Question about DeLonghi (DLGPAC400) Air Conditioner
Cant find drain hole in window air-con
Have recently been given a DL aircon. model no.dw157E orDW15/E. Am ready to install and need to know where the drain hole is , have searched  but cant locate one. Would be grateful for any help.
    Problem Solver:
  • 12 Answers
Modern window AC units no longer have a drain hole.
Condensate flows to the area under and around compressor. The heat from the compressor evaporates the water.
Posted on Mar 08, 2009
I have recently been given a Victa Catch and Release Lawnmower,but no manual. How much oil do I put in before commencing use. And How do I drain dirty oil?
Victa catch and mulsh ?
search pops these up as 4 strokes
which model and a internet search gets you its user manual
start with 600 ml oil and top up as required
try not to over fill
look for drain plug up under blades or on the side of motor
Nov 06, 2016 | Garden
My aircon gives me a E4 error. what does that mean? I need a manual urgently
Estelle, Estelle. Learn to use Google or some other search engine. That is what they are for. Lets try "aircon manual" but you probably need the model number, right?
So, using the information you gave, I got this:
Product documentation and of course it lists several models.
Don't EVER submit a question without Make and Model included, unless you want non-helpful answers.
Dec 24, 2014 | Office Equipment & Supplies
2010 Vauxhall Astra H (1.4 sxi) Air con previously not working. Had car re-gassed, still no joy. In Opcom Aircon was set to not activated. Changed this to "with clutch setting" an Aircon working now:-) ...
air cont flow sensor may have failed cannot remember on 1.4 model but on 2.0 model its on the left side of the engine. it could be this. a/c dont usually have codes to store. accelerator code is the sensor on the intake on the side. prob just needs cleaning mark were it fits with a pen and take off. on op side there is a hole spray some wd40 in the hole cover it and shack it around . then tip out and leave to dry. then put back on. should be fine then.
Aug 04, 2013 | Vauxhall Cars & Trucks
Front passenger side floor soaking wet,is aircon overflow blocked ?
It probably is blocked and i think the easiest way to unblock it is to drill a hole in the bottom of the heater box.You can pick up a plug at the dealer to block the hole you drilled. The drain tube is located inside the frame so it cant be blown out thats why you have to drill the hole. Call the dealer and he will tell you what size hole to drill
Mar 19, 2011 | 1998 Jeep Grand Cherokee
Drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Jun 28, 2009 | Fujitsu Heating & Cooling
My window air is leaking on the inside of my house
usually because the drain hole/duct/tube, on the outside is blocked, or the aircon is mounted leaning Into the house, condesate that is supposed to drip into the outer casing and run out the hole is funneled over the lowest point of the casing, the house side.
check and unblock the drain,
and ensure the aircon is mounted tilted back.
Aug 02, 2008 | Haier hwr10xc6 Air Conditioner
Error code f and dl won't drain or spin
"Fdl" is a Door Lock error. This is usually an indication of a failed door latch mechanism. To access and/or replace the door latch, click on the following link:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
A replacement latch can be located at searspartsdirect.com. Just type in your model number in the "Search" window. You can locate it under the "Door and Latch Parts" heading as item number 7 (part #8181700). This is an easy repair job if you wish to accomplish on your own and avoid the added cost of labor.
If you do not wish to order the part online, use the part number provided and go to your nearest applaince parts retailer. I hope this helps you. Please post back if you need further assistance.
May 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Installing duplexer for Magicolor 2430 DL
quite easy, remove the cover tape, from backside and cut in the hole in backside cover, if nessesary. then fit the duplexer knobs into holes in backside. shoul work.
Dec 06, 2007 | Konica Minolta magicolor 2430 DL Laser...
Heating & Cooling Logo
457 people viewed this question
Top DeLonghi Heating & Cooling Experts
Paul Carew
Michael Youngman
Michael Youngman
Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
