Question about HP DeskJet F380 All-In-One Printer
Cannot get the printer to print yahoo maps on my laptop. it will print a test page, but thats all i get.
  • 523 Answers
It's possible that your browser - Print button is not selecting your actual physical printer.
In your open Browser
Go to
File - Print -
then Select the correct Printer and be sure that it is marked as Default Printer
If that simple setting is correct, then it may be useful to uninstall and reinstall the printer drivers with the most updated drivers available for your operating system.
Best Regards
Posted on Mar 01, 2009
Pcl xl error subsystem kernel
Try to reload print driver.
Paul
Dec 25, 2013 | HP LaserJet 5000 Printer
All toner cardridges are at least 1/2 full but
in the printer menu, scroll to Special Pages and print a Config page, Menu Map and also the Test Pages. If these appear to print colour properly the problem may be in the driver. Check the quality tab in the preferences is not set to B/W. If the problem still appears to be with the printer after printing the internal pages then recheck after restarting the printer.
Dec 29, 2009 | Konica Minolta magicolor 5430 DL Laser...
Hp laserjet 3055 offline when print out via networking when direct to the laptop, its working fine.......
Go to reports print configuration page it will give to netwrok configuration page check if the printer IP Address is in the same range of the IP Address of the laptopn.
If yes than check if you are able to open web browser of the printer on lkaptop using IP address of the printer if yes in laptop go to printer driver properties there go in Ports Tab and check if the Standard TCP/IP Port has IP Address of the printer of some other IP Addressif it is different IP Address than change it to the IP Addess of the printer.
Thanks and Regards.
Apr 27, 2009 | HP LaserJet 4100 Printer
Printer Aborts during printing
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | HP PSC 1410 All-In-One InkJet Printer
HP psc 1310 printer autoprints a test page
the autoprint which you r telling is called allignment page which your printer is printing everytime.just when the printer prints that autoprint you take that autoprint and place the printed side of the paper on the scanner glass and press the scan button.the printer ON/RESUME light will blink for 1minute then automatically stop and then u will not get this autoprint till u replace any of the cartyridge from the printer.
Dec 15, 2008 | HP PSC 1315 All-In-One InkJet Printer
Lexmark won't print
good day,
have you tried highlighting the entire content of the Yahoo! page before you select print? this may be an issue between the internet browser that you are using and your printer.
Oct 13, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer won't print anything but a test page
Check printer settings. Also check windows setting for the printer. Also, be sure the printer is not offline.
Mar 05, 2017 | HP Office Equipment & Supplies
Toner all over the page with bubles
REPLACE THAT BAD RECYCLED TONER CARTRIDGE
Jun 18, 2008 | HP LaserJet 4350 Printer
Not printing maps/pictures
ok...what software are you using for the photos, and can that software see the printer, with proper drivers?
Feb 08, 2008 | HP DeskJet 9800 InkJet Printer
Hp psc1410 printer
If you are trying to print from a web page keep in mind that not everything that is on the web is able to be printed. I would look for a link which is usually found near the top of bottom of a web page that usually says something about printing the page. An example would be if you use google maps to get directions. In the corner of the directions it says Print. If you click that link it would open the actual link you can print from.
Aug 20, 2007 | HP PSC 1410v All-in-One Printer
HP DeskJet F380 All-In-One Printer Logo
Ben Johnson
