Question about HP Compaq Business Notebook nc4000
HP Laptop Screen Brightness Cannot Be Changed
I have an HP dv6129us laptop. The brightness is sufficient but cannot be changed upwards or downwards. I have used the fn-f7 and fn-f8 keys combination and also searched in the Contol Panel / Display / Properties icon. Do I have a hardware problem?
  • suw2 Mar 01, 2009
    I downloaded and installed from HP an updated Quick Launch Buttons Software. It did not help to change the brightness of the screen. Each time I tried the conbo keys of fn-f7 and fn-f8, it just gives me a small screen of my System Information identifying 5 pieces of information.
  • 2,653 Answers
You probably just need to download the hotkey software.
Your is HERE.
Download, install, and let us know what happens.
If that doesn't work we'll try something else.
Posted on Mar 01, 2009
How do I turn down brightness on my hp Windows 7 computer?
Below are instructions to adjust brightness on HP laptop
    • Press the "Fn" key with the computer turned on and hold the key.
    • Press the "F7" or "F8" key on some HP laptops, which are printed with a small sun icon on the key. The sun icon is filled on the function key for dimming the laptop. The other key is printed with a hollow sun icon for brightening the screen.
    • Press the "Fn" and left arrow keys together on some HP laptops to turn down the brightness. The "Fn" and right arrow key will increase brightness. Press and release the right arrow key repeatedly, while holding down "Fn," to decrease the screen brightness slowly, or hold the keys to darken the screen as low as the setting will go.
  1. For HP Monitors
    • Press and hold the down arrow key on the front panel of the monitor below the screen to turn down the brightness on the external monitor to the lowest setting.
    • Repeatedly press the down arrow button to dim the monitor gradually.
    • Press the up arrow key on the monitor to increase brightness.
Jul 15, 2013 | Computers & Internet
My hp mini 210-1000 boots up well both on battery and adapter but it displays faintly on battery while it display well on power adapter
the problem is that its set in the power saving options. i mean on battery its set to power saver . while on power adapter it changes to hp recomended or high perfomance. So if you want to change it go to the right bottom of your screen and click the battery symbol it should give you the option to 1> change screen brightness 2>more power options. Go to more power options and select "change plan settings" beside the power saver.(not the one beside the other options) and change ur brightness. but its always better to keep it at ur minimum(with what ur comfortable) as its helpful to save battery
Jan 10, 2013 | HP Mini 1000 Netbook
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
My laptop display very dim
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
1. Right-click on an empty space on the desktop and a drop-down menu will appear.
2. Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
3. On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
4. Click on the arrow beside "Show color mixer."
5. Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
I hope you find it very helpful. Thank you for using fixya.
Best regards.
Aug 15, 2011 | HP G62144DX Laptop
How do I turn up the brightness on a HP Probook 6550b?
go to the search icon under start. search brightness. it will tell you step by step what to do.
Every laptop is different, so adjusting the brightness or contrast on your laptop may vary from the steps provided on this page. However, understanding the process of how to adjust the brightness or contrast will help you change your settings.
Most laptops adjust their brightness and other settings using the function key in conjunction with another key. For example, pressing and holding the function key (abbreviated as "Fn") and pressing the up or down arrow keys as shown in the picture below, increases and decreases the brightness.
May 09, 2011 | HEWLETT-PACKARD HP ProBook 6550b Notebook
Laptop screen produces image, but there is no illumination
The screen brightness may be too low. That may happen in certain power regimes ( when used on battery power, presentation, etc.)
Here is how to change screen brightness on a Toshiba satellite that has the Toshiba Power saver software installed
Go to the Control panel, Click Toshiba Power Saver ( icon has two hands praying?) and increase the screen brightness. in each of the different regimes provided : Full power, High Power, Normal, DVD Playback and so on.
Hope it restores your computer screen to light.
Once finished, press the apply button
Aug 26, 2009 | Toshiba Satellite A105 Notebook
The screen on our Dell Inspiron 1545 is darker than normal. It looks like it does when it is running on just the battery. How do we lighten it back up?
Actually it's the F5 key which also has a symbol of the sun on it and arrow pointing upward. Press the blue Fn key located at the bottom row, 2nd from the left and the F5 key together to increase brightness or the F4 key to decrease the brightness (it has an arrow pointing downward). Easy, eh?
Aug 08, 2009 | Computers & Internet
When HP laptop is pluged into power source screen goes dim
Right click on the battery icon in the taskbar, go to Power Options or something similiar. Change the plan settings for the power plan you're currently in. Check the brightness ratio for both battery and plugged in mode. This problem might come if you or someone had tinkered with the settings.
Jun 20, 2009 | HP Pavilion dv6000z Notebook
Xps screen brightness low
Press F2 at start up to go into the bios. There is another setting in the bios for the screen brightness while on battery power.
Jul 14, 2008 | Dell XPS M1530 Laptop
My screen brightness
Pressing the function and the brightness key simultaneously. it should brighten up the screen.
function key is located in the lower left of the keyboard and the brightness key is located on the upper right of the keyboard.
hope this helps.
Apr 05, 2008 | IBM ThinkPad T60 Notebook
HP Compaq Business Notebook nc4000 Logo
314 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
