Question about Kicker Solo-Baric L7 S15L72 Car Subwoofer
My system ''pops'' when I turn my car off.
My Car Speakers ''pops'' when I turn the car off.
    Problem Solver:
  • 8 Answers
Bad ground,or remote wire.
Posted on Mar 01, 2009
What could cause a radio to pop and not turn on again for a 2006 Chevy Aveo
The output to the loudspeakers float at about half the battery voltage in most factory fitted systems. If a wire feeding a loudspeaker has chafed and shorted momentarily to the bodywork, that would explain the popping noise as you switched on the vehicle and it may have taken out the power stage within the radio.
May 28, 2017 | 2006 Chevrolet Aveo LT
I have a big pop on the speakers when i turn on my engine
The HU you removed may have had a circuit to prevent turn-on/turn-off pop. The nav system may not have it.
Jan 15, 2014 | Car Audio & Video
Static popping and buzzing sounds come from the speakers when the car is running. The Radio is not turned on and it will continue for a long time, quit then start again as you are driving.
Is it a factory amplified system? Could be the volume knob. Might try unplugging the radio for test purposes and see if it still pops and buzzes to get a better idea of where to go next
Dec 28, 2013 | 2004 Lexus ES 330
No sound coming from my speakers
Possible scenerio's with the little info you gave.
1.You have a bad speaker thats blown or the wires are touching the chassis of your car.
2. You have a factory amp and you need to connect the blue wire to the amp turn on wire. And if it still doesnt work then you have to rewire it complete or maybe have to get a special car amplifier compatible harness so your aftermarket works with your amplified system in your car.
3. In certain Ford cars they crisscrossed the back speaker wires. To test this unplug your harness from the radio. VERY IMPORTANT( splice these colors of wires in the middle enough so you can use a 9volt small rectangular battery to make the speakers you want to test pop(harmless))
1. green = back left + speaker
2. green/black = back left - speaker
3. purple = back right + speaker
4. purple/black = back right - speaker
test green speaker wires first touch battery to the + and - and the speaker should pop if not you have already discovered the problem. Know this time pop the green + and the purple/black - on the 9volt battery if the speakers pop you have found the solution.
Just criss cross the the negatives of the back speakers. From the radio harness end attach green to green, purple to purple, green/black to purple/black and last purple/black to green/black. And all your speakers should work again.
Dont ask me why late Ford Models crisscrossed their speaker wires. They just did.
Apr 08, 2010 | JVC KD-G140 Car CD Player
New speakers are fuzzy
If it is an older vehicle you could have interference from the ignition system. You can wire the radio to be powered up from a toggle switch that get its power straight from the battery, with a fuse between the battery and switch of course. This will eliminate powering up the radio with the ignition switch and take the ignition system out of it. Also need to make sure the ground wire is grounded good and the ground wire is the same wire guage if not larger than the power wire.
Sep 28, 2009 | Kenwood KDC-MP228 CD Player
Alpine stereo car deck installed in place of factory Bose with
What you have been told is correct, these proprietary systems are great for the manufacturer, but when they start to have issues (and they will) they leave you 2 options: pay through the nose to stay original or replace the amps with new ones....the upside of this is aftermarket amps are soooo mugh better than stock that it is lauhgable.
Mar 11, 2009 | Car Audio & Video
Popping noise in new stereo install
Does this only happen when you turn the stereo on? If so, it's perfectly normal. It happens when the amplifier in your stereo powers up. It's an older car with "unshielded" wiring that isn't going to be grounded properly. Oh, and to answer your question, yes, the plus (+) and minus (-) are for positive (+) and negative (-) terminals. Make sure that red is on positive and black is on negative. Reversing the polarity (installing the wires backwards) normally won't make the system stop working but it can damage your new speakers.
You also should make sure that you've connected the stereo ground. It will probably be screwed onto the back of the stereo and if there isn't a provided green wire in the bundle coming from the car than you'll just need to find a place to attach it to the car's metal chassis.
Nov 10, 2007 | Car Audio & Video
Hooked my punch Punch P450.4 up to speakers and ran rca cables to front and it wont work
Hi Jon,  you need to hook the Remote wire up to the Radios  Blue remote wire.  The car battery power stays on all the time.  The blue Remote wire watches to see when the radio turns on, and signal the amp to turn on as well.
Dec 12, 2006 | Rockford Fosgate Punch P450.4 60W x 4 Car...
Kicker Solo-Baric L7 S15L72 Car Subwoofer Logo
191 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
