Question about Sony VAIO PCV-RZ40C1B PC Desktop
Replace dvd drive need sata adapter - Sony VAIO PCV-RZ40C1B PC Desktop
  • 523 Answers
Replace DVD drive doesnot need Sata adapter, check your dvd and your board if they are compitatble, if your dvd is sata and your board use sata too, you just need sata cable + the dc cable comes from power supply.
Regards
Posted on Mar 01, 2009
Can I use an internal SATA DVD+RW drive with the HP DC5100 ?
Hi as long you have sata connector in your pc you can swap cd with hdd or any other device that use that type connector. Regards
Oct 11, 2012 | HP Compaq dc5100 Small Form Factor PC...
Pegatron M2N78-la
Go here and select the operating system you are using and download the "Chipset Driver" and install it:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=4120567&
Also, recheck the connections to the drives, both power and ide or sata.
Jun 03, 2012 | HP Pavilion p6313w -24058
How do you install an lg gh24ls70 dvd rewriter into a compaq presario computer runnining windows xp that is 8 years old
If it's a sata connection on the drive you may not have any sata sockets on the motherboard. You will need something like an IDE to Sata adapter like this one: Adapter.
Feb 18, 2012 | LG Computers & Internet
I want to install a CD/DVD RW drive. This is in addition to the installed CD/DVD already in place. The new drive has a SATA connection on the back, and the only available connector is an IDE connector....
There are IDE to SATA adapters and cables, such as this one linked below. IDE to SATA Adapter
You would simply plug this adapter into the available IDE connection on your motherboard, then use the SATA data and power cable to connect from the adapter to the CD/DVD drive. You can look around online for similar products, but they should get the job done!
Mar 05, 2011 | HP (REFURB) HP XW4200 XPP P4 3.4GHZ 80GB...
Can my CD-RW/DVD Rom Drive, model # GCC4320B be replaced with a hp 24x Multiformat DVD/CD Writer, dvd 1270i . I bought this unit today, but the connections don't match up? I truely appreciate your time and...
This model DVD/CD writer is a SATA drive and unless your motherboard has a SATA connector then you have a slight problem. You will need to purchase a SATA controller and install it into your PCI expansion slot, then connect your new DVD/CD drive to this SATA controller. You will also need a SATA adapter power cable converter which plugs into the 4 pin power connector.
Feb 08, 2011 | HP (350208-001) CD-RW/DVD-ROM (Combo)...
Can I put internal LG GH22 rewriter inside external GSA-E60N
First, open the external casing.
You'll find an "internal" CD/DVD drive, connected to an adapter, and the adapter connects to the USB cable.
Now, look at the adapter -- it could be a "parallel-ATA" interface, or it could be a "SATA" interface. The new CD/DVD drive will have to have the same connectors (data and power) as the adapter.
You might have to exchange the SATA device for a Parallel-ATA device.
If you have a parallel-ATA CD/DVD drive, look at the back of it.
There is a tiny jumper, and a few labelled settings:
* MA(ster)
* SL(ave)
* C(able)S(elect)
Move the jumper to the 'MA' setting, so that the USB-adapter will recognize the CD/DVD drive.
Connect the drive to the adapter.
Close the case.
You're good to go!
Jul 22, 2010 | LG Dvd Rewriter Gsa-e60n 20x Ext Black...
Install IDE devices (drives / DVD / CDROM) sata
IDE devices have different "data" and "power" connectors than SATA drives.
So, you need a motherboard with IDE connectors, if you wish to connect an IDE disk-drive (or CD/DVD), and you need a motherboard with SATA connectors, if you wish to connect a SATA device.
Similarly, the connectors on the power-supply must be compatible with the sockets on the disk-drive (or CD/DVD) drives, so that the devices can get power.
You could possibly purchase a short IDE-to-SATA power-adapter, if you have a SATA device, but there are no SATA power-connectors on your power-supply.
May 29, 2010 | Intel Motherboard
Need adapters for SATA connectors
you can buy a sata to ide adapter,you plug this into an ide slot and it makes it sata.
here is an example:SATA to IDE Converter Driver
http://www.dealextreme.com/details.dx/sku.706
Dec 26, 2009 | Dell DVD-ROM for Dimension (6t903)...
Gear Head Lightscribe 24x DVD+/-R Triple Format SATA
Your original CDROM drive is likely an IDE interface (large rectangular connector), where as the new one is a SATA interface (small narrow connector). If your original is an IDE, the simplest solution is to return the SATA and purchase an IDE DVD.
Oct 26, 2009 | Gear Head 8XDVDEXT DVD External Slim...
Recognizing my sata DVD writer in bios mode
How about a work-around?
(Your post is so old now that you probably figured out a solution . . . so this is for other readers)
I have the exact same motherboard, and a SIMILAR problem.
I have a PATA CD/DVD drive . . . so no problem there.
But I have a SATA hard drive, and the BIOS does NOT see it.
So when I boot from the WinXP CD, that is fine,
but then the install process claims I have no hard drive!
So how can I reinstall WinXP to a hard drive that doesn't exist yet?
Solution that didn't work:
So I knew the ASUS SATA driver (embedded in their RAID driver) needed to be loaded,
and TRUE, the WinXP install process gave me the opportunity (via F6 key) to install any
additional driver for a mass storage device. Great! So, with the latest driver on the floppy
from ASUS using their "MakeDisk" utility, I let the Windows install process read in the driver.
Well, it made the hard disk visible to the installation . . . sort of . . . but then it took me
to the Recovery Console (which I didn't want or need) rather than the Repair Install process
(and there was no "R" option available to initiate the Repair). So, gave up on that!
Solution that I think is sure to work:
Go to Ebay, and buy from Hong Kong a PATA to SATA adapter for about $7.50 including shipping. It is a great deal! And customer ratings gave HIGH marks, so the seller is trustworthy.
Make sure not to buy the SATA to PATA (the other direction), and also, I'd suggest buying the
version in which the little adapter card plugs directly (without a cable) into the PATA socket
on the motherboard, and then plug the SATA cable from it to the SATA hard drive (or the
SATA CD/DVD drive in your case). Connect the power jacks as needed. And presto!
You have converted the PATA interface to a SATA interface which needs no SATA driver!
The BIOS will see the SATA drive as a PATA drive (how clever!). After doing the WinXP
install or whatever, switch back to the way things were and save your adapter card for next time.
Sep 06, 2008 | ASUS P4S800D-X Motherboard
Sony VAIO PCV-RZ40C1B PC Desktop Logo
120 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
