Question about Sony VAIO K15 Notebook
Sony laptop won't detect hard drive
I installed a new seagate hard drive to the laptop but no primary drive shown , only cd drive shows
  • 26 Answers
Did you config as primary or slave?...jumper setting?
Try entering BIOS before your Operating System begins to boots up.
BIOS must recognize it before Windows ever will.
Posted on Mar 01, 2009
  • Sony Master
  • 5,568 Answers
If the drive hasn't been formatted, that is normal. On some systems, you also have to force the BIOS to recognize the drive by entering the BIOS setup (check with Sony or manual to learn the key needed). Once you know the proper key to tap at power on (it varies, sometimes F1, F2, Esc - who knows?), you will be presented with a simple text screen with a number of different selectable items. Choose 'Set factory defaults' and the BIOS should look for the drive and set the parameters for you. If that still doesn't work, check through the other BIOS items and you should find 'Detect fixed (or hard) drive.'
Sometimes installing a larger drive than the original can cause problems and if the BIOS is older, it may set the drive parameters of the original drive and ignore the excess capacity.
Dell Inspiron 600m: No Boot Device. I'm a computer
Have you tried resetting the BIOS defaults? In doing so, it will force IDE re-detection and often resolve vague boot issues.
Sep 11, 2011 | Dell Inspiron 600M Notebook
Hi, I tried to install a new Seagate 500GB HD on my windows XP system, I also used a bridge card to adapt the drive, as my system is IDE, the new Seagate is SATA, no jumpers on this drive. Problem is once...
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps don
Feb 25, 2011 | Seagate 500GB SATA HD 720016MBSATA3G 500...
St3160827as seagate hdd is not detecting in bios , other new seagate hdd is working fine with the same connection(sata cable and power card) I have imp data in that hdd ,pls help me how to get data...
Turn your computer off.
Disconnect the power cord.
Disconnect all other disk-drives and CD/DVD drives, leaving only the "suspect" drive connected.
Restart your computer, and enter BIOS SETUP, and see if the drive is detected, and how it is connected (primary/secondary, master/slave).
Read the model-number and serial-number and manufacture-date on the disk's label,
and access Seagate's web-site, to check the warranty-status of the drive.
If the warranty is valid, Seagate will replace the drive, at minimal cost to you.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 03, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
Hard drives not detected in my hp compaq nx6310....
Dear, in all the new laptop's its common problem because what bootable cd u are using did not contain sata drivers and thats why it shows no harddrive found ok so search the sata drivers and make bootable cd by adding this sata drivers and than try to boot.
Jan 19, 2009 | HP Nx6310 Notebook
Hard drives show up in BIOS but not in My computer? WHATS UP?
You should not use line select on any of the drives at this point. Set the jumpers on the components to one master and one slave on each channel. Personally I would put one HD and one optical drive on each channel and make the optical drives the slaves but that's not required. Win98 uses a different file system than XP (FAT32 compared to the newer NTFS) but you can still use the drive. I would copy all the files you want to save and then reformat it using NTFS for better performance.
Boot into XP, both HD should show up when the jumpers are set correctly. If they still do not show up go into your BIOS and double check that all master/slave designations match what you have set the jumpers to.
Dec 31, 2008 | ASUS K8V-SE Deluxe Motherboard
HARD DRIVE is not detected
Hi
Yes, problem with hdd you need to buy new hdd, no other choose....
Thanks
May 02, 2008 | HP Pavilion dv1000 Notebook
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
How to install a new seagate hard drive?
I have one thats ide ultra, & my computers see it as a disc drive, like a cd drive when i put it in an external seagate case. but when i put it in as an internal it shows up in cmos w/ 320 g space, & no matter which pin config i use it doesnt show when the os is booted. I enabled LBA like it says on the drive, & tried all the other options in CMOS & havent got it to go yet, but it sounds like its running perfectly when it powers up. it'll go, but its actin crazy. ill post it when i get that bastard.
May 02, 2007 | Seagate Barracuda 7200.8 300 GB Hard Drive
Sony VAIO K15 Notebook Logo
282 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
