Question about Sega Dreamcast Console
Sega dreamcast wont play games
I power it up put them in but it doesnt recognize them as being in there no matter what I do.
  • Anonymous Apr 04, 2009
    I was playing my Dreamcast one day when, suddenly, it just froze on me and would never recognize my disks again!!! The game was Test Drive 6, but that probobly doesn't matter...Also at some points it doesn't even turn on...
    All I wanna do is play Sonic Adventure...*sniff*...
  • 2,653 Answers
Clean the laser using a dry q-tip with a circular motion.
If that doesn't work then watch this video.
Posted on Mar 01, 2009
I was given a sega dreamcast everything works but when it says install disc i put the disc on the wheel close the door and the cd wont stay on the wheel
If I recall the Sega Dreamcast wheel is a clasp type wheel. You need to push the disk down onto the wheel and you will hear it secure itself onto the wheel. Then close the wheel and you should be good to go. Don't just place it on the wheel... push it down until you here that little clicking sound and it should stay on the wheel.
Aug 10, 2011 | Sega Dreamcast Console
It will play music, but not the game. it keeps going back to a screen with four icons on it. It says game, music, memory and settings. Every time i back out of one, the disc starts spinning and a Sega...
Looks like your Dreamcast can't read the game properly either due to damaged disc or the dreamcast GD rom is not working properly. try recalibrating the GD rom using this guide:
Aug 28, 2010 | Sega Dreamcast Console
It will freeze in the middle of game play a some games not play
I believe your device is overheating, you need to make sure that the Dreamcast is well ventilated, don't set it on a carpet or enclosure. BLow any dust from the unit, pull the Dreamcast out of whatever nook it is sitting in, and set it on a flat surface like a hard cover book, etc. See if your issues resolve themselves.
Apr 08, 2010 | Sega Dreamcast Console
My control wont work
did you tested another dreamcast had the same you have to check the protection Fusistor inside your dreamcast conector controller seems like a blue or green normal resistor...marked as F1 on the board..change it with a simple fuse or an smd fusistor...Good Luck!
Nov 23, 2009 | Sega Dreamcast Console
Freezing problem with Games
The Dreamcast is no longer supported because it was to easy to copy the games, but there are still a loyal few who keep the scene alive. I have no idea how much you want to put into fixing the problem, but the only way to fix your problem is flashing the Dreamcast BIOS.
Modification 101:
The Dreamcast is basically a computer; with the right programming you can do anything; and having a Dreamcast Keyboard is nice.
Other links you should check out...
DreamChip and 4 in 1 Connector
Another Dreamcast Mod Chip
The Ultimate Dreamcast Survival Guide
Sega Dreamcast VGA Mod
Modified Dreamcast BIOS
Nov 27, 2008 | Sega Dreamcast Console
Some Dreamcast games won't play
oh that problem.. leave it coz some of the PAL games are really a trouble .. better leave them coz they wont work eventhough you try it a million times.. n.n
Aug 18, 2008 | Sega Dreamcast Console
Sega Dreamcast console problem
First off, NEVER store a game console on top of a subwoofer. It is like a giant magnet, and electronic devices do not handle magnetics. I don't think i've ever heard of a VGA box, Sega brand or not, killing a console. Millions use aftermarket AV cables and adaptors on all consoles without problem. I think it likely died from being on top of the sub. Relocate it and you should be fine. Running it for a few hours isnt likely either unless you had the vents entirely blocked.
To the guest who's drive isnt spinning, I would say your drive motor has burnt out. This doesn't indicate a defect in Dreamcasts, per se, it just means bad luck or excessive dust which killed it. Either buy a different Dreamcast or see if you can find a drive replacement.
Hope this helps.
Feb 28, 2008 | Sega Dreamcast Console
Dreamcast Loading problem
you can get disks relayered at game stores.
there was a long period where this happened to me.
some games worked for a while, some didnt.
its the dreamcast.
you might wanna get anew power cable or just clear out the dust because that is the main problem with the dreamcast.
try playing with the console upside down
it sounds crazy but it worked for me.
Dec 18, 2007 | Sega Dreamcast Console
Sega Dreamcast Console Logo
597 people viewed this question
Top Sega Video Game Consoles & Games Experts
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
