Question about iLO 2600 Television
DVD player w/S-video and the TV does not
I have a DVD player that has S-video and the TV does not (older). Is there a way to make the DVD player work on this TV?
  • lynnloving Mar 03, 2009
    Thanks for the info. I haven't ordered the part yet but will. I sure hope it fixes the problem.
    Lynn
    Is this what you are talking about?
    http://search.cablestogo.com/?N=0&Nt...|-|100000000000000147222&cm_guid=1-_-100000000000000147222-_-2708695281&gclid=CNXo8sWVh5kCFRwpawodaDInmA
    I don't know how to highlight this as a link.The company is Cables to Go. Do I need the adapter (the blue things and the cables? I believe I already have the cables.
  • 44 Answers
Go to amazon.com! They sell adapters, type s-video to rca (a/v) yellow (video), white (audio), and red audio).
Posted on Feb 28, 2009
  • javswr
    javswr Mar 04, 2009
    Sorry, just search for s-video to rca! the rest was explantion of the standard!
I press TV/AV button but my TV does not show AV channel .so l am unabl to connect my DVD player
Main system control memory IC fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 16, 2015 | Televison & Video
I have an older sharp tv from an older sibling and the cable works, but I'm trying to connect what I believe to be an older dvd player to it. The dvd player has the 3 color cords (red yellow and white)...
Those modes you gave are for what TYPE of signal is comming in to the Cable/Antenna connector.
You need to switch from that input device to the other input device, the RCA plugs. These are often displayed as Aux or perhaps Line etc. It would help if you had the remote from the tv and were able to choose Aux or Line, or if it has TV/Video button. But if not, try channel button on the tv itself and go down below Ch 1. If using the cable remote to control TV, it may have a TV/Video button too. Maybe.
Good luck
Jun 07, 2011 | Televison & Video
Trying to hook up an emerson dvd player to tv and its not working? older tv it has no cable hook up or control box for channel set up, shouldnt the dvd player still be able to work though?
IM GUESSING THIS MIGHT BE AN RCA TELEVISION? if you dont have an rca in hook up on the tv give up and buy a new tv or you can find an older item what it is is a switch that has an rca input and a coax output it was used to hook up the older video game systems it is still sold in most stores and that will work if you do have rca inputs and lost the remote you need to get a universal remote to switch the input on certain older rca tv's you could go to channel 00 and it would set it to the input with the switch you shoudl be able to use it by putting the tv on channel 3
Feb 28, 2010 | Emerson EWD7001 DVD Player
DVD and older magnavox TV
On most of the older sets the video input is found by channeling down below channel 2 where you will find the video input source.
Nov 23, 2009 | Philips DVP3140
Craig dvd player, model CVD327, won't play
no, s video is not required to work. if you hooked up 3 colors to the tv 3 colors. make sure it's on video 1 or aux channel. and as long the dvd player is on and that channel is on, if that does not work, try on another tv that has same connection. if that doesn't work, then we know that dvd player doesn't work.
Oct 17, 2009 | Televison & Video
S-video setting on DVD not compatible with older TV
I recommend the obvious solution which is to plug it into an S-Video compatible TV, VCR or DVD player then change your settings. You could make it really for yourself if you want by looking for some software that you burn onto a CD which you make bootable and when you run it in the player it resets everything to factory default settings. But seriously make it easy on yourself and just plug it into an S-Video compatible device (TV/VCR/DVD, preferably a TV for ease, though it doesn't make any real difference). Best of luck to you anyway!
May 22, 2009 | Sungale DVD-2026 DVD Player
Connecting portable dvd player to tv
You should be able to connect the portable DVD player to the TV using an audio/video (AV) cable. The type of A/V cable you need depends on the receptacles on the DVD and the TV. Some older units have only one jack for audio and one for video. Newer units have one jack for video and two for audio. Matching the color coding of the cable, plug one end into the A/V out jacks on the DVD player and the other end into the A/V in jacks on the TV. I hope this solves your problem.
Apr 07, 2009 | Televison & Video
Setting up mintek 100 dvd player to cable box to tv
Newer TVs have multiple inputs. Mr Mark is correct, you generally do not daisy-chain Audio/Video units unless you are using a recording device. Cable box to Cable input on TV. DVD player to other inputs.
Let's get some terminology out of the way. Specifically for the Mintek DVD-1600. There are NO inputs.
Coaxial Audio out (orange) is for digital audio only. Usually connects to stereo reciever for Dolby 5.1 surround sound. Not for TV.
S-Video (black w/4 small holes, 1 square) is for better quality video than composite. Use this to TV instead of Composite if you have a S-Video input on your TV.
Composite (Yellow) Older video input type. Works just fine. Connect to TV.
Audio Output ( Red & White) for analog stereo only. Goes to TV. Red=right, White=left channels.
Component Video Out (Blue, Green White) is the newest video output type in this unit. Better than S-Video. Use this option if available on your TV instead of S-Video or component.
Feb 13, 2009 | Mintek DVD-1600 DVD Player
Dvd player
If it's too old and probably doesn't support progressive scan plug it on s-video or yellow rca plug, but be sure your DVD is setted for that. If is setted for component output plug it on another tv who support and redo the settings.
Dec 30, 2007 | JVC AV-27230 27" TV
Will not work
Hi, you'll want the 3 colored RCA cable to hook this up to an older TV.  Yellow is for Video Out on player and Video In on TV.  Then, on player, correspond the red and white to their holes for Audio Out, and match them with Audio In on your TV.  You may have 2 spots on your TV that are labeled Audio In.  Try them both - the one that works should very close to you Video In line.
Hope that helps!
Dec 07, 2007 | Protron PD-800 DVD Player
Televison & Video Logo
66 people viewed this question
Top iLO Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Jason Morris
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
