Question about SMC EZ Switch SMCGS24 24x1000 Mbps
Sonicview 360 Elite Dual w/ Dish500dpPLUS EXC! signal cant watch!
OK here i go. New to this fta sat deal, anyway i have to coaxes running from sat to receiver (no splitter just running to each tuner). Getting excellent signal and quality (71-73/99-100). Scan EchoStar 8,X and get a load of channels around 250-300. Then scanned echostar 7 picked some more up. then went on to do tuner 2. Only could get a couple of ppv channels and then some dish info channels. NEED HELP! I have checked out websites tried different settings and picked some up but cant view. Says either "no signal or scrambled" Oh i do have the latest USB update. What do i do next??
  • jtanon23 Apr 27, 2009
    I am a newbie to fta and any type of Sat.. installation . I have the sonicview 360 elite, I connected it to my sat. have some signal strength , but no quality signal strenth at all .. 0 .. quality . what is causing this >???
  • excableguy76 May 25, 2009
    I have a sonicview 360 elite dual tuner pvr, diretv phase III 18" dish with triple feed multi-satellite lnb. I have three eyes on the lnb with four wires coming out. I hooked the four wires to the disEqC switch with the single line going to receiver. I am getting signal strength of 72-75 on on Echostar 7 119 but no quality. What am i doing wrong?
    Problem Solver:
  • 10 Answers
Have you resolved this issue and do you now have a ihub for you SV? Since they went IKS and have no stand alone fix, it is difficult to get modded signal. However they are still in the beta phase of this fix and are have some freezing issues. But is you stay with them until they fix this, the you will be fine. Another solution is the ilink or the nFusion STB's. They are proven to be stable for now. Good luck. I am currently testing ilink, nfusion Solaris Prem and HD, SV 360 & HD. Anything I say here is for testing purpose only and not meant to be a solution for a mod fix. As a FTA user, you will understand what I mean.
Posted on Oct 02, 2009
    Sergeant:
    Champion:
  • 214 Answers
You need to use a sonicview splitter and then go into your settings and select proper ports.If you have 2 wires comming from i duel lnb or 2 stats then you install then in the splitter then one wire into your reciever.then you scan the sats on the ports you have them hooked on to. example echostar110 port 1 also tp setting is 12258 Then echostar119 port 2 also tp setting is 12239 then scan. Scan on autoscan. hope i helped :)
Posted on May 12, 2009
Error 771
ok explain a little more please. Make sure U have the coax coming from the Dish (outside) going into the back of receiver where it says SAT in. or if it is a dual tuner (ie: 322 etc) make sure the coax in hooked up to the Separator. also make sure u are using the correct dish and lnb to match ur receiver. I ALWAYS do a "check switch: every time I hook up to a new/different dish just to make sure the receiver recognizes the LNB.
Sep 02, 2014 | Directv D10 DTV Receiver
What sonicview 360 Elite pvr remote code?
0018,0019,0014,0011.
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order. Pull up older posts. Surf the site with patience.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Aug 19, 2014 | Sonicview Universal Remote Control for...
My KVH M3 will not lock on to a satellite, when I run anttena diagnostics everthing is OK except RF Low: 500 and I do not know what this means
RF low means low signal from dish. Maybe blocked satellite, maybe poorly crimped coax, maybe bad sat receiver. Most likely, bad coax crimp!
Dec 23, 2009 | KVH Tracvision M3 Satellite Tv System
Fta viewsat 2000 setup problem
You will need a sonicview or viewsat switch spliter 110 port 1 119 port2 then go into your menu and ajust the settings 110 tp is 12258 and 119 is12239 and make sure you have the freq on the correct setting11250 scan each alone then save.Also set what typelnb you have on there to hope i helped
Dec 17, 2008 | Yamaha HTR-5730 Receiver
FTA updates
how do I get to the up dates on the sonicview 360 premier?
Nov 16, 2008 | Fluke Networks (FTAP-8S) Network...
Viewsat ultra 2000 setup issues
You can go HERE to get all the info on how to set up your dish.
Mar 13, 2008 | Toshiba 57H84 57" Rear Projection...
XBOX 360 Elite RCA video connection problem
On the TV you should have a video, input or mode button. If you press that button while the 360 is on it should pickup the signal. You need to be in video mode instead of cable mode since you are using the red, yellow, white cables. Many TVs have a few video modes so press it wait a few seconds and try again if it does not work. Hope this helps:)
Jan 21, 2008 | Microsoft Xbox 360 Console
FTA fix
try autorollbins
Dec 31, 2007 | Televison & Video
SMC EZ Switch SMCGS24 24x1000 Mbps Logo
998 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
