Question about Sanyo DS32224 TV
Gray screen with horizontal lines accross it
My sanyo tv model ds32225 has a gray screen with white stationary horizontal lines covering it. The picture is extremely bright and can be partial view through the white lines if the brightness is turned all the way down. it does this regardless of if the tv has signal or not. if you have any suggestions id love to hear them
  • 75 Answers
Sounds like you may have a bad ic it probley is a surface mount on the bottom of the board it could couse this problem would need to take to a shop to repair. The ic probley is numbered ic101 on board.
Posted on Mar 01, 2009
What is the code for a universal UR2-211 remote for sanyo tv model#DS32225
Your unidentified universal remote probably has a "code search" feature you can use to find a suitable code in its library. If a thorough search through all categories does not yield a result, you may have to try another universal remote. Not all universal remotes have the same library of codes.
Sep 11, 2014 | Universal Remote Control Televison & Video
Horizontal white lines 27A43.
You have some bad capacitors. They are located very near and next to your vertical IC. I would guess you would have to replace maybe four of these! Thanks for asking!
Jun 12, 2010 | Toshiba 27A43 27" TV
32 ''Sanyo DP32648 TV has horizontal line running across screen
If you do not have any bad capacitors Problem will be the Display Panel
Call Encompass Parts Distribution or visit their website and type in your Model number 1-800-638-3328
Apr 28, 2010 | Sanyo Televison & Video
My RCA console tv has white horizontal lines accross screen, picture is very light and sound is ok, very frustrating. I know its an old tv, but appreciate any response. Thanks
Cold solder joints on the flyback transformer circuit board - probably because RCA used feed-thru steel rivets on their boards. Re-solder the connections using a good solder flux for clean solder joints and this will fix prob. The joints with the dull, pitted finish are the problem joints.
S. Hampton
Jan 26, 2010 | RCA G35773SK 35" TV
My 15 year old Toshiba Televisiononly shows a narrow horizontal band in the middle of the screen. Sound OK.
Hiii fairley,
You aren't specsificly dercribe yor tv set.
For common TV horizontal problem ;i.e : White line accross the horizontal screen, horizontal band,etc..it's can solved by replacing the IC Vertical/Transistor, and olso to replace the cap nearest the IC.
For common TV Vertical Problem :i.e : White line at the center of the screen (top to bottom),Vertical band,etc...It's can cure by Replacing the Horizontal IC/Transistor,and offcurse the cap's.
Tha's what all I know....
Hope can help you to solved the problem.
Thank's
h3liax
Jun 22, 2009 | Toshiba 32A33 32" TV
RCA-single horizontal white line
Your vertical deflection IC is bad.
Nov 04, 2008 | Televison & Video
Horizontal white lines across top of TV screen
Vertical hold circuit is failing.
Check capicitor in vertical hold circuit. You should have solid knowledge of electronics repair before attemping repair. TV's can emmit harmful radiation, and produce voltages up to or in excess of 30kV.
Oct 07, 2008 | Televison & Video
Thin red horizontal lines across screen
replace the focus block or try to adjust the screen control on the focus block for red only. this will affect the white balance of the set so adjust it carefully. the focus block is located on the front inside the set. remove the speaker cover then the 4 screws on the front plate. the focus block is 3" x 2" black box with 6 adjustment posts three for focus and three for screen. adjust only the affected screen (R).
Mar 13, 2008 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Sanyo ds32225 white lines horisontal in keystone shape ?????thanks
your watch tv the tvgoes off com back on nex day
Feb 19, 2008 | Sanyo DS32224 TV
Line accross top of the screen with flashing black and white boxes
Thin white dashes on top of screen is PERFECTLY NORMAL. It is nothing wrong with the TV, it is the broadcast. What you are seeing is the very bottom of the timecode running. It doesn't happen all of the time or all channels. It usually happens with old 4:3 commercials predating "Digital TV." This is mentioned in your Users Manual. You should be able to adjust the horizontal/vertical position in the menu settings.
Jan 02, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sanyo DS32224 TV Logo
261 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
