TV wobbles on its pedestal stand.
Just bought new TV. Delivery guy set it up. But is wobbles on its stand and sits at a distinct angle on the TV stand.
  • janepkpt Feb 28, 2009
    To clarify.... this is a samsung LCD tv - LN32A450
  • 44 Answers
Sounds like stand has been installed wrong an maybe miss aligned, and screws may be loose! Try removing and start over, or call installer back.
Posted on Feb 28, 2009
How i fix my wobbly high chair
If you know someone that has a welder they could weld it . Or if you don't .and can get the pedestal loose from the base you'll see where the break is .I would cut a piece of plywood drill a hole in plywood the size of pedestal push it in plywood stand stool up push down . Till pedestal touches floor take drill .get some 1" self drill/tapping screws commonly called : TEK-screws put 3 screws in the wood at an angle so screws go into the pedestal to hold it tight paint or stain the wood.your handy work.
May 15, 2014 | Furniture
I would like to remove the pedestal or stand from a LG 42LG70 TV because I want to place the TV on a wall mount.
Usually the safe way to do this is look first at the owner manual but lay set face down on a padded surface so all weight is on the frame around the screen and no weight on the screen itself, exert no downward pressure in that position or screen may be damaged.
Usually pedestal is secured by 4 or more screws that may require the back cover of the set to be removed first, to get at---a careful look with it face down will show if part of the pedestal is under the rear cover of the set or not.
Dec 18, 2012 | LG 42LG70 42 in. LCD HDTV
Separating a glass tv pedestal from a glass tv cabinet
I can only figure that the cabinet is Not part of the TV's normal design and it has been just sitting on this cabinet for a long while?
If this is so then it has by weight and heat sweated itself onto the top, synthetic feet are made of complex materials including oils which get exuded then form a quite powerful glue action, also that spray polish has baulking agents to make it look good in use these act as glue.
If this top is glass then its pretty well resistent to most things, try windolene glass spray its safe and dissolves many things on glass as a cleaner (or other surfaces). Move up to say WD40 a mineral oil again safe wipe clean with meths spirit to clean up just add in a bit of tilting to break that grip.
Hope this helps......
Jun 27, 2017 | Panasonic VIERA TH-42PX80B 42 in. Plasma...
Where can i find a stand
If you're referring to the original pedestal base sold with the TV, your best bet would be Ebay
or Craigslist.
On Ebay, search in the Category: Electronics > A/V Accessories & Cables > Mounts & Brackets >
using the search string "vizio 50 pedestal stand" or "vizio pedestal stand base" and you should get a few matches. For example, this used pedestal stand, which has a current bid of $9.99 USD, or this new pedestal stand, being sold for $149.99 USD or Best Offer.
Hope this helps!
Jan 08, 2011 | Vizio P50HDTV20A 50 in. Plasma HDTV
When we bought this TV - Polaroid FLM-3232, we wall-mounted it. Now we are moving it to a new room, but we can't find what we did with the pedestal stand. How can we purchase a new one?
Hello; Check with Jimmy's parts dot com. This Guy has tons of this stuff. You can also contact Polariod, but they may be very expensive. Good Luck
Nov 21, 2010 | Polaroid FLM-3232 Television
Sony bravia pedestal stand is unstable
http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf This link will show what it looks like when removing base to wall mount.They always recomend a mounting strap that connects to the rear of the TV and then screws into the table it will be sitting on.Not sure what they expect you to do if you have a glass top table. http://www.docs.sony.com/release/SUWL31_EN_ES_FR.pdf
This is a link to all the downloadable manuals and what not.Well hope this will help,and good luck.
Mar 13, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Can't remove base from Regza 37HL17
download manual and check' page 5 'for wall mounting.
Removing the Pedestal Stand
1) Carefully lay the front of the unit face down on a flat,
cushioned surface such as a quilt or blanket. Leave the stand
protruding over the edge of the surface.
Note: Extreme care should always be used when removing
the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose
the pedestal stand screws. The jack pack cover can be removed
without tools.
3) Remove the five screws shown in the diagram below. This will
allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal
stand in place, remove the pedestal stand from the TV by
sliding the pedestal stand away from the TV.
Five screws
Feb 14, 2010 | Toshiba Regza 37HL17 37 in. LCD TV
Try to mount TV to the wall and need to release the TV stand
To Display your LCD TV using a Wall Bracket:
If you decide to wall mount your LCD TV, always use a ULlisted wall bracket appropriate for the size and weight of the LCD TV: 32HL37/32HL37U/32HL17/32HL17U: 38.6 lbs (17.5 kg)
37HL17: 46.3 lbs (21.0 kg)
42HL17: 59.5 lbs (27.0 kg)
1) CAUTION: Two people are required for installation.
2) Unplug and remove any cables and/or other component connectors from the rear of the TV.
3) Follow the instructions provided with your wall bracket. Before proceeding, make sure the appropriate bracket(s) are attached to the wall and the back of the TV as described in the instructions provided with the wall bracket.
4) After attaching the appropriate bracket(s) to the wall and the back of the TV, remove the pedestal stand from the TV as described below.
1) Carefully lay the front of the unit face down on a flat, cushioned surface such as a quilt or blanket. Leave the stand protruding over the edge of the surface. Note: Extreme care should always be used when removing the pedestal stand to avoid damage to the LCD panel.
2) Remove the jack pack cover on the back of the TV to expose the pedestal stand screws. The jack pack cover can be removed without tools.
3) Remove the five screws. This will allow removal of the pedestal stand.
4) Once you have removed all five screws holding the pedestal stand in place, remove the pedestal stand from the TV by sliding the pedestal stand away from the TV.
Sep 28, 2009 | Toshiba REGZA 32WLG66 32 in. Television
I am having a home entertainment center being installed as I speak. However, I just bought a LC52D85U 52"aquois hdtv. I need to know what the height is with the TV on its corresponding pedestal. The...
I told the delivery men I didn't want the TV. I told the furniture delivery men, I didn't want the product and take it back. If I can't find something simple to fix without paying for it, forget it.
Jan 09, 2009 | Televison & Video
Televison & Video Logo
1,930 people viewed this question
Top Televison & Video Experts
