Question about Dell Latitude X1 Notebook
Dell Latitude X1 will not power up
The power supply seems to be fine, the battery does not charge, and the laptop will no longer boot up. somehow looks like something went wrong inside the laptop so that the external power does not get to the Laptop, nor to the battery to charge it. Is this a common error with the Dell Latitude X1?
  • Roelof Mar 01, 2009
    Tried both. Reseated the memory and tried to boot up with no battery installed. But still no reaction at all.
    Roelof
I had this problem just last week; the solution for my X1 was very simple. The problem was the power cord, which had worn out. The adapter was working, but the frayed cord never got the power to the computer. Before you try anything else, try replacing the power cord--it's cheap, easy, and may well work for you too! Good luck!
Posted on Dec 25, 2009
    President:
  • 2,653 Answers
This is a common problem for all laptops.
The issues you're experiencing all point towards a bad motherboard.
There is very little that you can do yourself other than trying to boot the computer with no battery and reseating the memory.
Try these two options first, write back, and then we'll proceed from there.
Posted on Mar 01, 2009
  • RescueTechLA
    RescueTechLA Mar 01, 2009
    If that's the case then it's a bad motherboard for sure.
    Not much you can do except to replace the board.
    That's always a bummer, sorry.
    Let me know if you have any other questions.
    Best of luck!
Pc booting light blinking battery
As a rule this indicates a low battery or a failing battery. If you charge it and it drains quickly, it needs replacement. When getting a new battery (power cells), fully charge it overnight and use it until it drains completely. Once it is recharged for 24 hours, the batter will obtain a memory and last longer.
Jan 03, 2014 | Dell Latitude D620 Laptop (Latitude-C620)...
I have two latitude x1.one dosent charge the betry.i have to put charged betry in it and its work fine..i need to fix this.anyone can help me?
Try another Cord/charger with the EXACT same power specs as the Original. Both Batteries are good? Both Cord/Chargers are good, same power specs. DC volts and Milliamps? Dell Specs: http://www.dell.com/downloads/emea/products/latit/LAT_X1_emea.pdf Battery, charger can be found here: http://www.atbatt.com/laptop-batteries/b/dell/m/latitude-x1.asp
Feb 27, 2013 | Dell Latitude X1 Notebook
Latitude X1 PC Notebook: I just used ny Dell Latitude X1 to add a new lapto...
If the other laptop can't see the network, then it sounds like you somehow turned off SSID broadcasting while you were in the router's settings. Log back into your router and look for the SSID broadcast enable setting. Make sure it is set to on, then save the changes and reset the router if you have to. The laptop should be able to see it now. (There is also a setting in the Windows wireless network properties that you can check to connect to a network even if it is not broadcasting, as long as you have connected to it previously.)
Hope that helps!
May 17, 2010 | Dell Latitude X1 Notebook
How to replace battery for a Latitude X1
The Dell Latitude X1 laptop has a 53 WHr 6 Cell Lithium Ion Battery. Your safest bet is to purchase a replacement battery from Dell directly, in order to avoid confusion and mismatched parts. The Dell Part number for your battery is Dell Part# : 312-0342. The Manufacturer Part# : Y6457. The cost is 135.99 from Dell directly. While you may be able to find a battery elsewhere for cheaper, it is not recommended.
Good Luck,
NOLA Tech
Jan 28, 2010 | Dell Latitude X1 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
Dell Latitude D510 will not charge battery
HI, check soldering on Fuse 1 right next to the power inlet plug, just fixed mine.
you will have to dissassemble it completly to get acces to it
Jan 20, 2009 | Dell Latitude D510 Notebook
Periodic Boot-up Problems with Dell Latitude D600
Well I had the same problem with my Dell Latitude D600. I tried many batteries, fully charged, partially charged and even i tried scenarios with AC Power On or Off. Nothing really seemed to work as my laptop was both hot and cold. I noticed this problem was coming specially when laptop is cold.
The Solution is found is, when i have this problem, i press the power button and then move the rotate the laptop, so that its screen touches the desk and keybord is upright verticle, i know it sounds ODD, but it really made my life so easier as now this problem doesnt haunt me.  and it will boot on first, second or third go.
Normal Laptop Condition with keybord down and LCD Open
                     /                     /      / lcd
__________/
You need to move the laptop in one of the following if it is having boot problem again
       \               /          \            /            \         /  keybrd  \      /  lcd                \   /                 \/
or put the lcd down flat while keeping the keyboard in the same position as above.
I m sorry the above illustrations are pretty rough but hope u understand what i mean :)
Aug 18, 2008 | Dell Latitude D600 Notebook
Dell Latitude X1 Notebook Logo
493 people viewed this question
Alun Cox
