Question about RCA D52W19 52" Rear Projection Television
Need circuit board
I have a rca d52w19 tv and i need the circuit board where the flyback transformer plugs into do yo know where i can get one
  • RCA Master
  • 5,568 Answers
You might be able to get some help from the owner of the RCA name;   Thompson Consumer Electronics
Posted on Mar 01, 2009
Where is the flybac located in a rca hd52w59
Hello
Flyback transformer other wise called Line output transformer {LOT} is actually a step up transformer, which supplies extra high tension voltages to the guns. It can be locatee on the main printed circuit board. 2_7_2012_5_19_59_pm.jpgJust see the different views of the main board of your RCA TV. You can see the flyback transformer at the left top corner, look like a large black componen; with a ferrite "U" type core goes though it. It is the LOT. Line Output Transformer, otheriwse called as Flyback Transofrmer. OK.
Feb 07, 2012 | RCA Televison & Video
I REPLACED RCA D52W19 CAPACITORS ONE TIME 5 YEARS AGO,AND THE TV CAME ON AND WORKED,IT LASTED 5 YEARS,BUT RECENTLY IT JUST WONT POWER ON,I REPLACED THEM AGAIN BUT IT WONT COME ON AND FLASHES THE POWER...
You have a bad flyback transformer. This is a common problem that eventually goes bad in the ITC 222 chassis. You have to get the model number with the code at the end of it after the /. And sometimes you must have the numbers from off the flyback itself. Try to contact MCM electronics for the flyback at 1-800-543-4330. First see if they can match it with the model number with the code after the /.
Jul 15, 2011 | RCA D52W19 52" Rear Projection Television
I have hdtv rca d52w19 green power lights shows
Hello Chris this problem is coming from your high voltage circuit which consist of the flyback transformer and the horizontal output circuit, the most common problem when it is acting this way would be bad soldering on the flyback transformer or defective transformer but keep in mind it can also be caused by the horizontal circuit or a faulty lamp as well can cause this problem, what i would recommend is to have a tech come out to service your tv set this should not be an expensive repair since most of the time it is just bad soldering on the flyback thank you hope this helps.
Aug 27, 2009 | RCA D52W19 52" Rear Projection Television
Burn spot and sparks
is it a off white block with a pink wire set going to the 3 picture tubes?then it is the high voltage called a flyback transformer.
the output is 28000 volts.you have to discharge the tubes before replacing the anode caps which are connected to the flyback.
this is a severe shock danger.
do not attempt this without the service manual ,about 35 dollars from rca.
May 28, 2009 | RCA D52W19 52" Rear Projection Television
Replace transformer
You will need a good quality soldering station, some solderwick to remove the solder from the transformer's pins on the underside of the circuit board. You can also use a solder removing tool but its a costlier device. You will have to remove many connectors and screws to free up the board so that you can access the underside of the board. You will also have to disconnect the anode lead from the high-voltage divider block, making sure the TV is unplugged and that there is no charge left in the CRTs.
If the preceding paragraph reads like greek to you, don't attempt to do this yourself!
michtech
Jan 28, 2009 | RCA D52W19 52" Rear Projection Television
Need to know how to install a flyback in 2004 52 in RCA tv.
First and foremost, disconnect the power cord from the mains.
Next, after having removed the back cover from the set, discharge the tubes' residual high-voltage to ground using a suitable tool.
Access to the transformer is pretty much staightforward here.
A few hardware removals and you can then get to the board and transformer..
Mark, then remove all leads that go to the unit.
INstallation is the reverse of removal.
Be sure to replace the driver device, just to be certain...accordianman
Dec 12, 2008 | RCA D52W19 52" Rear Projection Television
Stil confused
Check 3 capacitors on deflection board where the flyback is but they are located on front of board cp150 2200uf 16v cp111 330uf 35v cp114 220uf 35v Look at top of capacitor cp150 if it looks like it is bubbled on top it is bad so replace all 3.
Oct 04, 2008 | RCA D52W19 52" Rear Projection Television
D52W19 Screen Flicker
Go back to FBT check and make sure your high voltage wirer is in good.
Sep 18, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer
This transformer does not come with the hv lead,if the arch is coming from the side of the transformer,cut the side of the plug were it goes into the transformer and the lead will come out,there is no voltage stored on the hv lead after the set is unpluged for a few min.,the transformer you can get at any rca repair center.
Mar 21, 2008 | RCA D52W19 52" Rear Projection Television
RCA D52W19 Flyback Transformer Replacment guide
The picture tube can hold a charge.with a jumper connect one end to the ground wire around the picture tub. attach the other end to a screw driver and push it under the red cap on the picture tub. that will discharge it.. Remove the transformer from the board by disordering all connections. Insert the new fly and solder. from the old transformer follow the two leads on the side to the screen board at the picture tube. one at a time connect the new transformer leads to the socket and board. part number for the FBT 259296 $50.39 from www.the parts store
Mar 21, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
133 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
