Question about Estate ETW4400VQ Top Load Washer
Wont drain or spin is lock up
Have a Estate machine fills up with water and keeps kicking the power off and it wont drain or spin have to manually drain water out. Water is wrong?
  • rosi104062 Apr 04, 2009
    My Estate washer fills up and agitate, but thin stops at the rinse cycle. I hear a buzzing sound like it's trying to do something, but then it seems to cut of power. I can turn the load size to put more water in, but it still won't go past the rinse cycle.
Does not spin all water out, towels are still wet, not overloading, could it be the timer?
Posted on Mar 07, 2009
Estate washer fills with water and stops. It wont agitate spin or drain
Try replacing the lid switch.
These are cheaply mad of plastic, and fail often on all washers.
God bless your efforts.
Jul 03, 2017 | Estate Washing Machines
Lg top load washer keeps filling and has to be manually stopped but it will drain when put on the spin cycle.
HI,
From your description, it sounds like there may be a problem with the inlet water solenoid valve(s). They can stick after several years of use. The se valves are located in the machine, just inside where you connect the water hoses.
Jul 25, 2015 | LG Washing Machines
My washing machine will not spin or drain,only fill up with water
Couple things could be happening;
Scenario 1: Your motor is dead, or the electrical connections leading to it are chewed up and no longer send electricity to the motor. If you have a voltage tester, you should see if you are getting power to it.
Scenario 2: The safety switch that stops the motor from spinning when the lid is open is compromised.. This is possible, but less likely, as the motor would still spin in agitate mode..
Jul 12, 2010 | Estate ETW4100SQ Top Load Washer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Frigidaire wont fill,just keeps draining
Your drain hose must be 36 inches from the ground. Any lower and the water siphons out.
Apr 20, 2009 | Frigidaire Washing Machines
Washer keeps filling w/ water, only stops when changed to spin
Your drain line is too low.
OR the drain line is restricting air where it enters the drain stand pipe.
Remove the drain line and hold it up high.
Turn the washer on to fill. It should fill then stop.
This example should explain what you must do to correct the drain line problem.
Mar 12, 2009 | Whirlpool Washing Machines
Washes but dosen't drain
you having an issue withthe lid switch not activating, either a bad lid switch, or the "arm that hits it simply not making connection and needs adjusting.. chances are you cant hear a "clicking" noise when the lid is lifted and lowered... if this is the case its a lid switch issue... for safety reasons, the machine is not recognising the door closed so wont enter a spin cycle. will hawever wash and fill
Jan 03, 2009 | Estate TAWS800JQ Top Load Washer
Wont spin and drain
What brand is this? If it a whirlpool or kenmore (or roper, estate) It is you lid switch. A very common problem but is cheap and easy to fix. Get me the model number and i can give you the part number for the switch.
Nov 21, 2008 | Washing Machines
Washer repair
The transmission might have locked up causing the motor to overheat.
Nov 10, 2007 | Frigidaire FWS833A Top Load Washer
Estate ETW4400VQ Top Load Washer Logo
481 people viewed this question
Top Estate Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you an Estate Washing Machine Expert? Answer questions, earn points and help others
