Question about Crosley CR249TA Turntable
Tone arm does not retract right
When the album finishes, the tone arm doesn't lift up, it starts to go back to the stand, but across the record itself scratching it badly.
4 Suggested Answers
SOURCE: Tone Arm skips past first song
Hello, A. Do not try to close the case when there is a record inside!! The fact that the turntable cannot do this is not a design flaw--you'll be hard pressed to find a portable turntable that can close with a record inside because if you were to pick up the player with one inside, it could easily slip off of the spindle and scratch against the sides of the player.
B. Are you using the cueing lever to lift the tone arm before you place it on the record? Read the instructions to see where the cuing lever is (it's a little switch on the right side of the tone arm). When you lift it, the tone arm will lift up and allow you to position it wherever you want on a record, then you depress the lever to make the tone arm touch the record and being playing.
I hope that helps!
Posted on Jan 08, 2009
SOURCE: Tone arm retracts before recording is complete (CR-245)
The nickel on the tone arm is the best solution that I have found. I taped a nickel onto the head of the tone arm about 1/4 inch back from the point of the stylus and then taped 3 quarters near the fulcrum to slightly counterweight the nickel's effect. This fixed one of the disc skiing that my Crosley had when I first got it. A new stylus is in the mail and I will try the new needle without the nickel and quarters to see if the original needle was just bad.
Posted on Feb 15, 2010
SOURCE: Cr79 tone arm stops too early
I started having this problem with my Crosley. The automatic stop occurs because the tone arm is attached to a pivoting arm (the white plastic apparatus on mine) that switches the power on and off. When the arm moves toward the center, the pivoting member moves closer to the axis of the platter. When it gets close enough, a ridge on the axis presses the pivoting arm, thus turning it off. The works seem to be calibrated for a standard size records; the 45's I was playing had grooves too far in, so the power was cut before the records end. There may be a way to readjust the point when the pivot comes into contact with the ridge on the axis. However, in a fit of pique and concern that the record could be damaged (not to mention my irritation at the sound of a record coming to a dead stop), I did disable the automatic stop. To do this, file off the ridge, which is the raised line on the black cylinder portion of the platter. You'll have to remove the platter, of course, which can be done by taking off the c-shaped pin which is around the metal axis at the center of the platter. Hope this helps.
Posted on May 28, 2010
STYLUSCITY
  • 271 Answers
SOURCE: Tone arm keeps returning to rest on Crosley CR249
Hi, Try this. with it turned off. Lift tone arm across a record to the run out groove and set it down. Now power up and hopefully it will reset itself. In all honesty I would sell it and get a decent old school player. John. Styluscity.com
Posted on Nov 11, 2011
THE TONE ARM ON MY ROCKOLA 459 SLIDES OVER THE RECORD WITHOUT PLAYING.
Hi
It sounds as if the tone arm has become unbalanced. Make sure the turntable is on a firm flat horizontal surface and at the opposite end of the arm from the needle there will be a weight and a means of altering the position of weight on the tone arm. This weight keeps the needle on the record but only lightly when positioned correctly. If positioned too far from the pivot post the needle will as you have experience skip virtually straight across the record. You need to adjust the weight so that the needle just sits in the groove and plays without being too heavy. It is best to use a record you are not too worried about for this testing as the test record can sometimes get scratched.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Dec 11, 2014 | Audio Players & Recorders
On a L-A55, what causes the arm to retract not high enough and cause the needle to scratch across the record?
I think you you mean the lift and there is are screw on it , and a feather on the other side, turn the screw to the the right a bit , so it gets a little lower
Oct 16, 2014 | Audio Players & Recorders
Record doesnot finish and tone arm does not retract
Are you sure that the deck has an auto retract function? Give make and model please
Aug 31, 2014 | Audio Players & Recorders
Tone arm on technics Sl-BD22 lifts before the end of an album
the anti-skate is set wrong, this stops the arm skatting on to the label in the middle of the record & destroying your stylus tip.
Mar 03, 2013 | Technics SL-BD22 Turntable
Turn table doesn't start when tone arm is lifted
Did it used to start when you lifted the tonearm?
Many turntables start when the arm is moved over the record.
Jan 29, 2013 | Audio Players & Recorders
Wurlitzer one more time. no sound and record will not eject
There is a switch just under the tone arm. When the tone arm moves towards the centre it slowly pushes two copper strips together. When they meet it starts the motor to eject the record. If you can't Cancel the record with the cancel button then that is a different problem, otherwise you can adjust the trip switch by inserting a 7mm spanner down the hole to the right of the tone arm post.
Apr 30, 2012 | Wurlitzer Jukebox 1015 One More Time...
The arm will automatically return without playing the record
Hi Lisa, its a bit of a long shot however try this. With the turntable powered of manually rotate the platter approx 12 times to reset the auto operation back to default. John styluscity.com
Nov 28, 2011 | Audio Players & Recorders
Nov 09, 2011 | Crosley 0187SST Turntable
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
I hope that helps!
Jan 04, 2009 | Crosley CR249TA Turntable
Crosley CR249TA Turntable Logo
140 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Robert Marmorstein
Level 1 Expert
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
