Question about Mitsubishi WS-65907 65" Rear Projection Television
Mitsubishi vs-70803 Bad picture, please help
I moved to Costa Rica, the tv has double picture with green and pink colors on everything and the picture curves on the screen. I hired a repairman here who said there are no parts for the repair in Costa Rica. He says I need a new video card, but maybe he means video board, as things do not translate well to English. I can not look for a part online if i do not know what the part number is. Can anyone help me?
Thank you very much
    President:
  • 2,267 Answers
The parts you need to fix the TV are 2 integrated circuits with the following number STK392-040 and the locations of the parts is IC8D01 and IC8D02.
You can find the parts you need here or you can also contact this website and ask them for a convergence repair kit for your TV. They will provide you with the ICs and low value resistors just in case they are damaged.
Good Luck.
Posted on Mar 01, 2009
Mitsubishi VS-55609 distorted Picture Flickers
This is a convergence problem and not really a DIY Many amateurs try it to save money but end up spending more on it than a professional. There are dozens on here that managed to fix it for a day or two only to have it fail again.
cost of fix about $300.
Please rate my help++++Thanks for using FIXYA
Mar 24, 2010 | Mitsubishi VS-5059 50" Rear Projection...
Bought blu ray player but tv doesn't have hdmi input
Try a S-Video cable for the video output.Use a RCA cable for audio output should work simular.
Feb 06, 2010 | Mitsubishi VS-70803 70 in. Rear Projection...
Mitsubishi VS-4561 picture curved inward
Its Your Convergence Chips!. And Maybe a few Resisters!. Common Problem with this kind Of Set!.....
Jun 30, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi VS-50703 blurry after move
A halo effect usually means the coolant in the CRTs need replacing in the effected color usually blue goes first followed by green. red seems to be less prone for some reason.
Jan 14, 2008 | Mitsubishi VS-50703 50" Rear Projection...
Tv lost color
Your problem most likely is on the signal board is my guess. If your not a technician it would be in your best interest to have him check L2C60 on the signal board.
Nov 19, 2007 | Mitsubishi VS-60707 60" Rear Projection...
No red, orange, pink or green color!
Sounds like your green tube is low or is bad
Mitsubishi > VS XXXX
this model is famous for fluid leaks. each projector True True (``````````` (``````````` 0 95250 95250 clip_image002.png tube has a reservoir on the front of it with a fluid in it. this keeps the face of the tube cool.
this depends on how bad the damage is in the tv. in most cases we can reseal the tube and clean up the fluid 400-600.
Once you
take the tube out you will see where it leaked. The problem is that the
frame on the CRT that the heavy screws with springs are mounted on (that
hold the lens coupled to the CRT) is weak and they can bend. We have seen
several that have leaked after the customer moved the set. You can only
tighten them down so much because the frame bends. It is just stamped metal
and not welded at the corners to support the bend.
We remove the CRT, clean it all up, add a very small amount of RTV sealer to
the gasket, reassemble, let the RTV cure thoroughly and refill with coolant.
The extra sealer should prevent future leaks. Haven't had a recall yet.
Mits says replace the CRT...too costly.
You msut check the yokes carefully as well. If any coolant gets into them
you can end up with shorts there and a mess.
Clean the boards carefully and repair any corrosion damage. The coolant is
ethylene glycol and glycerine which is water soluable.
Mitsubishi VS-60603 60 in pink spot
I have seen this before, and I can only describe it as a flaking of the phosphorus coating in one of the picture tubes. If you can, remove the back such that you can take a flashlight and look down into the 3 picture tubes. If you see any flaking or dark spots in the phosphor, there will be a spot on the screen missing that color. Unfortunately, this is not repairable, as all 3 tubes would need to be replaced (like replacing all 4 car tires when one is completely bald) and that would cost more than a new TV.
Jun 06, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Green color/tint over the display
yea you have to call a tech to make repairs to your tv it is having problem in the color circuit good luck
Apr 08, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
236 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
