Question about Lexmark X1240 All-In-One InkJet Printer
Printing in all red (lexmark Z715)
This is on a mac.  osx 10.5.9 or whatever it is.  the printer was fine the last time i printed.  so i flipped on the switche in preferances to print in all black.  but now i have a streak that doesn't get printed, running about the middle of the line.  i cleaned the heads with a qtip and alcohol.  but i was really wondering about the printing in red which has my concern.
thanks.
  • the_visitor
    the_visitor Mar 01, 2009
    first let me say thank you for responding!  i really appreciate your attention to my problem.
    this was a brand spanking new ink cartridge so it would have been free of any gunk.
    -leQ
    p.s.
    on the lexmark Z715s, the black ink is the right cartridge.
  • Lexmark Master
  • 684 Answers
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be dry........... Take the Colour catridge first turn it upside down and u will see a small copper plate on the catridge from where the ink comes out....... Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10 Seconds...... Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same way........ Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a Copper plate on it with small boxes just clean that copper plate with the Dry Paper Towel.......... Know insert both the catridges inside the Printer the Colour Catridge should go in the right side and the black on the left........
Good Luck
Posted on Mar 01, 2009
I have a lexmark z715 printer connected to windows xp. recently it stopped printing. the paper moves and the machine makes sounds similar to printing, but it doesn't print. i think the sound is s
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Feb 23, 2013 | Lexmark Z715 InkJet Printer
Trouble getting printer to print for first time after downloading the driver from the internet. Mac OS 10.4
Try to delete the Lexmark Z715 print object from the Print and Fax on your Mac 10.4. Then, add a new Lexmark print object. After successfully adding a print job, try to print a document again to verify that printing is working properly now.
Aug 08, 2011 | Lexmark Z715 InkJet Printer
Why is my print lighter and hard to read at the top of the page but subsequent copies look fine. thanks, gene
Your cartridges may need to be cleaned. Follow the instructions in this article from the Lexmark website on How to Clean the Cartridges of the Lexmark Z715 in Windows. This will help improve the print quality for your printer. Also, make sure you are using genuine Lexmark cartridges. Thanks.
Feb 24, 2011 | Lexmark Z715 InkJet Printer
I installed the Lexmark z715 printer driver on my Mac and it is connected fine, but when you attempt to print documents, it prints blank pages instead. The ink cartridges are brand new. Please help me...
Ok, you need to clean the print heads they are probally clogged, what operating system are you using on your computer? I can walk you thru on what to do, very simple, if you have windows xp, do this: Go to start then all programs then go to your printer, there should be an option to align paper, clean print heads, print test page, you need to pick clean print heads, then after that print a test page, then if you see something printed but not good qaulity, clean print heads again....if this doesn't work you can take a damp cloth and wet and wipe under the ink cartilige where the ink comes out but is dried and clogged up until you see a rainbow streak of red, blue and yellow, be carefully not to wet any other part of cartirige, you can use a moist q tip if you want.
Jun 28, 2010 | Lexmark Z715 InkJet Printer
Lexmark Z715 printing faded color
you might need to go to the IBM website and find instructions for your printer and look up how to clean the printheads on your printer or just look up the manual that came whith the printer if it did come whith any
May 16, 2010 | IBM Lexmark Z715 InkJet Printer
X4550 lexmark does not print to my mac osx
try reloading the driver and make sure it is compatible with your system
Aug 22, 2009 | Lexmark X4550 Multifunction Wireless Color...
Z715 printing blank pages
your print haed bloked try clean with wet close. repeat until all dry ink remove
Aug 08, 2009 | Lexmark Z715 InkJet Printer
LEXMARK Z715 will only print in yellow and both black and color cartridges are half full.
Clogged, or dirty plunger in this units printhead.. You need to check and clear the clogged unit.. Tihs printer is going to need service..
May 21, 2009 | Lexmark Z715 InkJet Printer
Problem printing to wireless print server
I have a lexmark z715 printer that won't work my pc is a emachine windows xp please contact me at noahmackey@bellsouth.net
Jan 15, 2008 | IBM Lexmark Z715 InkJet Printer
Lexmark X1240 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
