Question about Microsoft Wireless Controller for Xbox 360 (Blue)
Controller connects but after a few moments it disconnects keeps flashing green, sometimes it connects again and sometimes it just keeps flashing green.........any solutions??
    Problem Solver:
  • 8 Answers
You have to use a rechargeable battery pack,for some reason those blue controllers and the legendary need the packs or they wont work right regular batterys dont do it even new lithiums wont work.
Posted on Mar 01, 2009
P1102 reser counter
  • I take it you are refilling the toner cartridge...
  • Switch the printer off.
  • Press and hold the green button on your printer and turn the printer on. You will see that the lights flash for a moment and then turn off. After a few seconds, the attention light will turn on followed by ready light and the green light. Keep pressing the green button. In a few seconds, the attention light and the ready light will turn off.
  • Push the toner rotate button while you continue pressing the green button. As you briefly push the toner button, you will see the light flashing. Release both the toner button and the green button.
  • Repeatedly push the red button (cancel button). Now all the working lights on the printer will turn off.
  • Open and close the lid of HP printer once. The light will start blinking.
  • Press the green button. Your HP toner cartridge chip will be reset.
  • Apr 25, 2014 | HEWLETT-PACKARD Hewlett Packard P1102...
    Invacare MKIV R11 Flashing lights
    One of the most common controllers, codes to help you and others.
    VSI & VR2 Joystick error flash codes:
    1 RED BAR:
    Low Battery Voltage The battery is flat (more likely).
    Or the battery has a bad connection (which is unlikely)
    2 RED BARS: Left Motor Disconnected The left motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
    3 RED BARS: Left Motor Wiring Trip The left motors wiring has a short circuit. Check all connections and leads for wear and chafing between the left motor and the battery cables or chassis
    4 BARS: Right Motor Disconnected The right motor is disconnected. Check all the connections for physical disconnection or corrosion or burning usually caused by the salt poured onto the roads every winter.
    5 BARS: Right Motor Wiring Trip The right motors wiring has a short circuit. Check all connections and leads for wear and chafing between the right motor and the battery cables or chassis
    6 BARS: Activated if you turn on your wheelchair with an external device like the Charger still connected.
    7 BARS: Possible Joystick Trip, Make sure that the joystick is in the centre position before switching on. If you still get this when switching on then joystick is probably faulty.
    8 BARS: A control system trip. Make sure that all connections are secure and if so the power module or control pod is probably faulty. Test by substitution of known good one.
    9 BARS: The parking brakes have a bad connection or have a failed solenoid, or any lever or switches that disconnect drive for pushing the chair manually may be pulled or switched.
    10 BARS: Over voltage detected. This can happen with a bad battery connection although unlikely. More likely your battery charger is faulty and is overcharging your batteries quite severely.
    1 BAR to 10 BARS and back in a "ripple" every few seconds. Joystick not cantered when turned on. Switch off and try again.
    1 BAR to 6 FLASH every few seconds. System Asleep. Switch off and back on. Time before sleep can be adjusted or disabled in programming
    Hope this helps, If so please click the "Yes" button
    Regards, Mark.
    Jul 12, 2012 | Invacare Pronto M51 Power Wheelchair
    When I turn on the TV, the DVD player has always made a sound as though it was being activated. It would cycle for a few moments (like it was looking for the DVD) and then the sound would stop. But...
    You kneed to replace the DVD Deck. Very easy, just a couple of screws on the side and pull the deck out. When you pull the deck out, if there is a cable connected to it, you will need to take the back off and disconnect the cable. Some models have it and some don't.
    Jul 20, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
    I was watching a movie on my denon avr-3808ci and all of a sudden it made a loud sound and it shut off. The power button was flashing red and wne I tried to turn it on, the power button would turn green...
    probably one of your speakers has blown.. disconnect them all. turn the reciever on.
    if this works turn it off connect one speaker and turn it on.. keep going until it goes red...
    when you find the speaker discennect all the other speakers keep this one connected and confirm that it is this speaker giving issues.
    if the amp doesn't come on with all speakers disconnected, remove the visual outs and start it with nothing connected. isolate the issue if this works. otherwise it might be your amp.
    Oct 24, 2010 | Denon AVR 3808Ci Receiver
    I need to know how to reset my printer, I 've cleaned the pads, but nothing... Thank you in advance...
    Power down the Canon Pixma IP4300. Once it has shut down, leave it off for a few moments.
    Hold down both the "Resume" button and the "Power Button." When the printer begins to restart, release the "Resume" button but continue pressing "Power."
    Push in the "Resume" button twice, then let go of both the buttons. In a moment, a green light flashes a few times.
    Press the "Resume" button four times once the green flashing has finished.
    Push the "Power" button again until the printer shuts down. Wait a few seconds, then press the power button again to restart the device. The Canon Pixma IP4300 will now function properly. for more information http://www.fixyourownprinter.com/forums/printer/67824 hope this helps you.
    Aug 18, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
    Controller will start up the 360, then just flashes. Wont respond
    Remove the batteries from the controller for a few minutes to reset it then try again.
    Jun 03, 2009 | Microsoft Xbox 360 Controller
    Controller NOT Working Properly
    I just came home to find this same problem. Four blinking lights on the wireless controller and the inability to sync the controller with my 360. On a whim I took out my controller's battery and then reinserted it after a few seconds. Voila! Problem solved. Controller works normally again!
    Jan 22, 2009 | Microsoft Xbox 360 Controller
    Tv cuts off and green light flashes
    Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
    Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
    Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
    Wireless controller
    I dont know if you have been able to figure out what the proble was with your 360, but the exact SAME thing happened to me. The 360 seems to be working fine, game loads, and both the consoles and the controllers rings lit up green, but then the controllers ring just keeps flashing and the console won't recognize it. I 've tried other controllers and nothing worked and obviously I tried to synch it with the console time and time again. PLEASE HELP!!!
    Apr 03, 2008 | Microsoft Xbox 360 Console
    Microsoft Wireless Controller for Xbox 360 (Blue) Logo
    87 people viewed this question
    Top Microsoft Video Game Consoles & Games Experts
    Tre Elkins
    Martin Murray
    Stu Morris K
    Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
