Question about Sunbeam 2350 Stand Mixer
I need to find the motor brushes for a SunBeam mixer.
  • o_pedrosa Mar 03, 2009
    Thank you for all the help. You really help.
  • 137 Answers
Will not mix
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
Apr 06, 2014 | Sunbeam 2347 MixMaster Heritage Series...
My Sunbeam mixmaster junior model-jc is smelling when it runs
the smell will be burning insulation on the windings of the motor probably from the brushes being too short and arcing on the armature thereby overheating the motor. suggest you take it to an appliance repair shop for quote on repairs.
Jun 17, 2013 | Sunbeam 2346 Heritage MixMaster Series...
Mixer on my Sunbeam Model MX5900 compact mixmaster has burned out because beaters kept jambing in each other. Can I purchase just the mixer and beaters? Stand and bowl are OK
If the motors had burnt out then the winding can be redone if you can get this job to a winding shop.
Other wise the motor and assmebly can be ordered from a Sunbeam service outlet. try and see if you re able to source a motor assembly from a damaged/scrapped set with a mechanical defect.
Sep 20, 2011 | Sunbeam Food Mixers
Won't turn on after first use. 1801 220 watts hand mixer looks like 2562 250 watt mixer
It seems that the mixer is overheating and tripping the thermostat thus preventing further use. I would recommend a thorough overhaul. You will need to carefully inspect all the components, particularly Items the brush assemblies, and the commutator portion of the armature (where the brushes touch the armature), and everywhere else in the motor compartment. Any parts exposed to oil will need to be degreased and dried before reassembly. When you reassemble your mixer, the brushes can only be installed one way. Make sure the brush's concave contact face is resting completely on the armature. If it is turned it 90 degrees too much, it wont' seat properly and the motor will not get any juice.
While your mixer's apart you should check for any other unseemly wear and tear on the gears, etc. You may find more things that need fixing, adjustment or replacement.
You may find it easier to replace the brushes than degreasing them. I recommend using a food-grade grease that you can order online (although I've seen automotive bearing grease used too - your call). If you feel this is beyond your capabilities and will be too difficult to do by yourself you can take your mixer to a local small appliance repair shop and have them troubleshoot and fix your mixer.
Dec 12, 2010 | Sunbeam 2562 250 Watts Hand Mixer
I have the Sunbeam portable mixer 2486. I was making Parker house rolls with the dough hooks. After blending the dough, the mixer just stopped. The motor will no longer be turned on or off. I want to...
Hi Janis.
You have likely burnt the motor. That is the most common fault when the mixer is used for a prolonged time on a compact dough.
The best thing to do is ringing Sunbeam at the number listed on the owners manual, and checking what conditions for repair are offered.
If you have misplaced the manual, then track the number using Sunbeam website: Sunbeam.
Mar 02, 2010 | Sunbeam 2485 MixMaster Series Hand Mixer
Sunbeam mixmasters 2358 stop working suddently
Check the condition of the motor brushes and springs. The springs should have a bright brass look and not be collapsed. The brushes should not be broken or worn less than 1/4 inch long.
Feb 11, 2010 | Food Mixers
My sunbeam mixmaster blades wont turn but the motor is on?
Hi, GLENNHOLD148 - With a motor that runs and the blades do not turn, it appears that your mixer's suffered a mechanical failure in the mixers transmission. I don't know if your mixer is under warranty, but I suspect like any small appliance the warranty's only good for a year, and you've probably had it much longer than that. That leaves with with three options; purchase a replacement (Sunbeam and the economy would appreciate that!), take it to a local authorized Sunbeam repair shop, and finally attempt to repair the transmission yourself (DITY repair). The later can be most gratifying, however, sadly, Sunbeam doesn't provide Parts List manuals like some other mixer brands, e.g.; Kitchenaid, so I can only suggest Option 1 or 2. I wish I could offer you more help. Hopefully this will help point you in the right direction. Howard - Burke, VA
If this solution has helped, please rate it, thanks! - hslincoln
Nov 30, 2009 | Sunbeam 2370 MixMaster Series Stand Mixer
Sunbeam Mixmaster is smoking from the motor.
I wouldn't turn it on again , if the switch is smoking then for all practical purpose;s the brush;s are nearly shot as well. I would look around the good will thrift shops or a Salvation Army Store you ;ll find a nice one there for less than a repair bill. You never know what you will find there. Have fun hunting.. DFD please rate me. Tku
Apr 11, 2009 | Sunbeam 200 Watts 2372 MixMaster Series...
Have a sunbeam heritage stand mixer model 2346-000.
Make sure the bowl is off to the side. I wouldn't get rid of a mixer just because the bowl doest't, if it's a good powerful mixer. There aren't many replacement parts available except directly from sunbeam. You need to get a replacement motor for the bowl turntable.
Jan 08, 2009 | Sunbeam Heritage 2346 Stand Mixer
I have an old sunbeam mixmaster that trips the safety switch
There are two probable causes for this. One is that the insulation in the motor has broken down. This is definitely an unsafe condition, and unless you are a motor repair specialist there is nothing you can do.
The other cause is an accumulation of graphite around the brush holders. Fixing this would require pulling down the motor and cleaning the graphite away. This usually happens with motors that have done a lot of work.
It is normal that by the time the brushes have worn so much that the dust causes shorting the motor needs to be serviced.
Read this to understand what is required to pull the motor down and to reset the speed control:
Just cleaning the motor housing out thoroughly may get the machine running. I make no guarantees though. If the motor insulation is failing the motor will remain unsafe.
Apr 24, 2008 | Sunbeam 275 Watts 2369 MixMaster Series...
Sunbeam 2350 Stand Mixer Logo
195 people viewed this question
Top Sunbeam Food Mixers Experts
Oloyede Monsuru
Oscar Netto
Oscar Netto
Are you a Sunbeam Food Mixer Expert? Answer questions, earn points and help others
