Question about Panasonic TX-32LXD70 32 in. HD-Ready LCD TV
I have lost the manual. How do I connect the DVD
Someone pulled out the jacks on the back of the TV. I don't know which sockets in which to put them back as I have lost the manual with the diagram of the back of the set.
  • 653 Answers
The red and white jacks are your left and right audio channels, and the yellow jack is your picture. On the back of the TV, the jacks should be plugged into the audio/video input jacks. You can download a manual at www.service.us.panasonic.com/operman/
Posted on Mar 01, 2009
I'm trying to hook up my DVD player to my TV but my TV doesn't have a yellow jack only red and black
If your TV doesn't have a Video IN jack (Yellow) then you would have to attach your dvd by antenna (Coaxial) cable. What does the DVD have on the back ? EG: Video Out is Yellow, Red is Right Audio, White is Left Audio. If your DVD has Ant in & Ant Out you can use a coaxial cable from Ant out to your tv's antenna In socket and put your antenna cable (from your wall socket) to Ant in on the dvd. Turn on the dvd and put your tv on a blank station and tune your tv till you see the dvd screen . lock it in and that becomes your DVD channel to watch your dvd's.
Hope this is some help.
Sep 07, 2015 | RCA Televison & Video
Have just purchased Toshiba 32kv500b tv and as there is only one scary socket don,t know how to attach a dvd player can you help with this problem please?
Connect the cables from your dvd player to the connections on the side, not the back, of the tv. If you are using component cables, match the colors in the 3 top ones (YPbPr) and the red and white go down into R&L just above the headphone jack. If you are using composite the plug the yellow just above the R&L connections.
Jul 06, 2011 | Televison & Video
DVD is playing but no sound is coming out. Where do you put the video cords from the player to the TV. We have an older Sharp tv
What is the model of your DVD Player? and does your old Sharp TV have jack plugs in the back to accept audio leads.
Normally you would connect a Scart lead from the DVD player to the back of your Sharp TV.
If your Sharp TV is so old that it does not have a Scart Socket then you may have to use an RF lead running from the RF out Socket from your DVD player to your Sharp TV!
Jun 22, 2011 | Televison & Video
NEED INSTRUCTIONS FOR HOOKING UP WIRELESS HEADPHONES FOR VIZIO TV
From the manual:
1. Plug the stereo audio cable into the headphone jack of your audio
source (e.g., stereo, TV, CD player, DVD, etc.). If your audio source
has two RCA output jacks instead of a headphone jack, use the
supplied Y cable to connect your headphones to the two (red and
white) RCA jacks.
2. Connect the other end of the stereo audio cable to the AUDIO IN
socket at the back of the recharging cradle/transmitter.
3. Connect the AC/DC main power adapter to the DC IN power
supply socket at the back of the recharging cradle/transmitter. Then,
connect the adapter to an electrical outlet.
Important: This power unit is intended to be correctly oriented in a
vertical or floor mount position.
Manual:
http://audiovox2.info/docs/common/AW772/AW772_OM.pdf
Jun 10, 2011 | Acoustic Research AW-772 Headphones
How do you connect a toshiba dvd to a tlc plasma tv
First of all unplug tv and tosh dvd.
1.connect the antenna(digital aerial) to the ATENNA IN jack of the dvd.
2.connect the ANTENNA OUT jack of the dvd to the Aerial jack of your TV.Using a RF cable(usually supplied if new)
3.Connect AV1(TV) scart socket of the dvd to the scart socket of your tv.Using a scart cable.
Then you are ready to start and program the channels.
Oct 10, 2009 | Televison & Video
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
Magnavox 20MC4304 connection to receiver
your set has a coaxal DIGITAL output so you must have a coaxal digital input to your reciever and that input must be assighned in the reciever to the selected input. page 10 of your manual explains how to hook up to the tv. your receiver's manual will tell you how to assighn the coax input.
Mar 09, 2008 | Philips Magnavox 20MC4304 20 in....
Connecting laptop audio to tv
i had the same issue with a thinkpad T61 which i was connecting using VGA and a audio jack going straqight from the headphone socket to the back of tv.
I had picture but no sound and i found that once connected the issue could be solved by rotating the projection setting on the laptop(Fn+F7). Basically switched back to laptop only display, then back to laptop and projector display again and teh sound just kicked in.
i think it's related to the projector setting on the laptop rather than an issue with the tv.
Oct 12, 2007 | Protron PLTV-32 Television
Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Sep 05, 2007 | Samsung CXD2512 25 in. Combo
Panasonic TX-32LXD70 32 in. HD-Ready LCD TV Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
