Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
3 bootons on the key opens both garage door at same time
I programmed the remote key to open the small garage door but now both bottons open both doors at same time. I like to program firsy botton for big garage door and small one for small door
  • 26 Answers
Reprogram one at a time with others unplugged...no power no programming will be received...pretty simple.
Posted on Mar 01, 2009
Garage Door Opener
there a botton inside the opener and a botton inside your garage opener push them both at same time it should link together
Dec 11, 2011 | 2002 Oldsmobile Silhouette
I recently bought a house which has a craftsman 1/2 HP garage door opener. The garage door opener works fine using the wall mounted pad and also the numeric key pad, but not with the remote that came with...
If you didn't, try programming the remote this way.
Press and hold the button on the remote and then press and immediately release the smart/learn button on the motor unit. If this doesn't work you need to make sure you have the correct remote for the model opener you have. Your model number doesn't bring any results from Sears Parts.com.
Nov 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
We bought a Craftsman 1/4 hp garage door opener. It came with a car remote and a push button. The push botton works fine to open and close the door. But the car remote will only open the door. What do...
If you didn't install the door sensors you must. If you did, make sure they are pointed at one another and the small light on each one is lit and not flickering. Tweak them a little.
Oct 28, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have an old Lifmaster professional garage door opener model 1040-6. I just got a new car that has a built in garage door opener. The instructions call for pushing the reset button on the garage door...
THE OLDER UNITS THAT HAVE SWITCHES INSTEAD OF A PROGRAM BUTTON REQUIRE A DIFFERENT PROCEEDURE - YOU USE A REMOTE PROGRAMED TO THE DOOR TO TRAIN THE VISOR.
IF YOU NEED INSTRUCTIONS GOTO HOMELINK.COM FOR COMPLETE SET - PRINT THEM OUT AND KEEP.
HOPE THIS HELPS
Apr 26, 2010 | liftmaster Chamberlain Garage Door Opener...
How do i program my garage door opener with my diamante
Most garage door systems, using ROLLING CODE technology work like this: You have to be ready with someone in the car, ready to push the button.,then you press a button on the garage door unit (get a ladder, and a light, climb up and READ the directions). this button press opens INVITE to any remotes. then have the person in the car press the button.
The reason for READ on garage opener is that one botton invites, and another CLEARS all remotes.... if you press that one, all remotes need to be reinvited.
Mar 14, 2010 | 2001 Mitsubishi Diamante
I have a liftmaster security+ garage door opener. My car remote does not open the door anymore. Is there someway to reprogram the remote again? We are also having problems programing the remote in our car,...
If the instructions for programming your car remote has you using your original remote and the original remote has quit you will need to purchase a new Liftmaster remote.
Oct 06, 2009 | Sears Craftsman LiftMaster Chamberlain...
Remotes won't open garage door, keypad will
If you look were the small wires attach to the opener there should be a red program button and instructions on how to program remotes.
Feb 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
GARAGE CONTROL SYSTEM
Try holding the hand held remote up next to the homelink (built in remote). Hold down the botton on the hand held remote and the botton you want to program in the car at the same time until the homelink light goes out. This could take 60 seconds or more. Now depending on which model garage door open and how old it is you may need to program the car to the opener. Usually this is done by pushing the botton on the back(Liftmaster,Sears, Chamberlin) or the botton on the front(Genie) and then go to the car and push the same botton on more time. I hope this helps.
Feb 05, 2009 | 2005 Honda Pilot
Program my garage door opener
What the last guy post is correct, but you have to tel your car what kinda remote you have. Assuming you have homelink Which 95 percent of the cars do ill give you a very short version on how to do this. First thing you need to do is clear the code in your car from any other owners. Do do this turn your car's key to the on or acc non running position. Press and hold the first and last button. Untill the light reacts different ether starts flashing or flashes faster etc. Then you need to get one of your remotes. Press and hold the button you want to set in your car and press your remote button at the same time untill the light reacts diferent. Mind you hold your garage remote as close to your car remote as you can. Then finally Find your learn button on your garage door opener it's self it can be in the back or the front if its in the front you have to remove the cover press the button once DO NOT HOLD IT. then go to your car and press the button you set for about 2 seconds and repet 1-2 more times untill your garage door moves. Make sure nothing is in the way of the garage door. (I know that should go with out saying.)
Dec 29, 2008 | 2001 Chrysler Sebring
Deactivating the garage door opener
If you hold the 1st and 3rd botton down in your honda built in remote for aprox. 60 seconds or until the light next to the bottons goes out, this will erase the program from the car. You shouldn't have to mess with you garage door opener at all.
Dec 23, 2008 | 2005 Honda Pilot
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
145 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
