Question about Honeywell Programmable Thermostat Heater
Trouble Installing Hunter Brand Thermostat
I purchased a new programmable Hunter Model 44155C thermostat. Unfortunately the wires behind my old thermostat were not marked. They are colored, however. I am not able to get the new thermostat to turn my furnace on for heat, nor even to just have the fan turn on after I installed it. Tried a few wire combos. I have a Heat Pump heating system.
  • Anonymous Apr 04, 2009
    ditto
  • 3 Answers
On the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Posted on Apr 29, 2009
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Wiring mdel 44155c unable to wire properly
what wire goes where on new thermostat my wire on old thermostat are red, white, green, and blue ro could u please tell where to connect them on this new thermstat.
Nov 02, 2010 | Hunter 30124 Air Conditioner
Bought 44155c hunter thermostat air won't turn on.
If unit worked before you tryed changing t-stat then its possible the t-stat wires are shorting each other out.take t-stat back off cut back wires a good 6 to 10 inches or if you dont have that much wire to play with just cut back as far as you can and make sure there is no bare wire touching each other ,then just to test unit to make sure its working ok twist yell.,red,green together this should bring both units on and should blow cold.if this works up to this point on the new stat read directions closely there might be a jumper wire in the stat that needs connected usually from y1 to w1 you would install a jumper wire .see if this helps if not write back i have 1 other solution.i hope this helps
Sep 14, 2009 | Honeywell Programmable Thermostat Heater
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Switching old thermostat to Hunter thermostat model 44155c
By describing the wires from your new thermostat and your old one, it sounds like your new thermostat is not compatible with your system. If you have seven wires now, then you more than likely have a heat pump system and you have to get a thermostat that is compatible with this type of system. Then you will have the connections you need.
Jul 11, 2009 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Heating & Cooling Logo
609 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
