Question about Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200)
Trouble with paradyne or linksys
I have 3 computers to start i have a paradyne modem that has 1 usb port and 1 ethernet port my first computer is hooked up using the usb port than i have a vonage phone service so i have it hooked up from the paradyne the ethernet cord to the vonage box for phone service than from vonage box to a linksys router with 4 ports for ethernet and the other 2 computers are hooked into the linksyswhen i had 2 computers i didnt need the router but with 3rd one i did. my problem is when all 3 computers are being used it slows down or wont let online some of the computers. what have i done wrong with hook up? all the lights work on all 3 components but it just slows down or wont work.the 2nd part of my question is i would like to take the computer thats hooked to the usb port and go wireless its all set up for it but dont know how?the other 2 are not set for wireless is this posible?not very computer hook up savy so im lost. any help is appreciated.
  • 371 Answers
Just saw your post, so please accept my apologies for being almost a month late in responding, as I only joined this service on March 26th.
1. When a modem has both usb and ethernet, only ONE of the two should be used as most isp modems will allow one or the other.
2. Your Vonage should be discreet and not intermingled with the rest of your system. It would be better to connect the Vonage to a router, and not the router to the Vonage. iow, do not connect the Vonage modem between the isp's modem and your router.
3. denigration of service or slowdown is typical with VOIP if more than 2 systems whether telephone or other systems are connected, due to the ringer voltage splitting that occurs when you put more units on the Vonage, or any other Voip modem. One ISP solves this by providing separate outputs for Voip and Ethernet.
Observation of these rules should speed up your system.
Posted on Mar 29, 2009
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Linksys b router not getting internet from modem, why?
Did it *EVER* work, or is this a "first-time" setup problem?
1. You need a "straight-through" Ethernet cable between the WAN (not LAN) port on the router to your modem.
2. You need a _working_ Ethernet cable between the modem and the router.
3. You need to turn the modem on.
4. You need to turn the router on.
5. You need to connect your PC to the router, and access the router's built-in web-server, and then view the router's "WAN-status" web-page. While on that page, click 'Renew IP address".
Apr 16, 2010 | Zhone Paradyne 6388-A1-200 Router
How do i reconnect linksys
Oh man your going to have to help me out a little on this one. Do you mean you had to unhook it and connect directly to the modem and now you want to hook the router back up? If thats the case Unplug all the devices (Pc's modem and router) connect an Ethernet cable from the ethernet port on the back of the modem (not the linksys) to the internet ethernet port on the linksys (usually set a little apart from the rest) then connect all the computers to the routers ethernet ports (usually labeled 1-4) then turn on power to the devices starting with the modem, wait for it to completely boot up all the lights like they're supossed to look. Then turn on the router and wait for that to finish booting up then all of the computers. If you have wireless devices that will take a little more help.
Mar 26, 2009 | Linksys Wireless-G WRT54G Router
Connecting a linksys wrt54g to a netopia modem
Is this an ISDN modem?
Generally: Netopia Ethernet out -> Linksys WAN port with a standard ethernet cable.
(Not the yellow LAN ports! - They are for your computers/printers.)
Dec 28, 2008 | Linksys Wireless-G WRT54GS Router...
MY LINKSYS WRT54G WONT READ MY COMPUTERS INTERNET CONNECTION
Ok to start the yellow ethernet port should be connected straight to the Linksys router in the ethernet in port. Then you connect the cmputer to one of the other the 4 ports on the back of the wireless router. wala you shouldn't have any more trouble after that.
Dec 03, 2008 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
How to install a linksys router to my desk top for my wireless laptop
1. plug in the router
2. connect the router to your DSL or Cable Modem using the supplied ethernet cable
3. connect the router to your computers ehternet port with a second piece of ethernet cable
you can use catagory 5 ethernet cable , or catagory 6
Most linksys routers have 4 to 5 ethernet ports to connect computers to.
One of the ports will be marked as the one to connect to your DSL or Cable Modem
Usually when looking at the back of the router the WAN port will be located to the far left.
Thank you for choosing FixYa!
Az.
Sep 19, 2008 | Computers & Internet
Setting up linksys adsl2 modem
The ADSL, Ethernet, and USB ports are located at the back of a Linksys modem. These ports are where the phone cable and computer will be connected. The ADSL Line should be connected to the ADSL port and the computer either be connected to Ethernet or the USB port., If u r using a ethernet cable no need to run the setup cd just connect the ethernet cable and contact ur isp..
do not worry about ur sagem modem, let it be inside.. just connect ethernet cables alone..
To setup a Linksys ADSL Modem with usb cable you need to perform two steps:
  1. Connecting the Devices Together
  2. Installing the USB Driver
Step 1:
Connect the phone cable to the wall jack with ADSL service and then connect the other end to the ADSL port of the modem.
Step 2:
Make sure the power adapter is plugged to an available power outlet.
Step 3:
Connect the USB to the USB port on the back of the modem and then connect the other end top the USB port of the computer.
Step 4:
Power on the modem. After connecting the device together, install the USB driver. For instructions, follow the steps below.
Step 1:
Power on the computer.
Step 2:
When the Hardware Update Wizard window appears. Click Install the software automatically (Recommended).
NOTE: Windows XP has pre-installed drivers for the ADSL2MUE and will automatically install the USB driver for the modem.
Step 3:
Click Finish.
Nov 06, 2007 | Computers & Internet
Paradyne 6381 ADSL2+/ReachDSL Router (6381A3200) Logo
245 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
