Question about Sonic Impact 5090 Video-55 LCD Video and Speaker Dock Docking Station for iPod Video
I need to know what type of AC adapter goes with this unit.
I have lost the AC adapter that goes with this unit, but I have a universal unit that i could use if i new DC output is supposed to be.
  • 3 Answers
The adapter specs are - Model # FM090020-US (which translates to 9.0 volts 2.0 Amps) with a center pin positive / outer shield negative connection. Probably most any adapter that meets these specs should work. You would need to have the correct size connector installed fo rit to work correctly. You may be able to find an exact match on E-Bay.
Posted on Sep 13, 2009
Need AC power cord for task force model 202754 tire inflator
This a battery jump pack that is used to jump start a car. Some units have an ac adapter built in so you can charge the battery in the jump start pack. My unit has a spot to connect the ac adapter to the jump pack so you can charge the battery in the jump pack. My ac adapter has been lost. I know I have to buy a new ac adapter so I can charge my jump pack, what I do not know is if the input (from the ac adapter) is 120v 60 hz
I understand that the DC output needs to dc12v. I do not understand the milliamps. The battery in the jump box is 12v 10 ah ( what ever that is). I just want a new ac adapter to charge the jump pack with that is not going to damage anything.
Oct 19, 2017 | AC Cars & Trucks
Where can I find an ac adapter for this monitor
You have not mentioned the make/model of the monitor. However there are several universal types and all what is required is to correct the connection pins and the polarity once the voltage are known which can be found in universal types.
Dec 17, 2011 | Fuji FP-768 17" Flat Panel LCD Monitor
My digitech rp 500 has power supply but it won't
Make sure you have the OFFICIAL Digitech power adapter. Universal adapters or those for MOST other pedals will NOT work... things may light up but you will NOT get audio. This unit requires an adapter supplying 9 VAC (not DC) at about 1 amp. These AC output adapters are not very common and people get the units without an adapter and try using universal adapters and they do not work. An AC adapter is used by Digitech so they can generate both plus and minus voltages internally. I don't know what your utility power voltage is in Cebu, so you need to get an adapter for your voltage that will give 9 VAC output and fit the power jack on the unit.
Sep 15, 2011 | Digidesign Digitech Control 2 pedal for...
HI, unfortunately I lost the power adapter of my Gemini FX 7000. I want to replace it with a universal power adapter with the accurate voltage but the connector is quite weird for a power supply (RJ 45)...
Don't even think of using a universal adapter !!! I could not find the schematic of this unit, but other Gemini mixers like this use center tapped AC power transformers. Any universal adapter will be DC, not AC. I have found that the FX7000 indeed uses an 18 VAC adapter... Try this as a source:
http://www.topdjgear.com/gemini-110vac18v.html
Jul 05, 2011 | Gemini Sound Products Gemini FX7000 10...
Lost my charger need to charge from internet
Laptop chargers also be called as power adapter, AC adapter or DC adapterCheap Laptop Charger online for UK For US: laptop AC adapter & laptop DC adapter You can use universal laptop AC adapter too.
Apr 29, 2011 | Computers & Internet
I have a alesis dm5 drum module. I have lost the power supply so I bought a universal power supply buti dont want to harm the system. How do i set the power supply up?
NEVER use a universal wall wart supply... it is too easy for the settings to be changed and blow the unit.
It appears that the correct power adapter supplies 9 volts AC at 1 amp (1000 ma)
Most universal adapters supply DC rather than AC.
There are sellers on eBay selling the correct adapters.
Jun 14, 2010 | Computers & Internet
AC Adapter
Ususally the model number s located in the battery compartment or on the bottom of the player.  Check ebay for an adapter.  Usually you can find an adapter that is universal for all durabrand dvd players.
Jan 06, 2009 | Durabrand PDV-709
I lost my ac adapter for Sharp Actius A250 PC Notebook
office depot / neighborhood computer stores /mite try ebay or just typeing in search engine for sharp actuis cheap power cord ...lala linda
Jun 05, 2008 | Sharp Actius A250 Notebook
MVBG45
Go to Radio Shack with your DVD player and manual if possible. They need to know the voltage and weather it is ac or dc. Radio Shack handles all types of charges ( ac adapter ), and will have the one you need.
Jan 26, 2008 | Liquid Video MVBG45 Portable DVD Player
Sonic Impact 5090 Video-55 LCD Video and Speaker Dock Docking Station for iPod Video  Logo
329 people viewed this question
Top Sonic Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Martin Murray
 Grubhead
Grubhead
Are you a Sonic Audio Player and Recorder Expert? Answer questions, earn points and help others
