Question about Kenmore Washing Machines
What causes brownish stains and lines on white clothes
My whites are coming out of my Kenmore HE washer with brownish stains and lines on them. What is cause and fix. How can I get the stains out? I have had no luck with that.
    President:
  • Kenmore Master
  • 2,651 Answers
Browninsh stains and lines geneally cpme from the dryer, not the washerif indeed it is the washer id look at between the front rubber boot for something stuck causing the marks
Posted on Mar 01, 2009
Rust colored mark or short line on tee shirts
most likely coming from your washer....when clothes are wet it harder to see marks....washer needs new seals.
Jul 20, 2010 | Maytag PYE2300AY Electric Dryer
Clothes are being stained and ruined in our kenmore washer. there are brown stains covering our white clothes.
This is greasy rust. It's not uncommon. Whats causing it is a bad tub bearing. I rate replacing it a 6 on a scale of 1 to 10. 10 being the hardest.
Please rate solution
Aug 27, 2009 | Kenmore Washing Machines
Clothes come out with stains on them
I had a similar problem with my Kenmore front loader. Turned out that the rubber lining around the door was trapping dirty, soapy water causing a nasty residue to collect. That residue got onto the clothes. I cleaned the rubber liner and now keep the washer door open between uses. I still occasionally wipe down the rubber liner with a wet rag. Problem seems to have been solved.
Jun 13, 2009 | Samsung WF328AA Front Load Washer
Brown stains on white clothes in front loading washer
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 12, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
My Kenmore heavy duty tumble washer is leaving a light brown stain on white or light clothes. It is likely staining dark clothes but of course they are too dark to see a light stain. It is definitely...
Jun 06, 2009 | Kenmore 44102 Front Load Washer
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of...
I have been getting brown stains in the shape of a line on items of clothing washed in my Whirlpool duet washer. I can not get these stains out with anything and they are ruining numerous items of clothing. I have no idea what is causing them - I have manually cleaned the inside of the washer. same thing here. I have been having this problem for a few weeks, cant wash anything white without ruining it.
Apr 23, 2009 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
Iam getting brown spots on white shorts after washing with Kenmore front loading washing machine
If it's gunk or build up the marks should wash away. In this case run a long cycle using "affresh" or "washer fresh" with an empty load and use the hottest water available to help rinse the gunk out.
If the marks do not wash away, it could be grease due to a bearing failure. Listen for loud growling or grinding either by spinning the drum by hand or putting it into a spin cycle. If this is the case, the rear tub assembly (contains bearing) will need to be replaced. Not much can be done about the ruined clothes :(
Jan 18, 2009 | Kenmore 44102 Front Load Washer
Rusty stains on all white clothes washed
I don't think the washer is at fault; the clue is 'Used very little.' I think the rust is originating in the water pipes serving the washer. The only help there is to run one machine with no clothes in it (wasting water) or putting splitters on the faucets and flushing the lines into a sink or other drain. To remove rust stains from WHITE (!) clothing and many synthetics, buy a product named 'Whink.' It is available in many drug stores, super markets, etc. in the area where one finds other laundry items.  It is fairly safe to use (with precautions) but keep out of reach of kids.
Jul 26, 2008 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
420 people viewed this question
fordexpert
Archaeology
Archaeology
