Question about Numark TT1520 Turntable
I cant get one of my numark tt1550 turntables working
I have bought some numark tt1550 turntables second hand , one works fine . with the other one the speaker makes a buzzing noise and you can hear it very slightly , Help please
  • 3 Answers
Check earth connection.
Posted on Sep 03, 2009
  • 69 Answers
Check needles and all connections also connect any gnds (earths)
Posted on Aug 06, 2009
I just put a numark tt usb from USA on a French electricity, it works only 10 seconde and power off with a little "poof" noise whats can i do, is it burn or can i repair it
No! I'am afraid it is done, the turntable motor is more than likely burned out along with several electronic parts, since hydro operates on 220volts at 50 cycles per second where you are it makes it totally incompatible with our system.
Mar 19, 2011 | Numark ttUSB Turntable
My numark TT500 turntable doesn't spin when i press play
Sounds to me like the belt has snapped or slipped off. Lift the platter off the table. On the inside of the platter you will notice a second ring, or rim. the belt should be put on the outside of the second rim while the platter is still in your hands. Next, slide back the platter and look for the spindle running the platter through one of the big holes in the platter. Slip the belt onto the spindle and turn with your hand to make sure it runs freely. Hope this helpsmicmor100.jpg
Jan 04, 2011 | Numark TT500 Turntable
I bought two numark ttx usb turntables of ebay with no warranty, they were from the usa. one of the turntables works fine the other did not even turn on at all. i thought it must be that i did't flivk the...
Here is a copy paste from Numark's Quick start owner manual page 3:
3. Voltage Selector:
This switches the internal voltage transformer between 115V, 230V and 240V. The turntable should be shipped with the proper voltage setting for your region. Check that the switch is in the proper voltage before connecting the power cord to prevent damage to the turntable.
At page 2 also there is a diagram showing the exact place for that switch.
So I can't believe that this turntable is stricted for use under 115V. Also, as far as I know from my experience (23 years Electronics Engineer), the only thing that coulg be before the transformer is either the voltage selector switch, or some kind of ac filter. The only case that I'm not sure, is the case that you powered up the turntable at a 230V area and the Numark's voltage selector was set at 115V. In that case the transformer should be burned and the service should replace it and charge you the cost for that.
I think that there is something strange at your case. Why don't you check at another service center at your area?
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 13, 2010 | Numark TTX1 Turntable
Numark Omni control-iMac Problems
Did you try this turn table on another PC? It is the best way to check for I never seen a NuMark act like yours. A secondary PC is always great to have if you constantly need this turntable
Mar 28, 2010 | Numark ttUSB Turntable
Numark x2 motor problem
I would like to know if it possible to use my Numark DXM09 mixer ... with two Numark ICDX players and use Numark Cue software
Oct 14, 2009 | Numark x2 Hybrid Turntable
Numark tt200 motor
The knocking sound is NOT normal, and you should not ignore it.
The tt200 is a HIGH TORQUE turntable, and as such is a highly accurate lathe for the accurately determined speed of the platter.
The lathe is in need of adjustment, which is recommended.
Apr 06, 2009 | Numark TT200 Turntable
Second hand decks
The unit should not be making any sounds like that. It sounds like the timing is off for the gearing underneath the platter. It may be as simple as cleaning the existing grease on the mechanism and re-lubing. The existing grease may have gummed up a bit not allowing the parts to move freely. Take of the bottom and look at the condition of the grease.
Dan
Jan 27, 2009 | Numark TT1650 Turntable
Cant connect my Numark PT-01 to my Numark DM950 mixer
What do you mean it didn't work? What happened? Are you getting no sound, did the plugs not fit? Please be more specific.
If you are not getting any sound, make sure you connected to the LINE input of the mixer - the PT01 has Line Level outputs, so you CANNOT connect it to the Phono input, as the signal will be too hot for the mixer - so make sure it is in the LINE INPUT. Also make sure the toggle switch on the mixer is set to LINE. There is nothing else to this set up, raise volumes, and that's it. It's very simple.
- OPTiC
DIY Yourself DJ Repair Videos
DJ Equipment Sales
Jan 08, 2009 | Audio Players & Recorders
Turntable
No way to fix these. Numark discontinued the parts for this model, in addition, it probably would have cost you more to repair than fix.
Junk em. Next time buy a package with Technics turntables in them. You won't regret it, and they hold their value over time.
I know Technics 1200s are not cheap, but with the money you just wasted on this package, you could have bought 1 Technic 1200.
- OPTiC
DJ Pro Audio
www.djproaudio.com
Mar 05, 2008 | Numark TT1520 Turntable
Numark TT1520 Turntable Logo
548 people viewed this question
Top Numark Audio Players & Recorders Experts
 Grubhead
Grubhead
Colin Stickland
Colin Stickland
Are you a Numark Audio Player and Recorder Expert? Answer questions, earn points and help others
