I don't Know my secret number
I'm trying to change my tv input from Air to Cable in the EZ Setup but it is asking for a Secret No. Any help out there?
  • 26 Answers
Try "0000"hope this helps.
Posted on Mar 01, 2009
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
Jan 27, 2014 | Sharp LC52SB57UN LCD TV
Sharp aquos 60 inch. Setup ok went thru ez scan for channels then not sure if i hit something getting settings right but now all it does is repeatedly tell me to search for channels even right after it...
Look in the menu to see if in catv or cable band or air band for antenna and you do have a way around this if using cable box or sat box---connect box via the jacks on the rear of the box (component or composite--component being better) and hook up to the correct matching input on rear of set--select that input on the set and change channels etc via the box.
Also try to unplug set for a short time and go through the setup again, be patient as a channel scan can take several minutes in some cases
Let me know what happens of if you have questions
Dec 06, 2012 | Televison & Video
Sharp
Hello
Just unplug your tV from AC mains, and leave it thus for about 10 minutes, and then replug it back. See whether this process help you or not. If yes it's ok. If not, and you did forget the passcode, there is a way to clear the passcode.
[1] Press MENU to display the MENU screen, and then press C/D to select serup.
[2] Press a/b to select "EZ SETUP", "CH SETUP", PARENTIAL CONTROL" OR "RESET" and the secret number input screen displays.
[3] Press and hold both CH r and VOL k on the tV simoultaneously until the messege appears on the screen. As a precutionary mesure, make a not of the secret number above, and keep it in a safe place.
If you cant get any menu screen, make sure that the main system control section indie the circuit board is faulty. It may be wither to a loss of supply voltage to that section or a damge to its system memory IC. System memory IC damge is a common fault to most of the TVs, and it will not cost more as this 8 solder terminal IC wont cost more. If you are aware in electroncis, and have confidence to do this work, and have ability to follow the schematic diagram of the set, inform me by Fixya. OK.
Nov 19, 2011 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
I forgot my pin number and master key please help
In the System Settings Menu, go to the 3rd page, then select "PARENTAL CONTROLS."
  • Select "YES," to change the parental controls.
  • You will be prompted for your 4-digit PIN.
    If you know the PIN, select the empty text box and enter the PIN using the on-screen keyboard, then select "OK" to continue.
    If you don't know the PIN, select "I forgot," then select the empty text box for the answer to the secret question and enter it using the on-screen keyboard. Select "OK" to continue.
    If you don't know either the PIN or the secret question, the Parental Controls will need to be reset.
    An Enquiry Number will be displayed. Ring the number given in the Nintendo DSi Operations Manual and provide the Enquiry Number. You will then be issued with a Master Key. Tap "OK" and enter the Master Key. Tap "OK".
  • Select "PIN" to change the PIN or "CHANGE SETTINGS" to update the setting you wish to change. Once the changes are made, select "DONE" to confirm any changes.
"If you don't know either the PIN or the secret question, the Parental Controls will need to be reset. Please call 1-800-255-3700 for assistance."
Aug 01, 2011 | Nintendo DSi Black Console
Can't access all the channels. I moved tv from one
You didn't say what model number, but check the setup menu to make sure it is set for cable (if you are using cable) and not AIR. Otherwise let me know the model number and what you are using for signal (cable, satellite, etc.)
Jul 04, 2011 | Sharp Televison & Video
How can I disable a Parental code that has been entered into my tv by some one. The tv is a Sharp Model LC-C4067UN Sharp Aquos
Press the menu button and select 'Parental CTRL' whcih will be located somewhere on that menu or in other submenus. When selected you will be greeted with two options:
  • New Secret No.
  • Secret No. Clear
Choose the 'Secret No Clear' option to clear the parental settings for the TV.
May 04, 2011 | Televison & Video
I want to change my parentle controles don`t know pin and secret question
To have your Pin/Secret Question Reset call 1-800-255-3700 for assistance which is Nintendo's number for it. I hope this helps you
Feb 28, 2011 | Nintendo DSi Black Console
Please give me .....TV SHARP Password???
.sharp X Flat Slim TV model number 21G-FX35 i lost my password please tell me its master password
Nov 27, 2010 | Sharp 27C-240 27" TV
My tv keeps asking me my input secret no.it says time over. how do i solve this problem? i cant watch any other thing on my tv. and i dont know the secret number
Feb 26,2011
my tv keeps asking me my input secret no.it says time over. how do i solve this problem? i cant watch any other thing on my tv. and i dont know the secret number .my brand of my t.v is sharp aphrody...
Dec 26, 2009 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Unable to change v-chip code in my sharp television set HELP
Go to Sharp webste http://www.sharpusa.com/ download your manual for the tv and whala it is done...
Nov 14, 2007 | Toshiba 32A33 32" TV
Televison & Video Logo
225 people viewed this question
Top Televison & Video Experts
Electro Med Services...
