Question about Intel InBusiness 8-port Fast Networking Hub
Computer IP I have one XP machine that does not ipconfig through the Hub. I have tried some things but they didn't seem to help. When I tried gentle incrementation of the I P ADDRI get an IP error message, when I try IPCONFIG /RENEW it doesn't work. I'm confused.
  • 71 Answers
You must do ipconfig/release then renew
Posted on Mar 15, 2009
Theres an ip address conflict when i use my 8 port NWAY switch
You need a router to use the hub or switch. It provides the IP routing. Make sure the Router is set DHCP. If you have all this correctly setup then try:
Go to Start > Search (Run in XP) and type cmd and hit ENTER. In the command prompt type ipconfig /release and hit ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it.
Dec 10, 2012 | Encore ENH908-NWY-A 8-Port Nway Switch
Tip
How to Check TCP/IP Configuraitons
The first step in the troubleshooting process is to check the TCP/IP settings. You can check it by using the IPCONFIG/All command on the command prompt. You will see the configuration results. If you see a blank configuration for a card this means then the card is not assigned any IP address. You can assign the IP address manually or via DHCP server. If you are using the DHCP server for assigning the IP addresses then you can use the following commands to get and release the IP address.
IPConfig/Release
IPConfig/Renew
IPConfig/All
If the computer is still unable to obtain an IP address, then there are several things that can causing this problem such as bad network cable or NIC card, DHCP server might have assigned all the IP addresses from its pool, mis-configured TCP/IP settings, incorrect user name and password. You can try to add a new well configured machine to the replace the malfunctioning machine to see if the new machine is working with its settings. Also see if the driver of the NIC is properly installed or not. In case of driver's problem go to the vendor's website and install a new exact driver for the NIC.
on Mar 25, 2010 | Computers & Internet
I bought a dell latitude computer from someone the internet worked but when I got it home it didn't work.
Renew the IP
Go to Start > Search (Run in XP) and type cmd ENTER. In the command prompt type ipconfig /release ENTER. Then type ipconfig /renew ENTER. This just refreshes your IP. Test it.
Dec 04, 2012 | Dell (04U621) for Latitude D600, Inspiron...
EEE PC, Win XP, TCP/IP and DCHP does not work, cannot renew IP address.
flush and renew your ip address via this commands:
*click the start menu*select "run"*type "cmd"*press enter*you will have a black screen*type ipconfig/release*then it will release your current ip address*type ipconfig/renew to renew the ip address then you're good to go.
Dec 27, 2011 | Computers & Internet
What is the default IP address of D-Link DES-1024R for accessing from PC for switch management?
the usual ip add of a Hub or Router or Switch is either 192.168.0.1 or 192.168.1.1. to determine the Ip Add you can check it - Start - Run (for XP) - type Run in the search box and use the Run command - in the Run Box type in "CMD" - a small black box will pop up (that's the command prompt) - then type in "ipconfig" - look for the "default gateway" that's the ip add of the switch or hub or router.
Hope this helps
Jun 21, 2011 | D-Link DES 1024R Plus (DES-1024R+/5)...
I recently purchased the D-Link Ethernet Broadband router DI 504M. I've followed the instructions provided twice, but it will not allow me to connect to the internet. I can connect to the internet with my...
it seems to be just settings for the new device your lacking.
log on to the router as ADMINISTRATOR,
Windows 2000/XP -
To release and renew IP address, go to Start > Run. Type in CMD and press Enter. At the prompt, type in ipconfig and press Enter. This will display the adapter information such as IP address, Subnet mask, and default gateway.
To view additional information such as Mac address, DNS servers, etc, type in ipconfig /all.
To release IP address, type ipconfig /release.
To renew IP address, type ipconfig /renew.
If you are not able to get an IP address try setting one statically:
Windows 2000
Step 1 Right-click on My Network Places and select Properties.
Step 2 Right-click on the Local Area Connection which represents your network card and select Properties.
Step 3 Highlight Internet Protocol (TCP/IP) and click Properties. Enter your IP information for your network.
If connecting to a router, make sure the default gateway and a DNS server is the IP address of the router (e.g. 192.168.0.1 or 10.1.1.1).
Windows XP
Step 4 Click on Start > Control Panel > Network and Internet Connections > Network connections.
Step 5 See Step 2 for Windows 2000 and continue from there.
Hope this helps ,
Please Rate Me ,Cheers Misterdj
Apr 10, 2010 | D-Link 4-Port Ethernet Broadband Router...
Hi I have a linksys router that had 3 computers working on it lately my telco has updated me to a new router so I now use my linksys router as a hub or switch(not sure which) one of my computers works but...
Hi Louie
the first thing i would check would be if there stale dns entries on either of the two that wont  connect using your linksys.
if you open a command prompt, in XP, go to start menu>>run and type in cmd
vista and windows 7, go to start menu, in the search box, do search for cmd
once the black window comes up, type in,  ipconfig /flushdns
(keep this window open)
then try connecting to the net. if that doesnt work, then in the same black window, type   ipconfig /all
for your machine ip address it should show something like  192.168.1.xxx   usually the first number is one but sometimes 2, but can be any number up to 255.
if this shows a 169.xxx.xxx.xxx number then your computer is not talking to your router.
in that black window, type in   ipconfig /release
if this is successful then you will see the message telling you that the adapter ip was successfully released.
then type in   ipconfig /renew
if this doesnt help then if you repost can help you with your router troubleshooting.
hope this helps
Feb 15, 2010 | Linksys Computers & Internet
Wrong ip address. No fix w/ipconfig/renew
192. is the beginning of a default gateway IP address and is usually only assigned when you are using a router. I recommend connecting to your router.
Jan 22, 2010 | E-Machines eMachines Desktop PC
IP address
Did you just install this card??
If so did you install the software first?
How far away is the this from the router??
Feb 13, 2008 | D-Link AirPlus G DWL-G510 802.11g/b...
Adding additional computer problem
Yes, the xp machine connects to the net. DHCP is not enabled. The ipconfig/all command brings up the correct static ip address, subnet mask, and default gateway. But it does also say under the ip configuration that ip routing is not enabled. I did have the 2000 machine connected when I first set up the router yesterday, but I booted up my laptop to try to set up a wireless connection, and then I had to reinstall the entire router set-up.
Jan 12, 2008 | Linksys Wireless-G WRT54G Router
Intel InBusiness 8-port Fast Networking Hub Logo
63 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
