Question about Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black
Breather for the dish washer
We recently bought a new faucet and I wanted to put the new soap dispenser in the hole in the stainless steel opening in the sink. The breather is hooked up to the dish washer and sink as well. Can I get the breather installed under the sink or something?
    Sergeant:
  • 149 Answers
Yes the breather can be placed under the sink. Just be sure to mount it above the level of the dishwasher. You can either screw it to something wood or use tie straps to tie it up to a screw.
Posted on Mar 06, 2009
Soap dispenser does not dispense the soap properly
Is the door opening ? if so make sure you are not putting things in front of it to prevent it from opening completly. If not you may have a dispenser or control issue. also are all the dishes getting wet? if not you would have a sump motor issue or you are not getting any water at all.
Feb 16, 2013 | KitchenAid 24 in. KUDS02FRSS Stainless...
Soap gets clotted is soap dispenser. Dishes greasy and dirty after cycle.
Hi, the soap is clotting because there isn't enough water being sprayed around inside. The water spray washes the soap out of the dish, if all is working well. My machine had the same problem. I had sufficient water level, but the spray head wasn't spinning very well. I found the end-most hole in the spray bar to be plugged. It is the end hole that provides a jet that makes the head spin. I cleaned a bunch of debris out of the hole and the machine started working and cleaning like it was new.
Jun 26, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
The soap dispenser opens while in cycle but it doesn't wash the dishes they come out greasy and the entire washer is dirty It does get hot but dishes come out dirty Model FP4702799 Serial KUDIO 1ELB L3
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Apr 22, 2011 | KitchenAid 24 in. KUDI01ILBS Stainless...
The dispenser door opens but the detergent is not released into the dishwasher. After the cleaning cycles are done, I open the dish washer door and the detergent is still in the tray. What could be...
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101 //../
Nov 25, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Soap is not dissolving. Dirty dishes! Help!!
the dishes could be hot from the heater start the dw then open the door feel the water it should be hot if not prime the sink before starting the dw
May 31, 2010 | Frigidaire 24 in. FDB750RCC Stainless...
Dishwasher
2 things will lead to soap not dissolving, first is cold water, so make sure you have hot enough water. second and more likely is the dispenser is not opening at the proper time , instead fully opens at end of cycle during the dry cycle never even getting wet, and washing dishes with no soap, id replace the dispenser or make sure your not stacking items in front of dispenser hindering the opening. also powder is best, tabs and gelpack put undo stress on the dispenser door not always allowing full operation...
Nov 06, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Soap Dispencer Doesn't Always Open
We are having the same issue with a new dishwasher. One solution is to leave the soap dispenser box open when you close the door. This will at least get soap in the washer.
Jun 07, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher not cleaning dishes. Casade cleaner not disolved.???
Run the unit with no soap, after about 5 min. of run time open door and check to see if water is clear or soapy,If soapy then you are having an oversudsng issue.When your washer gets to rinse cycle, your unit (if oversuding),will be rinsing with soapy water and the the drying cycle bakes the soap on dishes.You might be having a white film on your clear glasses.Cut down on soap especially if you have soft water.powder soap is best.Your dishwasher will fill , wash , the drain.Its what you put into it that will cause dishes not become clean.
Dec 01, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
New dishwasher
Having same problem + won't dry. Looks like this is a crap dishwaher.
Nov 06, 2007 | Frigidaire 24 in. FDB1050REC Stainless...
Kohler K-5988-2-7 Entree Self-Rimming Kitchen Sink, Black Black Logo
277 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
