Question about Optoma H27 DLP Multimedia Projector
Optoma H27 Projector will no longer power up after bulb change
I purchased an Optoma H27 projector three years ago. Recently, the bulb life warning message has appeared when turned on. Yesterday afternoon, the projector turned itself off and was unresponsive while the kids were watching a movie. There were no blinking lights on the housing to indicate temp or bulb failure. Later in the evening, the stand-by light was flashing again. I turned on the power and the picture came back for less than an hour when it went into total power off again. I assumed that these events were related to the bulb reaching the end of its useful life. I followed the instructions to replace the bulb with an OEM replacement bulb.
Problem is the projector will not power up with the new bulb or with the old bulb put back in. I can not find any type of reset button or fuse. All I can find is a proximity switch that the bulb cover actuates when installed. I cycled the switch a few times in case this component was not making a good connection. This did not change the outcome.
Is there anything else I can do to troubleshoot and restore the projector to proper operation?
  • rupegui24 Apr 30, 2009
    I am having the same problem. I don't know what to do.
  • kayoss82 May 03, 2009
    I have a very similar problem, i get no power when i turn it on. No Flashing lights at all. Wierd thing is it is always isolated from power when not in use. Twice this has happened and twice power has come back at random times and worked fine? The bulb has sone next to no use over the 3 years ive had, maybe 100 to 200 hours.
5 Suggested Answers
  • 4234 Answers
SOURCE: Optima H30 warning
The only way is to reset the bulb hours counter. There are instructions on how to do this with the replacement bulb. Please note that this procedure will reset the counter to zero(0). You should kee track of the actual hours on the bulb so you don't get surprized during a presentation.
Dan
Posted on Aug 25, 2008
jahting
  • 70 Answers
SOURCE: I have an Optoma EP745 projector. I heard a 'pop'
check all the fans, if still working. if the problem occur get assist to the nearest technician im sure your lamp balasst was deffective.
Posted on Oct 24, 2009
projdoc
  • 2236 Answers
SOURCE: on my optoma H77 I am replacing a burnt out bulb
clean out the projector with canned air to get rid of the dust that could be causing it to overheat. also make sure the fans are spinning. if it still blinks, replace the temp sensor. if it overheats alot, the sensor will wear out from excessive heat.
Posted on Nov 16, 2009
projdoc
  • 2236 Answers
SOURCE: I have an Optoma EP716 projector. It has run for
either the lamp has/is going to expire, or the ballast is bad. if the lamp has bulges or black spots on the inside, replace the lamp and clean out your projector with canned air. too much dust keeps in the heat and makes a 2000 hour lamp go in 1100 hours.
SOURCE: Optoma hd65 projector new bulb wont turn on...cant reset timer!
I think it's a lamp driver issue from what I've seen others have gone through. I also read that if you go through the sequence of unplugging, plug back in, wait 20 seconds and try to turn on, multiple times, it will finally kick on and work. I just got mine to turn back on by doing this and waiting through the fan cycling without the light turning on. After the 4th sequence the light flickered. After the 7th sequence it finally turned on and is working. Now I can watch the Super Bowl and will look into replacing soon.
Posted on Feb 06, 2011
Optoma 25hd air filter issues
Hi Cathy,
The replacement of the filter is something that needs to be done at a service center by a trained technician. If you are interested, feel free to send us a message: Projector Repair Bulb Replacement
Jan 16, 2014 | Optoma HD25-LV - HD 1080p 3D Home Theater...
Bulb blows on gt700
Possibly a bad ballast or power supply going to it causing it to either kill the bulb or your old bulb may still be good. Did you rest the counter in the menu for the bulb life after replacing?
Nov 05, 2012 | Optoma GT700 Projector
My projector's power light is red, but when I click power it won't turn to green (on)
The likeliest problem here may be a burned out or failed projector bulb. Most projectors will fail to power up at all when if the bulb is out. The HD20 user manual does not specify a red light as an error indication option however, generally amber.
User manual .pdf is located here (takes a bit to download for it's size), Projector Status Indicator instructions are located on page 40.
Here on the product page itself, an email to Optima support may be warranted given the red instead of amber error light.
If you had any messages recently indicating your bulb life was nearing it's end, again, this would be my first guess. Certain models of projectors do have a tendency of blowing through bulbs even before any warning message comes up. I had an experience with a certain brand/model that for the last 3 replacements has given only about 1/4 of the stated bulb life, so unfortunately it does happen.
Mar 05, 2011 | Optoma HD20 DLP Projector
How do you install new light bulb
The Projector will detect the lamp life itself. It will show you a warning message renstrike_1.jpg
When you see this message, change the lamp as soon as possible. Make sure the projector has been cooled down for at least 30 minutes before changing the lamp
  1. Switch off the power to the projector by pressing the Power/Standby button.
  2. Allow the projector to cool down at least 30 minutes.
  3. Disconnect the power cord.
  4. Use the screwdriver to remove the screw from the cover. (1)
  5. Push up and remove the cover. (2)
  6. Remove the 2 screws from the lamp module. (3)
  7. Pull out the lamp module. (4)
To Replace the lamp module, reverse the previous steps,
Feb 28, 2011 | Optoma EP716 Multimedia Projector
I have an OPTOMA H27 projector, I am experiencing problems with the quality of the video images displayed. I set the focus by using the internal menu as an image reference. However when I view DVD/Video...
hi,
if u are using the composite video the try component video. composite video will dive u a dull image than component one. also check the distance between the projector an screen.Make sure the projection screen is between the required distance 4.9 to 40.7 feet (1.5 to 12.5 meters) from the projector.
ok
Dec 30, 2010 | Optoma H27 DLP Multimedia Projector
How do you feed TV thru an Optoma DLP projector?
You need a tuner to tune in the tv channels. use a vcr that way you can change your channels
Jun 06, 2010 | Optoma EP739 Multimedia Projector
How do I find the remaining bulb life for the Sanyo PLC SE-20
There is not a set time for bulb life. The projector will have a timer built in to tell you how many hours it's been running. I've had projectors that I've reset the warning twice before I've noticed any performance issues with the bulb. That particular bulb has a life of approx 2000 hrs, so go through the menu on your projector and find the "lamp timer" or something similar to that and do some simple math. :)
Jan 16, 2010 | Optoma EP732H EZPRO DIGITAL PROJECTOR...
Blotchy colors on optoma hd80
i had, have the same problem i also replaced the bulb then shortly after the power went out no standby light or anything. From what i've read so far it seems like a power supply issue so i ordered two power supplys from optoma 1 for lamp 1 for the unit waiting on delivery from CA they were $ 99 each if this work i'll be one happy camper. Three years no problems it's a great machine with incredible picture using 106" screen
Dec 22, 2009 | Optoma HD80 Projector
Optima H30 warning
OK, found the solution on the net, you have to use the buttons on the projector instead of the remote to access the menu item.
Aug 25, 2008 | Optoma H30 Multimedia Projector
Optoma H27 DLP Multimedia Projector Logo
446 people viewed this question
Top Optoma Office Equipment & Supplies Experts
Electro Med Services...
Computer Links
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
