VitrA Aria Toilet with Round Bowl / Backsplash Tank Lid - White Logo
A
Anonymous Posted on Mar 22, 2013
Toilet continues to drip after flushing
Vitra 195420 model. Leaks water into bowl continuously after flushing
3 Related Answers
jpintore
  • 129 Answers
  • Posted on Sep 26, 2009
SOURCE: I have a dual flush vitrA and it leaks
You will need to replace the flapper in the tank, its very simple.
Anonymous
  • 33 Answers
  • Posted on Aug 02, 2010
SOURCE: VitrA dual flush toilet doesn't flush enough water
maybe by shortening the chain length on the flapper valve might help
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Feb 27, 2013
SOURCE: i have a 4.8 lt flush vitra toilet when i flush hardly any water goes in the bowal to clean the sides of paper
These new style toilets are this way by design. It is designed to use less water, thus helping the. Ecology and your water bill. In effect what is happening is that the trap is lower in the bowl , thus not letting the level of water be as high in the bowl. Now matter if you pour a gallon of water to try to fill it up, it will run out until it reaches that level in the bowl.
I have a 4.8 lt flush vitra toilet when i flush hardly any water goes in the bowal to clean the sides of paper
Toilet tank...leaking into bowl
rubber flapper in the center of the tank replace.
May 03, 2017 • Home
I have a new Kohler Toilet that has a different flushing system from other Toilets. It's about 1 year old now and I'm noticing a Drip noise on the 1st floor under this Toilet. It looks to me like the water...
Basically, if water is flowing out of the overflow tube, then water must be coming in...I would suggest that you check the intake valve, it is probably not shutting off completely when the float comes up to the prescribed level,and continues to leak some water into the tank. That is what the overflow tube is there for.
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
2helpful
Toilet bowl gurgles after flushing cycle
Sounds like your toilet is not vented properly. Possilbly something caught in the trap is causing it to syphon
Water drips into overflow valve after flushing
The purpose of the "Overflow" tube is to fill the toilet bowl. It should drip for a while. If it is continuously dripping there could be dirt or deposits on the ball **** valve. Shut off the water and dissasemble to see if there is deposits or perhaps a torn diaphragm.
Have a vitra dual flush toilet we have no water pressure when you flush the toilet
check to make sure the water level in your tank is sufficient, if not you'll need to ajust your float. otherwise your flapper is shutting too soon, you'll need to shut the water valve off and flush untill the water in the tank is gone, letting air back under the flapper slowing it's desent when submerged. then turn the water back on. if the problem continues repace the flapper.
Sep 19, 2009 • Home
Top VitrA Home Experts
ADMIN Andrew
ADMIN Andrew
Oscar Sta Ana Jr
Are you a VitrA Home Expert? Answer questions, earn points and help others
