Question about HP OfficeJet 6210 All-In-One InkJet Printer
Microsoft Word problem
I want to print a microsoft works spreadsheet in landscape mode but every time i get to the printer view i get a dialog box that says "out of memory - close all applications" ...... can microsoft works be out of memory?? my hp has lots of memory ???
  • 523 Answers
This problem may occur if there is a problem with the printer driver that is installed on your computer.Contact the manufacturer of your printer to inquire about how to obtain and install the most recent version of the printer driver for your printer.
Method 2: Configure the printer as the default printer loadTOCNode(2, 'resolution'); Configure the printer driver that you have installed as the default printer. To do this, follow these steps:
  1. Click Start, and then click Printer and Faxes.
  2. Right-click the printer that you want to set as the default printer, and then click Set as Default Printer.
  3. Click File, and then click Close.
  4. Start Works, and then print the spreadsheet or the database file
Method 3: Install an emulation printer driver loadTOCNode(2, 'resolution'); If the problem persists after you install the most recent version of the printer driver for your printer, install an emulation printer driver. An emulation printer driver is a driver that imitates the functionality of a different printer driver. For example, you may be able to resolve this issue if you install the driver for the Hewlett-Packard DeskJet 550C printer or for the Hewlett-Packard LaserJet II printer. To do this, follow these steps if the printer is connected directly to the computer:
  1. Click Start, and then click Printers and Faxes.
  2. Double-click Add Printer.
  3. Click Next, and then click Local printer attached to this computer.
  4. In the Use the following port box, select the port that you want to use.
    If the printer is connected directly to the computer, the port is typically LPT1 (Recommended Printer Port).
  5. Under Manufacturer, click the manufacturer of the printer driver that you want to use as the emulation driver. For example, if you are installing Hewlett Packard 550c, click HP DeskJet 550c.
  6. Under Printers, click the model of the printer that you want to use as the emulation driver, and then click Next. Select HP. In Drivers, select HP DeskJet 550c.
  7. In the Printer name box, type a name for the printer, click Yes to set the printer as the default printer, and then click Next.
  8. Click the appropriate option for sharing the printer, and then click Next.
  9. Click No, and then click Next.
  10. Click Finish.
    Note If you are using a USB printer, go to step 12.
  11. Start Works, and then try to print the spreadsheet or the database file.
  12. Open Control Panel.
  13. Open Printers and Faxes.
  14. Right-click HP 550c, and then click Properties.
  15. Click Ports.
  16. Click USB001 Virtual Printer port for USB.
  17. Click Apply, and then click OK.
  18. Start Works, and then try to print the spreadsheet or the database file
Posted on Mar 01, 2009
  • 684 Answers
This error message may occur when there is a wrong Printer selected when u try to Print but if it still says the same thing just uninstall and reinstall Works and Check............
Good Luck
Excel table link in word
Excel and Word are two parts of the Microsoft Office Suite that have become standards tools for spreadsheets and word processing.
Among their features are the ability to easily exchange information.
For example, you can easily copy a cell or part of a spreadsheet from an Excel and paste it into a Word document, which preserves all the formatting.
This method requires opening up both programs at the same time.
To avoid this, you can insert an Excel file from within Word itself.
Choose the "Insert" tab inside Microsoft Word to display the Object dialog box.
Click the "Create from File" tab and Browse to display the Browse dialog box.
Navigate to the Excel file that you need and double-click to load its name into the File Name box of the Object dialog box.
Click a checkmark into the "Link to File" box if you want the table that you insert to be automatically updated anytime the original file is changed.
Otherwise, leave it blank if you don't want the inserted information to be affected by the original file.
Click "OK" to insert the Excel file as a frame into the document.
Note how only filled cells from the first table (worksheet) of the file are inserted.
Blank cells are not inserted. You can resize the frame by clicking it and dragging the handles that appear.
You can also click it and drag it to a different line within the document.
http://office.microsoft.com/en-us/word-help/link-or-embed-an-excel-worksheet-HA010120810.aspx - BM4
Aug 07, 2013 | Microsoft Excel Computers & Internet
Tip
How to recover Excel 2007 password
Microsoft Office software developers have been paying more and more attention to the means of protecting users' information, and Microsoft Excel has not been overlooked. Recent versions of the program provide users with advanced features for protecting Microsoft Excel documents against unauthorized access of the information stored in them. The methods include completely blocking access to a document, forbidding saving changes to it. Besides, some expert team even designed Excel password recovery tool to recover Excel 2007 password for those who have lost Excel password.
Set a password to open or modify Excel 2007 password
Set a password to open Excel 2007
  • 1. Click the Microsoft Office Button 3dac3a8.gif, point to Prepare, and then click Encrypt Document
  • 2. In the Password box, type a password, and then click OK.
  • You can type up to 255 characters. By default, this feature uses AES 128-bit advanced encryption. Encryption is a standard method used to help make your file more secure.
  • 3. In the Reenter password box, type the password again, and then click OK.
  • 4. To save the password, save the file.
Set a password to modify a Excel 2007 Spreadsheet
  • In addition to setting a password to open an Excel spreadsheet, you can set a password to allow others to modify the spreadsheet.
  • 1. Click the Microsoft Office Button office.gif , click Save As, and on the bottom of the Save As dialog, click Tools.
  • 2. On the Tools menu, click General Options. The General Options dialog opens.
  • 3. Under File sharing, in the Password to modify box, type a password.
  • 4. In the Confirm Password dialog, re-type the password. Click OK.
  • 5. Click Save.
Remove password protection from an Excel spreadsheet
  • 1. Use the password to open the spreadsheet. (Note: If you don't know the open password, you have to recover Excel password with the third Excel password recovery tool)
  • 2. Click the Microsoft Office Button 3dac3a8.gif , point to Prepare, and then click Encrypt Document.
  • 3. In the Encrypt Document dialog box, in the Password box, delete the encrypted password, and then click OK.
  • 4. Save the spreadsheet.
Recover Excel 2007 password with Excel Password Unlocker Excel Password Unlocker is a popular Excel password recovery tool that can recover Excel password from Excel 97 to Excel 2007
on Jun 09, 2010 | Audio Players & Recorders
Tip
How to set, modify, remove and recover Excel 2007 password?
Set a password to open or modify Excel 2007 password Set a password to open Excel 2007
  1. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document. excel-document.gif
  2. In the Password box, type a password, and then click OK. You can type up to 255 characters. By default, this feature uses AES 128-bit advanced encryption. Encryption is a standard method used to help make your file more secure.
Set a password to modify a Excel 2007 Spreadsheet In addition to setting a password to open an Excel spreadsheet, you can set a password to allow others to modify the spreadsheet.
  5. Click Save.
  2. Click the Microsoft Office Button office.gif , point to Prepare, and then click Encrypt Document.
Related Office 2007 document password tips:
How to set, modify, remove and recover Word 2007 password?
How to set, modify, remove and recover PowerPoint 2007 password?
on May 21, 2010 | Computers & Internet
I need to print landscape orientation on HL 5140 and can't. HELP
I could be more specific if you provide the operating system an application you are running. Without that, all I can tell you is there are up to four places where landscape/portrait selection is made, and one of these is overriding your choice.
In general, these are:
  1. Printer properties. This only sets the default mode, and is overridden by a selection made elsewhere, even if it is the last selection made
  2. File: Print... dialog box settings
  3. File: Page Setup dialog box settings
  4. Format: Document dialog settings - may be in a dialog tab, and does not exist in many applications
In the last three, the correct operation is that the last selection made will be used. Some programs don't follow the rules, so you may have to set all three to make sure your choice sticks (bug in program).
Nov 12, 2011 | Brother HL 5140 Laser Printer
Biz c 650 photocopier does not sort and staples all the sets together when print frm pc
When printing multiple stapled sets from Microsoft® Word all the sets are stapled together.
Solution:
CAUSE: The Collate option in the Microsoft® Word dialog box is selected.
SOLUTION: When printing and stapling multiple sets, the Collate option in the Microsoft® Word dialog box must be deselected. Please
Feb 23, 2010 | Konica Minolta Office Equipment & Supplies
Trying to print microsoft excel spreadsheet printer keeps saying load tray A4 both trays have paper whats going on
This isn't actually a problem with the printer, but with Excel's print preferences.
In Excel, select File->Print to bring up the print dialog.
Select your Dell 3100 if it's not the default, and then hit the Properties button just to the right of the printer name.
On the printer properties dialog, there's a field named "Paper size"
Click on that field and select "Letter (8.5 x 11 in)" You may have to scroll to find this selection.
Hit OK to close the printer properties dialog, then hit OK to print your worksheet.
If this helps, be sure to hit the "thumbs-up" for me!
Dec 24, 2009 | Dell 3100cn Laser Printer
Printer "out of memory"
The problem isn't your printer. The problem is with your Microsoft Works software. I know of six solutions that may work.
1) Download the latest service pack for .NET Framework 1.1. http://www.microsoft.com/downloads/details.aspx?FamilyId=A8F5654F-088E-40B2-BBDB-A83353618B38&displaylang=en
2) Go to this website and download the update. http://www.microsoft.com/downloads/details.aspx?FamilyID=65f5b806-e6a1-4f92-a656-e56eeda67e3d&displaylang=en
3) Uninstall printer completely (again). Unplug the printer from the computer. Reboot computer. Download the lastest driver from HP website. When installing the driver software, choose (type)a different directory,( ie. C:\MYHP\HP4180\ ). Plug Printer back to computer.
4) Go to this website. http://support.microsoft.com/kb/841220
5) Click START, click RUN, type SPOOL. Double click printer folder, clear (delete) any files in this folder.
6) Download the latest version of Microsoft Works 9.0.
Let me know if this works.
Feb 03, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
So which printer are you wanting help with?
Nov 23, 2008 | Office Equipment & Supplies
Changing the direction of the paper
when you gave print command the print dialog box there you get properties tab click on that then you will get properties dialog box there you click on layout you will see protrait and landscap.click accordingly.
Apr 03, 2008 | Office Equipment & Supplies
HP OfficeJet 6210 All-In-One InkJet Printer Logo
149 people viewed this question
Ben Johnson
