Question about Kenmore 24032\24036 Top Load Washer
I have to replace the lid switch (which I now
I have to replace the lid switch for my model 25842400 (which I now have) and have to remove the top of the washer (i think to do so). No instructions on how to replace with the new switch. any advice on how to proceed without damaging whole device?if not, any manuals I can consult. Nothing in the user manual to help.
  • ryanmcgough Mar 01, 2009
    great thanks. model number was 25842400
    President:
  • Kenmore Master
  • 2,651 Answers
Soory but was unable to pull up a model number, ill assume that you have a top loading washer, in which case you can search you tube-- "kenmore washer repair" . theres videos as to how to remve the cabinet. easy to do once youve seen it
Posted on Mar 01, 2009
How to remove washer lid to replace lid lock
Remove power to the unit.
Locate the console and remove two phillips head screws. Most
models have them in the front, bottom of the console. In some of the newer models they are located in the back, bottom of the console. Some washers require you to remove two end caps on the console to access the screws.
After you remove the two screws, slide the console slightly forward and then up. The console will then hinge to the back of the washer.
With the console now hinged back, locate the lid switch harness.
Disconnect the harness and check for resistance between the 2 grey wires (outside) on the lid switch connector connected to top of washer. With the lid down the circuit should read no resistance. If the circuit is open(infinite resistance) then the switch needs to be replaced. You can also use a insulated jumper on the lid switch harness to determine if its the switch.
To replace the lid switch you will now have to remove the cabinet. Use a flat head screwdriver to remove the two clips holding the back of the washer to the outer shell of the washer.
Disconnect the lid switch harness(If not still disconnected).
You can now pull the outer shell away from the washer. Do this by
grasping the outer shell (I open the lid and grab it there.) and tilt the shell forward (toward you) and out. The shell is now removed and you can see the tub. Be careful not to bend the outside walls of the shell when removing and setting aside. This will help greatly when reinstalling the shell. Remove the 2 screws attaching switch to cabinet. Remove the screw connecting the ground on the cabinet. Use a flat blade screwdriver to push tabs on lid switch connector block to remove. Finally remove the whole harness from the 2 remaining retainer clips under the cabinet. Install new lid switch harness assembly and reassemble washer.
Apr 09, 2014 | Washing Machines
Model # lat8826aae my washer doesnt work when i close the top load cover
open timer console and replace fuse can get from any hardware store
Jan 27, 2011 | Maytag Washing Machines
How to remove washer top for broken lid switch access
if it is a top loader,,,remove the screws in each end of the control panel,,,some units you have to remove the end caps to access the screws,,,then pull slightly forward on the panel and flip it back it is on hinges,,,,then remove the 2 clips that hold the back to the base,,,unplug the lid switch,,then open the lid and grab the inner lid section and pull the rear of the base towards you slightly and lift off the base,,,, then you can access the lid switch and replace it ,,,,
Apr 29, 2010 | Washing Machines
Replace lid switch
You will need to not only remove the control panel, but you will also need to remove the washer casing from the frame in order to acces the switch. It sounds intimidating, but really isn't that difficult to do. The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Your washer is manufactured by Whirpool, so these instructions will apply. Most commonly, the lid switch is located under the washer casing along the right hand side of the lid. If the model number you have this listed under is correct, your switch is under the washer casing near the right lid hinge. The mounting screw(s) and ground connector are under the operator console. For clarification, you can refer to pcappliancerepair.com for some excellent exploded view diagrams to assist you. The lid switch is located under the "Top and Cabinet Parts" heading.
If you have any questions about this repair, or need additional assistance, please let me know.
Sep 11, 2009 | KitchenAid KAWS850LE Top Load Washer
KENMORE 80 SERIES MODEL # 25842400
This often appears to a more serious problem than it really is. The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at searspartsdirect.com. Just type in your COMPLETE model number and look under the "Top and Cabinet" heading. The lid switch is listed as item number 11 (part #3949238) and the lid strike will be listed as item number 20 (part #350733). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
http://www.fixya.com/support/r385198-replacing_lid_switch
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can can more potential problems.
Oct 07, 2008 | Kenmore 24032\24036 Top Load Washer
I need to replace lid switch on Kenmore washer.
remove trims from edges of control panel
remove screws from under trims
rais and flip control panel over backwards(hinged at top) do not dislodge air hose to level sensor
remmove brass clips from washer body top, not position for reinstall
disconnect lid switch connector cable
lift and remove entire body
turn upsidie down
change switch
reassemble in reverse order
~20minutes
Oct 02, 2008 | Washing Machines
Replacing lid switch
someone, Im not finding that model number. Going by the first six digits Im assuming that this is a regular top loader and not an Oasis washer. If so, remove the end caps on the consol by pulling them off. Remove the screws under each end cap and flip the consol up. Unplug the lid switch connector and snap springs holding the cabinet on. The whole cabinet will pull forward and you can get at the lid switch. Check out the pics and post back...Catriver.
Apr 14, 2007 | Kenmore Oasis 27042 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
Sal De
fordexpert
Robert Rankin
