Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Agitator on Whirlpool Ultimate Care II won't agitate
This machine is at least 10 years old, model LSQ8243HQO. For some time the agitator has made noise, has probably been the cause of numerous torn clothing and now will only stop & start as it travels clockwise. The only way we can make it agitate is to push down on the center of the softener dispenser. Queston: Does it look like replacement is the prudent option or might it be repaired for less than 1/2 the price of a new one ?
  • deartyler Mar 01, 2009
    Dear aborcass,
    Thanks very much for your suggestion. I'm absolutely sure you know what to do in this case. However I got another answer from elsewhere on the internet. In that case they suggested I buy a repair kit "ap3094543 at www.appliancepartspro.com. Is this the same as your suggestion to buy agitator dogs, part #80040? I'd be grateful for any comments from you.
    Thanks, deartyler
    Thanks for helping out. Beats the heck out of a new $700 washer. I bought the agitator repair kit for $19 iincluding frt.
    Deartyler
    President:
  • Whirlpool Master
  • 2,651 Answers
You can replacethe gears taht cause the agittion called agitator dogs part number 80040, probly $20.. reomveth efabric softener( swift smack with thepalm of you hand) and then remove the agititor with a 7/16 screw down the center shaft. the agitator will "split to reveal the "dogs" fairly easy repair
Posted on Mar 01, 2009
  • Ron Coons
    Ron Coons Mar 01, 2009
    yea thats better repair kit as a matter of fact, for that includes the holder(yellow piece) as well as the 80040agitator dogs that i reccomended , sometimes handy when reassembling the agitator.. as a matter of fact i will now reccomendthat part number for future repair requests of same issue, thankyou!!
I have a Whirlpool washer... model number # LSQ8243HQO The top part of the agitator is loose. The bottom part is strong. I think I need what they call dog ear replacements. Can you help me?
yes sounds like the dogs to me.
to replace them,remove the cap at the top off of the top of agitator by pulling it up (no tools required) then remove the clear plastic cover by pulling on one of the two tabs in it,remove the bolts using 7/16" socket and pull the agotator out of the machine by gripping it at the bottem.seperate the upper portion of agitator by pulling it upand the dogs will be located under the clear plastic,to replace them seperate the top barrel of agitator a cam that holds all (4) dogs will come out remove the retainer over the dogs install new ones and reassamble in the line up upper barrel and main agitator you will (2) tabs on main agi. and (2) corosponding slots on barrel line them up and snap in place
Jul 14, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool ultimate care II, Top agitator not working. I got it apart and can see the agitator dog gear not catching, unable to free the gear from the clips. Suggestions?
stand on agitator,pull top section upwards,the agitators are meant to be disassembled this way,sometimes they are stubborn,and you cannot service agitator if agit is still in the machine...
Mar 09, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
How to separate auger from agitator. whirlpool ultimate care II
When you look down into the agitator, are there 4 white plastic points that look slightly melted or otherwise deformed? If so, using a small flat head screw and a small hammer, separate the white plastic from the surrounding translucent plastic. Once you've done that, it should easily pull apart.
Jan 03, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
I put a down comforter in my Whirlpool Ultimate Care II washing machine (I have done this at least 50 times). Last time, it got hung up around the agitator and started making a funny sound. The agitator...
Pull the agitator off and check the plastic drive hub at the top of the agitator shaft. It should not be split, or have it's internal splines sheared off. If this all looks ok, then likely transmission problems or a slipping drive belt (motor to transmission). Good luck!
Jul 12, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II top of agitator don't agitate.
This problem is caused by worn agitator dogs. The following link explains how to replace them:
http://www.fixya.com/support/r823955-replacing_agitator_dogs
The upper portion of the agitator you mention is called the "auger". The small teflon dogs have teeth on them and act as a clutch to drive the auger when the agitator is in motion. The teeth wear out and become smooth, causing the auger to slip. The replacment part number is included in the link I provided. You can choose to order on line at searspartsdirect.com, appliancepartspros.com or repairclinic.com. All three sites offer competitive pricing, so shop all three for the best price. If you do not wish to shop online, take the part number provided to your nearest appliance parts retailer. This is a common part, they should have in their inventory.
I hope you find this information helpful. Let me know if you have further questions.
Apr 12, 2009 | Whirlpool Washing Machines
Whirlpool ultimate care II super capacity plus ser.# LSQ8243HQO The top half of adjitator is not turning at all. Handiman1125@aol.com
If the bottom half of the agitator is turning and the spin cycle works, then the motor coupling is good.
Check the agitator by turning it back and forth. It should work like a ratchet (turns one way, locks the other way). If you're able to turn it in both directions, the agitator dogs are worn and need to be replaced. To do this remove the agitator cap and the bolt that holds down the agitator. With the bolt out you can remove the top section of the agitator (auger) where you should see 4 small white or beige plastic gears (dogs). Replace those and it should be ok.
The part number is 80040.
If it there is no agitation or spin, replace the motor coupling.
The part number is 285753A
Mar 13, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The agitator does't work on the Whirlpool Utimate II & this washer is about 7-8 years old
You must replace the agitator dogs. Pop the top cover of the agitator to access the 4 defective parts. They are pear shaped.
Tools required.
Feb 20, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate care II Washer Agitator not turning
replace the dogs in the top portion of the agaitator, the agaitator top comes off and you will see the four dogs part number is 285707 about 3-5 dollars
Apr 16, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
838 people viewed this question
Dan Webster
Dan Webster
Sal De
