Question about Lexmark JetPrinter X1185 All-In-One InkJet
Paper feeds crooked and will not go through printer
Just suddenly happened.
  • 653 Answers
Sounds like you have something jammed in the paper path. Take out the paper tray, and the toner cartridge, and look for scraps of paper, a paper clip, staple, stray cat, or other item in the path.
Posted on Mar 01, 2009
  • Fahr Quad Mar 07, 2009
    So how mad was the cat?
My paper feeding is crooked
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
May 15, 2016 | HP OfficeJet 7310 All-In-One InkJet...
Paper going in crooked
Adjust the side guides in the paper tray up against the paper snugly. If it still feeds crokked try feeding paper through the hand feed tray.
Dec 27, 2012 | Office Equipment & Supplies
Paper is pulled through crooked printing is not straight. how doyou clean the rollers?
This can be caused by several factors. It could be that there's something(like small foreign objects in the paper feed area) causing the paper to get crooked. It can also be caused by improperly adjusted paper guide or the paper is not in good condition.
Paper Feed Rollers Are Rolling But the Paper Is Not Feeding
How the Accu-feed Paper System Works
Mar 23, 2011 | Lexmark X75 All-In-One InkJet Printer
Paper feeds crooked and results in a paper jam.
Assume every time this happens something microscopic fell into that tiny pinch of an area. I have found everything from a Tostito crumb to a chip of drywall blocking my paper feed. Flip your machine over and shake it around til the little bugger falls out.
Oct 03, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Paper feeder is not straight
Push the copy button with the cover up and no paper on the glass. Is the light bar straight up and down, or is it crooked? I can't imagine how paper could go thru the machine crooked, but check it out if you can. If the paper is too thin, it may not be getting grabbed by the rollers right.
Mar 04, 2009 | Brother MFC 7420 All-In-One Laser Printer
Samsung SCX-4200 manual feed prints crooked
You need to change the pick up rollers for your printer if it pulling the paper unevenly... but first check to see that the paper size adjuster on the tray i self is set to your paper likeness.....adjust to the correct paper size if not...
Please don't forget to vote!
Cheers!
Nov 13, 2008 | Samsung SCX 4200 All-In-One Laser Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Crooked printing on HP C3180
good paper also try instalinga fresh new driver from website and unstall old one 1st before u install new one maby try runing cc cleaner also free tool u can dl online free form filehippo.com
Jan 07, 2008 | HP Photosmart C3180 All-In-One InkJet...
Images coming out crooked when in copy mode. A hardware problem?
Ensure the guide for the plain paper onto which the image is printed, are pushed up fully. It is possible that the paper is being fed into the paper feed path at an angle if the guides are nut pushed up.
Jun 22, 2007 | Brother MFC-640CW All-In-One InkJet...
Lexmark JetPrinter X1185 All-In-One InkJet Logo
107 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
