Back to:
Tags:
JVC BR-DV600U Mini DV VCR
Is a TBC needed to make a quality VHS tape from...
By Odud - usenet poster
What recorders make a really good video from miniDV (I know to use S-video)?
Is a deck with a TBC necessary to make a quality recording?
Thanks...
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 02, 2007
Not Rated (0)
Ranny
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
to add to the BRILLIANT advice you recieved
remember that vcr's with built in tbcs can be a better vcr sometimes
same with Svcrs
so even though your Buying a good vcr you throw in the unneeded tbc as a
extra, and when you show on this tbc device the pic will usually look
better.
Looping
if you LOOP through this to another recorder turn the tbc off when DVing
also if you get them jvc things turn off R3 turn the edit switch on in
picture control
a tech said the non tbc models of the jvc's have the same cheap mechanism as
the tbc models, well he was basically correct, the arangement of some of the
items is diferent, but the quality of all of them is the same CHEAP, even
the $500 models, it amazed me to see a tech who thought that even the Casing
on the units could be a little more substantial.
Martian
sold by weight not by volume
some settling of the components
can occur during shipping :-)
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Is a TBC needed to make a quality VHS tape from miniDV?:
I don't want to Accept this solution
Solution #2
Not Rated (0)
kioner
Rating: 0%, 0 votes
You're right, that's what I meant but I was just writing it badly. I added
an exception to the TBC requirement in a paragraph that appears after the
one you commented on. Any way you said it better than I did.
Thank You!
Solution #3
Not Rated (0)
M0nica L
Rating: 0%, 0 votes
While your info is correct when coming off an analog format (or a ccouple of
pro digital formats), it is not correct when coming off DV. The sync info is
never recorded to the DV tape. Therefore it can not be sloppy from tape
inaccuracies. It is rock stable generated by the device playing the tape. It
will never need the time base correction of a TBC. That is why they can get
away with saying that they have a TBC built in.
Thank You!
Solution #4
Not Rated (0)
jessie25
Rating: 0%, 0 votes
You can make great dups from DV to any format, but a TBC, waveform / vector
scope, and proc amp is the equipment what's required to ensure that the
analog video signal is the best it can be.
A TBC is a Time Base Corrector, it compensate for the video signal's timing
inaccuracies when playing back from tape. Video tape stretches slightly,
causing the video signal to become sloppy. This sloppiness causes
degradation of the signal and shows up as dropouts, color shifting and other
problems. The TBC restores the timing of the video signal to rock solid.
Duping a tape without a TBC can add a significant loss of quality.
A Proc Amp allows for adjusting the video signal's setup (black level),
video (white level), Hue (aligning the color signal), Saturation (color
brightness). These values are best set initially with a vector / waveform
scope while playing back SMPTE color bars recorded onto the tape. The color
bars should be from a meaningful source like from the camera that originally
shot the footage.
Here's a rundown on some of the analog formats:
Betacam / BetacamSP:
This format is mainly for broadcast use and have their own TBC & proc amp
built in.
VHS/SVHS/8mm/Hi-8:
These formats are mainly consumer, but are frequently found in industry.
Some models have TBCs, most do not.
DV:
This format doesn't need a TBC since it's video signal isn't coming off an
analog tape. The tape stretching is not a problem with video output. Most,
if not all, DV decks have composite and "S" connectors. These connections
interface consumer and industrial VCRs. The "S" connector gives better
quality so use it for composite I/O when it's available.
Some DV decks have component connectors in addition to the composite
connectors like the JVC BR-DV600U that can interface to the broadcast
Betacam decks.
Whenever recording an analog video signal, the best quality is obtained from
setting the video levels with the TBC, waveform / vector scope, and proc amp
using color bars as outlined above.
Another deck to look into is the JVC HR-DVS1U / SR-VS10U. These are dual
decks and have both DV and SVHS decks in the same box. Duping between DV &
VHS uses internal connections, and the VHS side has a built in TBC. JVC has
several other VHS models that have some level of internal TBC. Look at them
here: #
Thank You!
Solution #5
Not Rated (0)
Reynolds
Rating: 0%, 0 votes
No, the 1980 does not have a full frame TBC. Full frame TBC's are only found
in Professional VTR's like the AG-7750. The 1980 is an industrial prosumer
deck. Professional VTR's come with balanced audio in and outputs and do not
have a tv tuner built in as does the 1980.
Bob,
VID-COM
Thank You!
Solution #6
Not Rated (0)
pandamama
Rating: 0%, 0 votes
TBC only affects playback, not recording. And TBC is a built-in format
requirement for all consumer and industrial DV gear.
Any decent Super-VHS deck, therefore, should make excellent standard VHS copies
from a miniDV source.
Also, there are very few VHS-format decks with TBC, other than industrial (and
very expensive) models.
The best VHS playback I've ever seen has been from Sony's SLV-R1000 deck (still
available), fed to my 32" XBR100, and a Panasonic AG-1970 (now replaced by the
AG-1980) fed to the 27" PVM-2950Q. IINM, the latter deck has a full-frame (or
at least full-field) TBC and 3D comb filter.
CPJ2000
Thank You!
Can you Help with these VCRs problems?
VCRs
My Vcr will not turn on, When i press the on button it...
VCRs
VCRs
VR633HF vcr will not play my movies. It immediatley ejects...
capturing from the deck onto final cut studio 2 which is...
I can power on my deck, but when I try to eject, rewind,...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Home Media Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
