FixYa.com
Tags:
D-Link Dns 323 2-Bay Network Storage Enclosure - Nas Server
D-Link DFE-530TX 10/100 PCI network card not...
By Putty - usenet poster
I got the Cheapbytes CD for Redhat 6.0, and almost everything installed fine
except for networking support for my NIC, a D-Link DFE-530TX 10/100 PCI
card. It works very well in Windows 98, but apparently there is no support
in Linux yet. I tried NE2000, NE1000 (though that's ISA, right?), and all of
the 3Com options, but none of them worked. I have some technical knowledge,
but not enough to write a driver for my card. I've had the same problem with
SuSE 6.1. Do you know if there is support for this card in any form, or if
there's something special I can do in the installation to get it set up? I
might even consider running linux primarily if I were to get this working.
Thanks,
Nick Bennett
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Well for even more confused info to add the 530TX says right on the back
with that stupid logo NE2000 Compatible. I have never tried it but I would
say use the other more specific driver.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Rogers
Rogers - usenet poster
Rating: 0%, 0 votes
[Posted and mailed]
You're probably thinking of a different D-Link model; they've got several
with annoyingly similar model numbers, but radically different designs.
The DFE-530TX is a 10/100 PCI model that uses the VIA Rhine chipset.
AFAIK, it is *NOT* NE2000-compatible. Even if it were, I'd use the VIA
Rhine driver, since it's more specific to the model in question.
Rod Smith
Author of _Special Edition Using Corel WordPerfect 8 for Linux_, from Que
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
Hi Nick..
Boot from a dos floppy and configure your card for 0x300, IRQ 10.
I'm fairly certain that the NE2XX driver/module will work.
Jim
Jim Chisholm
Dalhousie University, Dept. Physics Halifax N.S. Canada
Halifax Regional Fire and Emergency Service
Lieutenant #2 Bay Road Station 59
Solution #4
Not Rated (0)
jessie25
Rating: 0%, 0 votes
Supported by VIA Rhine driver.
Regards
Wei Shun
Solution #5
Not Rated (0)
Kim1
Kim1 - usenet poster
Rating: 0%, 0 votes
Regards,
Wei Shun
Solution #6
Not Rated (0)
jessie25
Rating: 0%, 0 votes
[Posted and mailed]
There is Linux support. The D-Link DFE-530TX board uses the VIA Rhine
chipset, so you need to specify the via-rhine driver. I'm using one of
these as the link between my Linux box and my DSL modem.
Rod Smith
Can you Help with these Network Storage problems?
Network Storage
telefunken ttv-29tb pincushion
I have the above tv and the... Answer This...
Network Storage
external drive just stopped...
First, Windows warned that a... Answer This...
Network Storage
transferring files from...
I recently purchased the Antec... Answer This...
Network Storage
DNS-323 ACCESSING A NETWORK...
I have made a few attempts in... Answer This...
Network Storage
Trouble with Simple Share 250
posted by Kb2MSE on Jun 24,... Answer This...
Repair Service
Find Network Storage Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
