Question about GE (PSS26MSRSS) Side by Side Refrigerator
12 yr old ge refrigerator leaks water on kitchen floor occassiona
The frig leaks water on floor but not all the time , could it be coming from defrost system and how do we fix or un clog
    President:
  • GE Master
  • 2,651 Answers
Common issue.....sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Mar 01, 2009
I have water on floor under refrigerator.There is no water supply line to this frig.
If the refrigerator is leaking water it's possible that the refrigerator has a clogged or freezing defrost drain. If the defrost drain freezes the defrost water will overflow the drain and drip down to the bottom of the compartment, If enough water accumulates in the bottom it can run out onto the floor.17 May 2013
SOLVED: Water leak in refrigerator? - Refrigerator - iFixit..or go to this link might help you as well....
water on floor under refrigerator Google Search
Oct 23, 2017 | Refrigerators
I have a kitchen aide frig, It has water under the freezer drawers, which is frozen. A couple times a week there is water on the floor. Don't know where the ice. Originates from.
Clogged / frozen defrost drain. Defrost water has no where to go so accumulates in bottom of freezer and then eventually out the door.
Aug 24, 2017 | Refrigerators
Water appearing on floor be side by side refrigerator
Check drain line in the bottom of the freezer, clean and defrost the drain, run hot water until appears in the drain pan under the frig.
Jun 29, 2015 | GE Profile PSW26P Stainless Steel Side by...
GE Monogram bottom freezer leaking water from left side onto the freezer floor and onto hardwood floor of the kitchen . Already tried totally defrosting freezer and that did not solve problem. Help!!
ck the drain in the back of freezer . it may be pluged and when it goes into defrost cycle you get about a cup of water on the floor . if there ice on bottom of freezer then the drain is iced over . some models require a drain heater to prevent this . mm hope this helps ..
Oct 14, 2010 | GE Monogram ZICS360NR Bottom Freezer...
My frig is leaking water all over the floor in front of it
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 28, 2010 | GE Refrigerators
Water leaks on the floor occassionly may happen during defrost GE Model TDC18PAAWW
Hi,Before jumping to conclusions about why your refrigerator is leaking, do a thorough inspection. Many times, it will be easy to see where the water is coming from and from that point deduce the problem. For instance, water leaking from the back is usually due to an ice maker issue, water from the side of the refrigerator is usually due to a faulty door or gasket, a leaking drain pan,a clogged defrost drain pan.
Thanks and good luck
Jun 03, 2010 | GE Profile Stainless Bottom-Freezer...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
I opened the door on this frig this morning and water poured out like a small river! It filled the frig, and leaked below into the basement. Horrible! I noticed the water streaming out of the built-in...
obviously a filter leak. the water shuts off when the filter is removed. either it wasn't installed properly or it has a bad gasket. as for the fridge getting warm, the water probably collected and froze to the evaporator coils and now resrticts the cold air flow. you need to turn off the fridge, empty it out, leave the freezer door open, and let the coils defrost on their own. or remove the back panel in the freezer and defrost the coils with a hair dryer. you will need to soak up some water, but not nearly as much. once it's defrosted, dry it out, close the doors and turn it on while it's empty. when it's cold enough, replace the food.
Jul 31, 2009 | GE Profile PSC23MGTBB Counter Depth Side...
10 yr old GE side by side: freezer is leaking
Your drain is frozen up and so every time unit goes into defrost the water refreezes in the freezer's bottom. You either have to shut fridge off completely and let it dethaw or use hot water and an ice pick to hurry up the process. The drain is located in the very back of freezer. You will have to pull out the bottom drawer to see it. Good luck
Jun 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
235 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
