turned power onto heater. It sound's like the bottom element on the heater is not working. That is if it's the same throughout the house hot then get's cold.
Check the power to the lower element and thermostat.
Jul 09, 2010 | Delta Faucet Delta 467-SSSD-DST Palo...
My laptop turn off, I think it got hot, I can't turn it on now. turn off Sunday
try this,
unplug dc plug from laptop. remove battery.
wait a few minutes. press and hold the power button for 10-15 seconds.
plug the dc power plug back into the laptop, but do not put battery back in yet. Then try to power on. if it powers on, let it run a few minutes, but best to keep checking to see if it is getting warm or hot anywhere. if it is getting hot shut it down immediately. If it isnt getting hot then shut it down and put the battery back in.
if it doesnt power up, then i would have to suspect heat damage to the motherboard.
Feb 15, 2010 | Toshiba Satellite A135-S4527 Notebook
My boiler is not working, not heat, no hot water, red alert light flashing? I dont know how to reset the boiler or het it going again. Its a Worcester 24i junior. Help! Im very cold!
your condensation pipe may be frozen get a hairdryer on it or a hot kettle that should sort it thats the whit pipe on the left usualy plastic
Nov 13, 2009 | Water Heaters
We just relocaed a modual home with a Rheem electric 40 gal warrior hot water heater, we have no idea of previous care, in setting up the home and trying to get hot water, after turning the water on,...
sounds like the element is burned out....probably got turned on before it was completely full of water. You can get a kit that has new elements and upper and lower thermostat in it. Those are the only things that can go wrong with an electric water heater....other then leaks.
Oct 28, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Hot water heater
Absolutely no hot water indicates the top element or thermostat on the heater. Check to make sure that you have 240 volts on the top two terminals of the top thermostat. If you do then check the top element for voltage. It should also read 240 volts between the two screws. If you have 240 volts there shut off the power, drain the heater to a point below the top element and change the top element. When the element is installed turn your WATER back on and let the air bleed out of several hot faucets in the house. When the faucets stop spitting air you can turn them off. Check for leaks around the element. If you have no leaks turn the power back on the the heater and replace the covers.
That should get you 'back in hot water' in two hours.
Apr 05, 2009 | Element Chromalox SG1353-430326 Electric...
Will not scan, goes into warm up mode and then turn power off and
Might try unplugging the power cord and letting it sit for about 20 minutes. Right off hand it sounds like its getting to hot. Even if it is turned off power is still going to the printer so it can still get hot.
Feb 10, 2009 | HP OfficeJet r40 InkJet Printer
Won't turn on
I bought two tvs and after about 3 months one of my tvs would not turn on; this tv was used more than the other one that is still working. I noticed that the power cord has a box that connects the two parts of the cords together, well the box gets very hot. I thought that the problem could be the power cord (may be it burned out) and not the tv. I switched power cords from the working tv to the nonworking tv and that sovled the problem.
Dec 17, 2007 | Proscan 19LA25Q 19 in. LCD Television
Philips GoGear HDD1830 MP3 Player Logo
60 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
