Question about Nintendo GameCube Console
My Gamecube won't work right.
Whenever I turn on my Gamecube, the light and the fan both turn on,
but then the light turns off, the fan keeps running, and the gamecube doesn't do anything.
  • Anonymous Mar 01, 2009
    The same thing happend to me, all i did was leave it off for a while then tunred it on and it worked
  • megamanblue Jan 27, 2010
    Nevermind. I got a new GameCube.
You are so stupid just let it rest
Posted on Mar 11, 2009
There is to much electrcity in the game console let the gamecube rest for a couple of days
Posted on Mar 02, 2009
Whenever I try to play my Super Smash Bros. Melee game with 2 players (me and my dad),It always automatic turn off. I tried every combination of black and white controller,but no working. WHY IS THIS...
Power Light Shuts Off
If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
Feb 27, 2011 | Nintendo GameCube Console
My Nintendo Gamecube seems to reset by itself about every 30 minutes, can anybody help?
If the power shuts off during game play or resets after 30 minutes after the system is turned on then turns off and won't turn back on or the fan isn't working, the system needs to be repaired then. This problem that you have might be the fan thats causing this problem then.
Jan 08, 2011 | Nintendo GameCube Console
My Nintendo Gamecube received a big powersurge and now it won't turn on. Is there any hope for it or is it fried ?
  • No Power
    1. Make sure that the words "Nintendo GameCube" are molded into the AC adapter. Unlicensed products are not fully compatible and may not work correctly.
    2. Make sure the Nintendo GameCube has good ventilation. For best results, make sure that the system rests on an open, flat surface. Avoid operating the Nintendo GameCube while it's on carpeting or inside an enclosed space.
    3. Check the vents on the sides of the Nintendo GameCube for a build-up of dust. The system will shut down if it cannot vent properly to prevent overheating. If there is a build-up, remove it using a vaccum cleaner with a soft brush attachment.
    4. Avoid the use of unlicensed products such as memory cards, controllers, and cheat devices. Some of these products are poorly manufactured and may result in damage to your system. If one of these products is attached to your system, remove it and try resetting the AC adaptor (see below).
    5. Make sure that your wall outlet works. To check it, try plugging a lamp into the same outlet where your system was plugged in. Turn the lamp on the verify the outlet works. Also, make sure you are not using an outlet that is operated from a wall switch. If you do, make sure the wall switch is in the ON position.
    6. Make sure the AC adapter is attached properly. Firmly plug your AC adapter into the back of the Nintendo GameCube (the port is labeled DC 12V IN) and into a working wall outlet.
    7. Press the power button on the Nintendo GameCube and check to see that the red power light on the top of the Nintendo GameCube illuminates.
      If this fails, try resetting the AC adapter.
      1. Unplug/remove all accessories from the system (including game discs, memory cards, and all controllers), hookup cables, and the AC adapter from the outlet and Nintendo GameCube.
      2. Let the system rest for about 45 seconds. While you're waiting, check to see that the cords on the controllers, AC adaptor, and Stereo AV cables/Component Video cables (or RF Switch) are not frayed or have exposed wires (this can cause the system to shut off); if so, you should replace those parts.
      3. After the 45 seconds, Plug the AC Adapter into the system and wall outlet. Press the power button to see if the system works.
        • If the system works, turn the power off and plug ONE accessory into your system, then turn the system on to see if it still works. Repeat this process with ONE accessory at a time. If your system doesn't work once you put a particular accessory in (GameDisc, controller, Memory Card), there may be something defective with that accessory.
        • If the power does not come on, a repair will be necessary. Because it is not possible to determine which item (Control Deck or A/C Adapter) needs repair, please call our Consumer Service Department at 1-800-255-3700 to discuss available options.
    8. If the power is continually shutting off after aprox. 30 minutes, listen to hear if the fan is working while the system is powered on. If the fan is not running, the problem will continue (Nintendo GameCube is avoiding overheating) and the system will need repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair.
  • Jan 01, 2011 | Nintendo GameCube Console
    Turns off automaticly
  • Power Light Shuts Off
  • Sep 27, 2010 | Nintendo GameCube Console
    No power The light does not come on. The game does not turn. The fan does not blow.
    • No Power
    Dec 21, 2009 | Nintendo GameCube Console
    Power button failure
  • Sep 11, 2008 | Nintendo GameCube Console
    Gamecube - blank screen, disc wont spin, power light and fan work.
    Troubleshooting - Power
    No Power
    Power Light Flashes
    Dec 07, 2007 | Nintendo GameCube Console
    Nintendo GameCube Console Logo
    214 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Raj Patel
    Julian Wainwright
    Martin Murray
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
