Question about GE WSXH208A Front Load Washer
GE ELECTRIC DRYER - WILL NOT COME ON.
OLDER MODEL. INHERITED DRYER. MODEL DDE9200GLAD
I CAN HEAR THE ELECTRIC STARTER HUMMING, BUT NOTHING HAPPENS. THE LIGHT COMES ON WHEN I OPEN THE DOOR BUT DRYER WILL NOT START. IS THERE A FUSE OR SOMETHING THAT MAY BE BLOWN?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    Have you checked to see if the belt is broken? (a broken belt allows idler arm to switch power off to drive motor) Also, some older models have a non-resetting safety thermo which can go out if you have a long or restricted vent. (the replacement thermo is an auto resetting one)
  • 478 Answers
Very often the problem is the resetable thermostat, if you open the top you'll find it on the back inside, you can test with an ohm meter or just bypass it to test it.
Posted on Mar 13, 2009
Dryer won't turn on
Is your dryer electric or gas. If electric, check your fuse box first thing. If it is an older model and your home has an older fuse box, and the boxes uses the big bullet type fuses for the 220 line, one or both fuses could be bad. If so, go buy two new fuses and give it a t;ry.
Aug 09, 2013 | GE DCVH515EF Electric Dryer
GE Dryer GFDN110ELWW hums loudly and won't start
The start capacitor is built into the motor and you will need to replace the motor. Here is the motor if you should need it.
Nov 24, 2012 | GE GFDN110ELWW Electric Dryer
GE Profile gas dryer, DPXB515, no heat and no drum spin
the humimg you hear is from the motor,check the blower wheel that is below the lint filter,if a sock or something gets sucked into the blower the motor can't spin,check the belt,if it is jamed the motor can't spin,if these things check good you have a bad motor
Nov 05, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
When i turn the on switch i hear a humming as if it is going to start but it does not. my dryer brand is Frigidaire FEQ 332 E s
Depending on the hum you hear (if you hear the sound and it keeps humming) the belt that connects the motor and the drum is probably broken.
If the hum only happens when you turn the on switch, the motor has probably failed.
Aug 31, 2009 | Frigidaire GLEQ642A Electric Dryer
Push the start button but nothing happens
check thermal fuse inside back of dryer usually little white fuse unplug and ohm out should ge a reading if good
Aug 09, 2009 | Whirlpool Dryers
Dryer won't spin, but heats up - belt is okay
the motor may have seized up, or the drum bearings are shot.
Jun 19, 2009 | GE DBL333EA Electric Dryer
Our ge microwave does not heat properly. No heat at all.
Greetings,
If you hear a humming noise that you never heard before. Its most likely the magnatron tube is bad. It could be another hi-voltage problem, but site unseen, most g/e are bad tubes...Bruce Denton
Mar 14, 2009 | GE DBSR453EBWW Electric Dryer
1-1/2 old dryer keeps stopping
could be a bad motor or timer contacts. can you hear a humming sound coming from the motor if you tried starting it again? if there is none, wait for about 5 mins and try starting it again, hear what happens?..
Feb 24, 2008 | GE DBXR463EBWW Electric Dryer
GE WSXH208A Front Load Washer Logo
143 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
